#76 |
Just like to part out trucks!!
Re: Next one getting parted 70 chevy with a 6 cyl
Mark, No problem
Brent, sounds good Willie, I will Pm you Stan, I haven't forgot you just been busy, I will get quote Circa73, powerglide is different Loren, I have 3 or 4 up here, I left you a message on your phone. $20 a hood Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#77 |
Randy, do you have a linkage on the shelf somewhere that will fit a 2spd?
#78 |
I have th350 and turbo 400 linkages
#79 |
![]() Join Date: Nov 2007
how much for the cab, i'm looking for one with no rust above the winshield area,(rusted out rockers/cab corners expected)just trying to find something better than what i have.mike
#80 |
how much for the cab, i'm looking for one with no rust above the winshield area,(rusted out rockers/cab corners expected)just trying to find something better than what i have.thanks mike
#81 |
This cab needs rockers and corners and mounts and I also cut the center part of dash out so it would need dash replaced. Above windshield is good and so is cowl area. I think it needs some floorpan work too, I'm headed out there now I will look at it better. I'd need a $100 for it. Thanks Randy
#82 |
i good with the price.i'll take it as long as its not rusted into the toe boards real bad. i have another dash. do you have any decent 67-68 driver quailty hoods? thanks,mike
#83 |
Mike, I have some pics. It has a hole in middle floor where previous owner must of put in floor shift. It aslo has a patch by gas pedal. Kick panel are are by floor board has small rust. Front driver mount looks solid, front pass mount has some rust but not real bad. both rear cab mounts are rusted out. They put new rockers on it and cab corner, rockers don't look to bad but pass cab corner doesn't look that good. They put a patch in very inside pass corner. Sorry no 67-68 hoods. Thanks Randy
#84 |
eeeee
#85 |
I'll even throw in a new pair of aftermarket cab corners
#86 |
alright. i will take it. i'll pm you information
#87 |
OK Mike, cab is yours with the corner patch panels. Thanks Randy
#88 |
![]() Join Date: May 2009
Do you have kick down cable bracket,carb,and linkage for '67-250,turbo 350?THANKS TOM ALSO LOOKIN FOR POWER STEERING SET UP TO 07726.
#89 |
Tom, I have the kickdown setup off this truck, I can get pics of it Tues. Sorry I don't have any of the other stuff. Thanks Randy
#90 |
Thats cool,I"ll take it,need a price and pic. THANKS MAN
#91 |
Sorry never had time to get pics or get it off today. I will try Wed. Thanks Randy
#92 |
hey,did ya get the pic of kick down bracket? THANKS TOM
#93 |
hows the steering column?
#94 |
Tom, finally got to look at it today, its not in the best of shape, sorry
jhiggy94, this one is out of a 67, what year are you needing one for? Thanks Randy
#95 |
![]() Join Date: Sep 2002
Hey Randy, interested in seat belts, center caps, and intake/exhaust manifold pending pics and price. Also the exhaust pipe if u havent cut it off yet.
Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon Last edited by ScottH; 10-12-2012 at 12:07 AM. |
#96 |
Scott, only have the 2 inner belts. Center caps are $20 plus shipping. Sorry the manifold has been sold with motor. Thanks Randy
#97 |
I have a 72 k20 do you know if the column would still fit in that truck? I would also be interested in one of the rear sliding windows. How much for your best one?
#98 |
You wouldn't want this column out of this truck, you'd want one out of a 69-72, that uses the collaspable shaft. I have one I took out of a 72 2wd that is the same for $40 plus shipping. I have 2 sliders left they are $40 plus shipping also. Thanks Randy
#99 |
Dually Jams, James your up on air cleaner, I've pm'd Spirit of 76 twice and he has yet to reply to me so its yours if you want it. Thanks Randy
#100 |
![]() Join Date: May 2007
I went through the thread , it looks like the carb has been sold is that correct ? as I need the hard ware for the air cleaner to attach to the carb to go with it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
