Old 07-21-2013, 09:45 AM   #76
made2drag
made2drag's Avatar
Re: 56 made2drag
made2drag is offline   Reply With Quote
Old 07-21-2013, 09:46 AM   #77
made2drag
made2drag's Avatar
Re: 56 made2drag
kind of like gardening! almost 60 years of gunk to dig out.
Old 07-21-2013, 09:48 AM   #78
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 07-21-2013, 09:53 AM   #79
made2drag
made2drag's Avatar
Re: 56 made2drag
sprayed some primer on after it hit these with a wire wheel.
yes, i want to send the cab off to the sandblaster so this is a waste of time. but i plan on doing a little patching here and there before it goes to the blaster so i figured i'd stop some of the rust from getting worse til i can weld in some patches this fall. im thinking early spring b4 i can send it to the sandblaster.
Old 07-21-2013, 09:56 AM   #80
made2drag
made2drag's Avatar
Re: 56 made2drag
wire brushed, cleaned thoughly, then sprayed Duplicolor Rust Fix
Old 07-21-2013, 10:01 AM   #81
made2drag
made2drag's Avatar
Re: 56 made2drag
Duplicolor primer then Duplicolor Gloss Black Engine paint next. when the cab is off i'll do the rest of the frame. remember, this was a scrapyard save and im not trying to make a show truck out of it. POR-15 worked well on my 67's frame which has been sitting in the sun for 6 years now, but im thinking the Rust Fix may do almost as good. if i see rust surfacing in a couple year, it will just add to the patina look im going for
Old 07-21-2013, 10:39 AM   #82
Kim57
Kim57's Avatar
Re: 56 made2drag
Looks pretty rough but nothing that can't be fixed with a little time and effort.
Makes me appreciate how good mine was to start with.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-21-2013, 10:53 AM   #83
made2drag
made2drag's Avatar
Re: 56 made2drag
Kim
im hoping i can do something with it. i'd love to replace the floor and firewall the way you did yours. are there any bodydrop builds out there you can point me to? im wanting to do a 2 or 3 inch body drop with a low static drop with a sid drop axle. 2 1/2 inches of ground clearance in the end with a 235/70/15. i've been looking for a 70's camaro front clip but cant find any camaro's in the junkyards. i have a spare complete 73-87 crossmember already but from what i see on other builds they are a tad too wide and they would hang too low
Old 07-21-2013, 11:18 AM   #84
made2drag
made2drag's Avatar
Re: 56 made2drag
http://i781.photobucket.com/albums/y...ps4634ae9d.jpg
whoever truck this is....it's the bomb.
i'd like mine this low and from looking at the signs...static drop....no bags!
Old 07-21-2013, 01:12 PM   #85
Kim57
Kim57's Avatar
Re: 56 made2drag
I've seen that truck at the Brothers Show and the Grand National Roadster show.
Has a ton of work done to it. I don't remember what he did to the suspension.
Kim
My build thread
Old 07-21-2013, 06:41 PM   #86
_Ogre
_Ogre's Avatar
Re: 56 made2drag
use the [IMG] tag and it will load like this
nice truck
shop air compressor timer
Old 07-26-2013, 09:14 PM   #87
made2drag
made2drag's Avatar
Re: 56 made2drag
ttt
Old 08-23-2013, 09:30 AM   #88
made2drag
made2drag's Avatar
Re: 56 made2drag
so i've done alittle research and found this thread:
http://www.jalopyjournal.com/forum/s...d.php?t=245130
seems a flipped front and rear is doable. the bump steer i kept hearing about can be fixed with a steering stablizer and mounting the draglink level with the frame. my thoughts are to flip the front and get the 4 inches then take a leaf out or 2.
Old 08-23-2013, 12:51 PM   #89
_Ogre
_Ogre's Avatar
Re: 56 made2drag
different, but doable. i wonder how it drives. he never posted an update of it after getting it driveable.
lots of ideas out there on the internet, i just am a little leery of some of the projects that are in the works.
i consider bump steer part of the geometry of a straight axle, though it can be minimized, it will never go away.
for some reason, i like his finished yellow 58 truck
as for the rearend, he did pretty much the same thing as i did.
cheap way to do it if you source your own parts, instead of buying a kit.
i recommend a little more c-notch as i had to use air shocks to stay off the bump stops.
Old 08-23-2013, 01:36 PM   #90
Baldeagle SR
Re: 56 made2drag
Welcome aboard. That is a Dodge rearend.from around the 70s.
You do have your work cut out for you.
Rich
My build http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Baldeagle SR is offline   Reply With Quote
Old 08-23-2013, 03:19 PM   #91
meter swinger
meter swinger's Avatar
Re: 56 made2drag
Mine was flipped in the front and rear when first got it...drove like krud. But there was no notch in the front either. This is what a lot of the traditional lowrider guys do but with a bag over leaf in addition to the flip and notch.
Im not sure youll be thrilled with the ride after all that work though. If you cant find a camaro clip in your area, have you considered a jag i.f.s? 59" hub to hub, usually around 200-300, easy to bag. To fit in a 34" wide frame they require a little trimming, but it fits. Some guys notch thier frame to get as low possible. If you are on the HAMB 4t6ford started a group called jag ifs swaps. Lots of good info there.
meter swinger is offline   Reply With Quote
Old 08-23-2013, 03:21 PM   #92
meter swinger
Re: 56 made2drag
Heres a jag in a 57 frame
Old 08-26-2013, 10:46 AM   #93
made2drag
made2drag's Avatar
Re: 56 made2drag
thanks for all the input!
i thought i read somewhere on the thread he thought it rode pretty good.
yeah, mine is getting a deep c notch or step...not sure. i'll prob use coil overs or air shocks.
im not sure about the front. but if i flip it and c-notch then adj out with spring pulling and i dont like it....not out much....little labor...no big deal. i can always wait til i find a frame clip...i got the time.
by the way...i got a chevy 235 to put in it. the ford 6 is for sale, so i dont have to worry about trying to get it to fit and mess with driveshaft mods.
Old 08-26-2013, 10:48 AM   #94
made2drag
made2drag's Avatar
Re: 56 made2drag
Rich
THANKS!!!
i got a ford ranger wheel to fit...dodge and ford same lug pattern?
Old 08-26-2013, 10:51 AM   #95
made2drag
made2drag's Avatar
Re: 56 made2drag
would it have been a better ride with a c-notch and airshocks? less leaf springs? i do still want it to ride like an old truck....LOL...i know that doesnt make sense but i want it to be a tad rougher than stock...LOL
Old 08-26-2013, 10:52 AM   #96
made2drag
made2drag's Avatar
Re: 56 made2drag
what year and model jag? thanks
Old 08-26-2013, 03:32 PM   #97
meter swinger
Re: 56 made2drag
"68-86 (87 in US) XJ6 (and XJ12) XJ-S and XJS 1975-1996 for front suspension - not sure about the XJ40 but could be 1987 through 1992. 59" or 59-1/2" hub to hub. Steering racks vary - quickest ratio is late mid 1993 to 1996 XJS. "
I copied this from another thread, the info seems consistent with what i have read and the jag unit i am tearing apart currently. The one i have is from the mid 80's, though i dont know the exact year as i got it second hand off CL.
Heres a pic of it torn down to the A arms & spindles...
http://s1106.photobucket.com/user/pl...4940.jpg.html][/URL]
Old 08-26-2013, 04:47 PM   #98
made2drag
made2drag's Avatar
Re: 56 made2drag
man, that's awesome!
that seems like the way to go....
i'll keep an eye out for a jag in a junkyard or other for sale sites.
Old 10-25-2013, 10:45 AM   #99
made2drag
made2drag's Avatar
Re: 56 made2drag
Old 02-26-2014, 11:13 AM   #100
made2drag
made2drag's Avatar
Re: 56 made2drag
