Old 02-12-2013, 04:35 PM   #76
robnolimit
robnolimit's Avatar
Re: The BCC No Limit build
The crossmembers that come with kit are pre-drilled for the tank mounts. But regular nuts and bolts are tough to get to, so we use a 'clip-nut' for the tank mounts. This way the tank can be pulled out easily, even with the bed on.
Speaking of the bed, the kit comes with all new bed mounts for the raised floor - on a metal beds. So, for a raised wood bed, the front crossmember goes up with the wood, and a 4" riser is needed. the other mounts are standard.
Finally, an overall shot. It has been on this lift for a while now waiting for wheels/tires, and for me to finish it up. If the bed-cab gap looks a little tighter than normal, it is. The new rail kit moves the bed forward 1/2" to clean things up a bit. This also puts the tire in the miidle of the wheel opening.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-12-2013, 05:06 PM   #77
67cheby
67cheby
67cheby's Avatar
dang.....now i want some gold line tires ! Dig what you are doing with this truck !
67cheby is offline   Reply With Quote
Old 02-12-2013, 05:51 PM   #78
knomadd
knomadd's Avatar
That's some tricky exhaust routing. Nice work!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-12-2013, 06:10 PM   #79
aggie91
I'm just glad to be here!
aggie91's Avatar
It all looks great, can't wait to see it on the ground with the wheels and tires!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-12-2013, 08:48 PM   #80
duallyjams
duallyjams's Avatar
x2
well you if have a I6 with a turbo the exhaust will be a piece of cake
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-12-2013, 10:22 PM   #81
butternut1972
butternut1972's Avatar
I really like the rear rail kit, thats sweet. I see a shortened long box in my future with those! Nice work.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 02-12-2013, 10:48 PM   #82
Rusbuilt
Rusbuilt's Avatar
Very nice!!
Rusbuilt is offline   Reply With Quote
Old 02-13-2013, 12:19 AM   #83
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
very interested in this build. subscribed!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-15-2013, 02:26 PM   #84
Wasted Income
Boosted Member
Wasted Income's Avatar
Cool build.
Looking forward to some more detail on the steering column and column to rack connection.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-18-2013, 09:25 PM   #85
robnolimit
robnolimit's Avatar
Hey Waisted Income, I saw you build thread over on Pro-Touring.com - look good.
Now that we have wheels and tires, we're wrapping it up. We were going to go out to A.M.P. tuesday night, but it looks like rain. RTTC this weekend, so maybe we'll do final testing next week.
I like to carry 4 or 5 gal of air for an air ride truck. Seems like if you have any less, you get caught waighting for the compressors a lot. With the raised floor, there is some extra room for tanks, but we still want them hidden. I went with two 2gal. aluminum tanks. One on each side, the link together plumbed through the valve block. From under the truck you can see how the fit. From the wheel opening, they are visible, which I don't like. So, we made some covers out of 3/16" ABS plastic. It's strong, durable, and it soaks up noise. These bolted into the bed floor crossmember, and then to the bottom of the bedside via a small 'L' tab, and act as the fender brace.
Old 02-18-2013, 09:32 PM   #86
robnolimit
robnolimit's Avatar
Raising the floor also means raising the wheel tubs. This is easy. We bolt in the tubb to the floor with a few bolts, and then mark the new hole locations. Remove the tubb, and drill and install nut-zerts into the inner bedside. Then bolt the tubb back in. Up front we have RideTeck Shockwaves installed for the air ride. Out back all of the install is finished, note the small piece of fuel line around the air line. This works as a safety barrier for the air line. We use this trick anywhere the air lines can come into contact with an edge or rough surface.
Old 02-18-2013, 09:41 PM   #87
Rusbuilt
Rusbuilt's Avatar
Very nice!
Old 02-19-2013, 09:51 AM   #88
OTIS HURTS
Looks great
OTIS HURTS is offline   Reply With Quote
Old 02-19-2013, 10:08 AM   #89
aggie91
aggie91's Avatar
Looks Good. What air managment sustem did ya'll use on this one?
Karl
The LST Challenge:
Old 02-19-2013, 12:55 PM   #90
robnolimit
robnolimit's Avatar
We're using a RideTech E3 system. I like the memory 'on start' feature.
Old 02-21-2013, 01:01 PM   #91
robnolimit
robnolimit's Avatar
Here's a couple of teaser picts. The last hang up seems to be 5 lug axles for the rear. Back Order status. Here's a few teaser picts to hold you over. RTTC this weekend, check our facebook for some live updates and video. Also, check out "Are you Faster than a Redneck", friday night on Speed Channel.
The standard Wide ride front brake is 12", drilled /slotted. While not the true rolling stock, this is a look at the stance, a bit lower than RH at the moment. Full drop is another 1" down, at that point the drive shaft would rub the floor. We have bump-stops in place to stop that from happening.
Old 02-21-2013, 01:10 PM   #92
Rusbuilt
Rusbuilt's Avatar
Very nice sir! I love those breaks!
Old 02-21-2013, 01:14 PM   #93
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry, sorry, late for the party.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2013, 01:57 PM   #94
higXtech
higXtech's Avatar
wow looking awesome. I can't wait to drive the wheels off this. Being able to toss the keys to anyone and not worry about the air-ride system was important to me. I've had some sketchy setups in the past.. so the little things, like bumpstops are necessary. Im surprised those wheels tuck up in there. wow.
1968 fleetside - nolimit wide ride front and rear + ridetech
higXtech is offline   Reply With Quote
Old 02-21-2013, 08:30 PM   #95
duallyjams
duallyjams's Avatar
Hope to see your ride when it gets to the east coast.
James
IG duallyjams
Old 02-23-2013, 05:25 PM   #96
theastronaut
theastronaut's Avatar
Subscribing! I like the way you lifted the bed floor, very simple.
theastronaut is offline   Reply With Quote
Old 02-23-2013, 08:18 PM   #97
Low Elco
Want. Those slots. Truck looks great!
Low Elco is offline   Reply With Quote
Old 02-24-2013, 12:27 AM   #98
checoperez
i love it this truck!! c10s rules!!
checoperez is offline   Reply With Quote
Old 03-07-2013, 07:04 PM   #99
higXtech
higXtech's Avatar
I called the shop today to find out how things are going. Wish you guys the Best of luck at Goodguys this weekend.
Old 03-08-2013, 12:51 AM   #100
Hardesty454
Hardesty454's Avatar
this looks amazing.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
