01-30-2013, 10:35 AM | #76 | |||
Re: Project "Booger"
Im definitely bookmarking your response here to refer to when I do go shopping for body supplies. Thanks again!
__________________________________________ AmericanThunder Project Booger Build Thread |
01-30-2013, 10:43 AM | #77 |
Have had a hellacious week at work so not much has been getting done. Did manage to get some of the accessory brackets off the old motor. One for the a/c compressor doesnt fit due my intake manifold choice. Gonna require some modifications. Spent almost 3 hours cleaning up the power steering brackets once I figured out what was grease and what was an actual bracket!
Got the crank pulleys off and cleaned up as good as they'll get. Hope to shoot a little paint on the brackets and get them on the engine this week. The UPS guy did leave a present at my house yesterday: Its a little Hobart 130 but I should do what I need it to for this project. Now to sharpen my welding skills. Been staring at the hole where the CB antenna was...Any suggestions on how to fill that? Square it up and cut a fill piece then weld in place? Cant get at it from inside the cab.
01-30-2013, 12:41 PM | #78 |
Nice! I love my Hobart. Making the patches is pretty straight forward. You could square the hole out if you liked but you could also just make a round patch. Get the welder adjusted right on a test piece first then just zap, zap, zap around your patch. You might even try making a hole and patching that on your old fender first. I like to set mine on the hot side with plenty of wire speed. That way you can make a quick, hot zap. Go slow so you don't get your panel too hot. Zap, zap, pause, zap, zap..... You'll get it figured out in no time. You got an auto-darkening helmet right?
Get a flapper wheel for your grinder too. When you're done welding use the rock to knock it down about flush then use the flapper to really smooth it out.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
01-30-2013, 01:02 PM | #79 | |
01-30-2013, 02:29 PM | #80 |
I go to Adams auto body at prince and i10 its a little hole in the wall but great guys and good prices.
Posted via Mobile Device |
01-30-2013, 03:21 PM | #81 |
Thanks man I appreciate all the local info you've given me everyones been great and its appreciated! Off topic...What app are you using for this forum?
01-30-2013, 04:03 PM | #82 |
I just use the browser on my phone as far as i know there is no app
01-30-2013, 04:19 PM | #83 |
I've been doing my sheetmetal patches on #2 with wire speed a little under 50%. I'm running a 0.032" solid wire with an argonne blend tho. It'll probably be different with flux core.
01-30-2013, 04:32 PM | #84 |
For sheetmetal, use ESAB.023 easy grind and 75/25 argon/co2. Makes it nice, without a lot of warpage.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-30-2013, 04:35 PM | #85 |
01-30-2013, 06:42 PM | #86 |
I'm anxious to try that easy grind wire!
01-30-2013, 07:29 PM | #87 |
Ha, me too! I'm running .023, but it ain't easy grind!
02-05-2013, 10:12 AM | #88 |
Just wanted to drop in and update the thread but there isnt much to update. Seems the bug my boy had caught me and I was down for the count on Fri/Sat/Sun. I did manage to get all my accessory brackets blasted and painted over the weekend so I made progress? Yesterday I installed the previously mentioned brackets, water pump, and flexplate. I went to install the torque converter so I could mate the engine and trans and realized I didnt have any trans fluid which I swore I picked up already..Oh well this week I should make some progress! Hope everyones having a great week!
02-05-2013, 11:32 AM | #89 |
Ok, my system:
1. Repair rust 2. Bare metal all bad stuff. 3. If straight to paint, etch prime. If getting worked or anything else, system compatible epoxy primer. 4. Skim filler to taste with 80 on a block. Leave it a tad high. Don't take the last stroke! Believe me on this. 5. Slick sand/Featherfill G2 2 coats. 80 the first round, then recaot and 150 on a block with guide coat. always use a block. The 3m rub on guide stuff is expensive, but great. Do this till it's flat in a few strokes. 6. Re-shoot and block with 320. 7. wet-sand on a block with 400. Scuff in edges/corners with Scotchbrite. 8. Paint all interior stuff and jambs. 9. Loosely assemble truck. Gap doors. 10. Mask and paint all exterior at the same time if possible. 11. Bask in glory and female adoration. Drink beer. Sit on tailgate. Enjoy. Disclaimer: I probably left something important out. There is a more in depth guide in Sanborn's thread, somewhere in the middle. PS- glad you're over the flu!
02-07-2013, 10:34 AM | #90 | |
02-07-2013, 10:52 AM | #91 |
Mid Week Update:
Ok the engine/trans is "just about" ready to toss in because I still forgot to pick up a harmonic balancer! Last night I started to tear into figuring out why old boogs brakes arent working so well. I knew the rear passenger wheel cylinder was shot because I couldnt bleed that corner but when I took the drum off to replace the wheel cylinder and it appears to be missing several things. First dont these have automatic adjusters? I see the adjuster but shouldnt there be a self adjuster arm? Second the parking brake lever was just loose inside. The spring on the strut was in three pieces and it was only contacting the front pad and the parking brake arm? It appears someone was inside here at some point and failed miserably. Here are some pics: Im gonna hit napa after work today and try and figure out what parts Im missing. Any drum brake experts on here PLEASE chime in and direct me to what parts I need to get these things rebuilt and working. Thank you in advance!
02-07-2013, 11:45 PM | #92 |
Rear Brakes are done and actually work Now onto the fronts..Thought I would just get the front ones rebuilt but now Im back to the old "should I convert to disk brakes?"
02-08-2013, 10:13 AM | #93 |
Got the fronts apart last night...They seem to be missing the self adjuster arm too..Guess I am finding out why the brakes didnt work? Pads and drums in alot better condition then the back ones though. Thinking if I stick with drums I'll just have them turned, new set of pads and get the adjuster hardware after cleaning everything up.
02-08-2013, 11:21 AM | #94 |
Wow, that's impressively bad brake work! Glad you got it straightened out. Remember, "Big On Back!"
02-08-2013, 08:34 PM | #95 |
In the long hawl, you would be better off to convert to disk brakes in the front. I went to the bone yard and found a 72 truck and took the front and rear end and put in on my 67 frame. I am glad I did. Yes it cost more but when you do a brake job it is a lot faster and it will stop a lot better. that Is mu opion
02-09-2013, 12:59 AM | #96 | |
Got the fronts done...Ended up just buying everything new. Cost was under a hundered bucks so I said the hell with it. Probably end up converting to disk later on but for now at least I know I have brakes Time to wash the hands and hit the rack...
02-09-2013, 09:21 PM | #97 |
Hey Shon just want to say thanks again for hooking me up with your old motor I took it apart and it looks better alot better than the other one.
And your truck looks great in person proably one of the cleanest cabs i've ever seen almost zero rust! |
02-10-2013, 01:00 AM | #98 |
You are kickin some butt on Booger, I love the mock up engine. Wish I could find a cardboard engine.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-10-2013, 11:46 AM | #99 |
Nice work on the brakes. Hardware kits are chump-change when you've got a wreck like that. Amazing that people would stumble through a brake job, knowing it prolly ain't right and still run it down the road.
02-11-2013, 10:44 AM | #100 | ||
Hey James thats good news! I spent the day working on that cab yesterday and can't move my arms this morning...still seems like an awful lot of work to me!
