Old 02-04-2013, 02:07 AM   #76
Mike Bradbury
Mike Bradbury's Avatar
Re: Totally disgusted - flat cam
Crower makes some really nice one piece chromoly push rods, I installed them after four of the sixteen lobes were flat in my 14,000 mile GM crate motor. Moved to a Crower full roller system. They say you can gain as much as 25 HP just from the lack of friction in a roller set up.
I would install a mag plug for sure
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 02-04-2013, 02:15 AM   #77
BigRed76
BigRed76's Avatar
I agree with Eddie H. If you ran a quality oil filter then it should've trapped most of the crap from that pushrod.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-04-2013, 06:56 AM   #78
Scotty-D
Scotty-D's Avatar
IMO, you are not out of the woods yet. I've seen that happen before, and every single time it was from a lobe going down and allowing the rocker arm to beat the pushrod into submission. It generally bends the crap out of the pushrod when it does it, but I have seen it both ways.
Sorry if I missed it, but have you pulled the oil filter off yet and cut it in half? I'd be very interested to see what you have collected in there.
85 Scottsdale LWB
383 227/235 105 lsa Howards Roller
TH350 by Jakes Performance, Sanger TX
Scotty-D is offline   Reply With Quote
Old 02-04-2013, 08:26 AM   #79
burnin oil
Sorry about the bad luck. Low zinc is definatley a problem but it can not be as bad as we blame it for. I would rather had higher zinc content but the fact is every day there are flat tappet cams installed by the factory today with little to know cam issues. Every single Dodge truck running around with a Cummins diesel engine is a flat tappet. This fact tells me that it is the cam cores that are the issue and not the oil. If I were running a high lift cam with fast accelerating ramps with massive spring pressure then a zinc additive would be a safe investment. On a cam with mild ramps and spring pressure you should be just fine with regular oil.
burnin oil is offline   Reply With Quote
Old 02-04-2013, 11:52 AM   #80
Eddie H.
Eddie H.'s Avatar
If it were mine, I'd probably go ahead and pull the cam out and inspect it closely, just to make sure.
While I had it out, I would throw it, and everything else that came out of a Comp Cams box in the trash, and go back with some good parts.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-04-2013, 03:57 PM   #81
storm9c1
*** That's interesting ***
storm9c1's Avatar
This is a can of worms. That being said, using the Cummins comparision is like comparing apples to oranges. First of all, last I looked, official Cummins spec diesel oil does call for higher ZDDP (but that was a while back). Secondly, Cummins designs the engine from scratch knowing what kind of protection modern oils provide. An OEM is going to pay more attention to reliability than any run-of-the-mill aftermarket cam provider. Diesels also use a different valve geometry. Interestingly, there are high performance upgrades for the Cummins that include roller cams. I have heard of people ending up with flat cams in their Cummins with aftermarket parts. However, the OEM setup is bulletproof as long as you run the oil spec they recommend.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-04-2013, 09:22 PM   #82
burnin oil
Flat cams are not a major concern. We actually snap them from the injection pumps more often. PPumps rob power like a 671 huffer. Sure there are some differences but the point was that flat tappets are still around on a motor designed in the 80s with no real redesign other than upgrading the head to 24v. The 6.7 is like the 400sb Chevy, some minor differences to make more cubes but still the same engine family. Cummins recommends premium blue by Valvoline oil but by no means do you need to run it. No problems with any of the other major brands. They are more concerned by which oil filter you run (Not Fram). I actually broke an oil pump at 4k+ RPM (and 75 PSI boost) and the cam still didn't go flat. Modern oil still can do its job, even on a quality after market cam. I would still prefer more zinc. Any and all lube enhancement is a good thing but we have what we have. Interestingly I have seen as many failures running Schaffers race oil as regular over the counter oils.
Old 02-09-2013, 10:48 AM   #83
Horsman
Horsman's Avatar
Call me nuts, but I went ahead and pulled the engine so I can tear it down for inspection. The metal chunks worried me enough to do so. Thanks for the insight guys, great lesson learned here.
Jeff Horsman
1972 C20 Highlander "C"
1966 Olds 442 L69 four speed
1971 Skylark (GS clone racecar) 494 stroker
1986 Buick T-Type
Horsman is offline   Reply With Quote
Old 02-09-2013, 11:47 AM   #84
Scotty-D
Scotty-D's Avatar
Shoot...I ain't calling you crazy. That's the only way you will ever know exactly what is going on with it. Good call and good luck.
85 Scottsdale LWB
Old 02-10-2013, 12:10 PM   #85
edge
edge's Avatar
Smart move. Good luck.
edge is offline   Reply With Quote
Old 02-10-2013, 02:11 PM   #86
'63GENIII
'63GENIII's Avatar
You'll sleep better after knowing exactly what's in there. You going with a different cam now?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-11-2013, 12:34 AM   #87
1970 CST STEP
Red face Re: Totally disgusted - flat cam
Very smart move. Really sucks what you have to go through. I've got a 286h in a 468 with less than 200 miles and no problems yet and no zinc added to oil. Pennzoil 10-30. a couple months ago, I went into shop, smelled a really strong odor of gas, looked around, and followed my nose straight to my truck with the brand new engine, looked under truck and gas was everywhere! Crawled under it and looked, had gas flowing out of oil pan at the bottom of dipstick! Gas tank was not venting and was passing through fuel pump. Pulled drain pan plug, first gallon was pure gas, then oil. Drained, changed filter, filled with oil, fired it up, ran for a few minutes, drained and filled again. Haven't had any problems so far, but man, the feeling in your gut is like no other!
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 02-11-2013, 12:49 AM   #88
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Here is the result of metal in motor even with a good wix filter. You are smart in not taking the chance. It's like the old saying "an ounce of prevention is worth 2 birds in the bush".....or something like that. lol
I about sheet at how much metal still made it through my motor even after changing the filter 2 times in about 10 miles. Like the wedding ring on my rod bearing?
prostreetC-10 is offline   Reply With Quote
