Old 02-19-2013, 09:14 AM   #76
Rusbuilt
Rusbuilt's Avatar
Re: Project "Grandpa gets a transplant"
Lol thats a big rat
Rusbuilt is offline   Reply With Quote
Old 02-19-2013, 10:51 AM   #77
67cheby
67cheby
67cheby's Avatar
great progress !
67cheby is offline   Reply With Quote
Old 02-19-2013, 07:54 PM   #78
Bhelton
Bhelton's Avatar
Looks like a mouse under the wiper!!
Bhelton is offline   Reply With Quote
Old 02-19-2013, 11:27 PM   #79
biohazardbill
well aired it up today and then shut down the power to see if the lines would hold the air.... i have a small leak on the right front line somewhere... wish there was an easier way to get to the front bag fittings... ah well, will diagnose when i swap the control arms out.
biohazardbill is offline   Reply With Quote
Old 02-27-2013, 11:10 AM   #80
biohazardbill
Well with the weather and waiting on parts and then also waiting on parts to be powder coated havent been able to get a ton done. So what happens I buy another rig lol....
Ah well...
While waiting for stuff and weather to clear decided to tackle the gauge cluster. The original had only the 3 window cluster and I knew that would not work. Since I wanted to keep the old grandpa look decided to grab a used 7 window bezel
I wanted a RPM guage. There were kits to add it to this existing bezel however decided to go a little different route. Most people that put in aftermarket gauges replace all of them. I left the two 5" gauges alone to keep the stock appearance. This being said it retained the original glass.
Hopefully I get parts back from the powder coater today to get some more work done on the truck itself.
Old 02-27-2013, 12:12 PM   #81
bigguy69
dazed and confused
bigguy69's Avatar
What size and style of gauges are you using?
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-27-2013, 12:18 PM   #82
biohazardbill
Gauges are Autometer Pro Comp line. Small holes are 2 5/8" and middle hole is 3 3/8".
Old 02-27-2013, 12:52 PM   #83
Fattback
Fattback's Avatar
Great build!!! Subscribed
Rob
Fattback is offline   Reply With Quote
Old 02-28-2013, 09:15 PM   #84
biohazardbill
Well got my powdercoated parts back today...
Here is the starting point...
bottom of the motor crade is 3.5 inches off the deck
Got the passenger side done tonight however ran out of light for drivers side. The whole time I was hoping it would make a signifigant difference.
I didnt get any pics of the passenger side being done due to it being dark. However i fully aired out the driver's side and the tire sat 3.5 inches below the fender ( i dont have inners on at the moment). When I aired out the passenger side it is stopped by the fender so that means these a-arms will allow at least 3.5 inches of drop. The tires currently on it are too wide and I knew that going into it. So once the driver side is dont I imagine the front crossmember will be touching the ground.
Old 02-28-2013, 09:35 PM   #85
hilljob26
hilljob26's Avatar
that tach looks awesome in there..build is coming along nicely
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-28-2013, 10:37 PM   #86
twangismythang
twangismythang's Avatar
Cant wait to see it with the new wheels......
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 03-01-2013, 01:25 AM   #87
67ctener
67ctener's Avatar
I'm pretty jealous you can DRIVE to summit
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 03-01-2013, 12:25 PM   #88
biohazardbill
More done this morning, that is all for today though as I have to do some real work to pay the bills.
Final stance basically, keep in mind the wheels/tires are changing.
The front is as low as I can go with this wheel/tire combo and still roll.
The rake is a little more than I would like at the moment. The tires are 29" in the pic so that will come down a bit when I change them. Thinking about using shorter bumpstops to gain a little more drop in the rear.
Hopefully will fire this bad boy up tomorrow.
Old 03-01-2013, 12:42 PM   #89
Rusbuilt
Rusbuilt's Avatar
Much better! I love seeing the crossmember less than 1 inch off the ground! Nice work sir!
Old 03-01-2013, 01:39 PM   #90
Fattback
Fattback's Avatar
Looks great
My A arms are on order can't wait to get them
Rob
Old 03-01-2013, 01:40 PM   #91
67cheby
67cheby
67cheby's Avatar
nice, it looks great man !
Old 03-01-2013, 11:58 PM   #92
Jimbabwe
Jimbabwe's Avatar
Looks great!
Jimbabwe is offline   Reply With Quote
Old 03-01-2013, 11:58 PM   #93
Jimbabwe
Jimbabwe's Avatar
Oh, yeah...#TeamStepside !!!
Old 03-02-2013, 01:53 PM   #94
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Awesome work!
i have the same issues, i have a c notch and the rake constantly bugs me, keep wondering if i am gonna change it later to a step notch to level it out.
Do you think the front is gonna have to come up a bit once the wheel wells are in?
smoknbarrels is offline   Reply With Quote
Old 03-14-2013, 04:32 PM   #95
biohazardbill
Alright guys, havent forgot about ya...
Few things stood in the way of real progress. Looking at the rot under the battery tray I was going to just weld in a small fix, however under closer looks it was really into the radiator support mount so off to Summit again. They had core support and inner fenders in stock. Core support is in, not too much trouble. Have yet to stick in the new inner fenders.
So I have also removed any wires from the wire harness that waill not be used and figured out which wires I can use for the aftermarket gauges.
Started to put the radiator in and had some issues finding fans that would work. The radiator is a stock brand new 4 core. The fins are 2" from the center of the water pump pulley, but afterr a ton of measuring and tweaking I was able to fit two 14" fans for a total of 6000 cfm cooling...
Bad pics as they were taken at night
Another thing I had to change was the routing of the front air lines
Originally I had the air lines port through under the motor mount
However after doing an overnight leak test and finding a leak, to correct the issue I had to remove the header. Figuring if I broke down and had an issue that would be a pain
if not impossible to fix on the side of the road.
So I cut a slot in the frame and a 1" hole on the back side of the crossmember under the frame. Wrapped the air line in some 3/8 fuel line, stuck a grommet in and BAM...
Just need to secure the slack up a bit then will be done. Passenger side is done, doing the same to the driver side tomorrow then hopefully Saturday I can work on firing this up.
Wheels and tires completely done now. Will put on the fronts tomorrow too to see how they fit. Should be fine if I did my measuring correctly.
Old 03-15-2013, 06:59 PM   #96
biohazardbill
Got the driver side line rerouted today... test fit the new wheels.
The rear is still a little high still but those are 29" tires and I am going to swap out the existing bumpstops.... maybe remove them completely.
The front i can set the crossmember on the ground howver the inner fenders put a little pressure on the tires.
Old 03-15-2013, 07:08 PM   #97
PBFAB.COM
PBFAB.COM's Avatar
Looks awesome Bill! Can't wait to see it with the bed set back on it!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-15-2013, 07:12 PM   #98
Jimbabwe
Jimbabwe's Avatar
Wheels look great. What were the caps from?
Old 03-15-2013, 07:21 PM   #99
biohazardbill
Caps are from Wheel Vintiques. I bought them when I bought the wheels.
Link to Wheel Caps
Thanks Nate/Dave whichever you are..... but you have to say it looks great since its your rear notch and control arms lol
Old 03-15-2013, 09:07 PM   #100
Rusbuilt
Rusbuilt's Avatar
Wow! Looks awesome!
