03-02-2013, 01:52 AM | #76 |
Re: 1972 one ton for parts
I am interested in the housing so pictures would be nice. Thanks
03-02-2013, 12:01 PM | #77 |
washer res 89104
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson |
03-03-2013, 07:08 PM | #78 |
couple a/c housing pics.
my1st69- sorry, washer res was cracked. |
03-03-2013, 09:16 PM | #79 |
thanks for checking. I am right now in the process of removing the cab and I am have trouble figuring out how to remove my shifter from the trans. pulling the last of the bolts now( the four main cab) I'll chekc back when finished thanks southern parts again and anyone else who can assist with my issue
03-04-2013, 12:15 AM | #80 |
Thanks for the pictures of the AC housing. What is the total price with shipping to 99224. Thanks!
03-04-2013, 01:03 AM | #81 |
Power steering pump brackets still available?
Thanks Rob |
03-04-2013, 02:52 AM | #82 |
do you have the spring clip beneath the steering wheel removal bolt that retains the steering nuckle
03-04-2013, 07:06 AM | #83 |
looking for a rebuildable rag joint or good one. Need the larger shaft style
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-04-2013, 10:03 AM | #84 |
does the jack bag have the jack assembly inside?
Reed |
03-04-2013, 03:22 PM | #85 |
eddie wickward- it may take me a day or two to get a total for you.
fattback- this truck had the wrong setup on it (long water pump) $10 plus shipping if you want those brackets. I also have the correct setup (short water pump) $50 plus shipping. my1st69- not sure i understand what your looking for, can you post a pic of the part or where it goes? jjzepplin- i have some like chevelle and camaro use 1" on the column side, 3/4" on the sector side. $35 plus shipping rcm1958- i only have the bag, no handle or lug wrench. |
03-04-2013, 05:01 PM | #86 |
My 350 is short water pump. Can you post pics plz.
Thanks Rob Posted via Mobile Device |
03-04-2013, 06:05 PM | #87 |
Hi,
I could use the core brake booster w/brackets. I would need the all the brackets and linkage, rods, I am looking to add PB to a truck w/o it. If they are still available could you ship to 01702? Thanks! |
03-04-2013, 07:15 PM | #88 |
pic for fattback- both type brackets for short w.p. either set the same price.
03-04-2013, 11:26 PM | #89 |
pic for 71proj
03-15-2013, 10:28 PM | #90 |
Hi southern parts,
Received the booster, the back ring must have been broken during shipping...just a bunch of shattered pieces...no worries it was probably going to be a core. But it would have been nice to try it out. I was wondering if you had the bracket that held the proportion valve in place? Please let me know...Thanks! Posted via Mobile Device |
03-17-2013, 12:15 PM | #91 |
Do you still have the radio delete?
My K20 build http://67-72chevytrucks.com/vboard/s...d.php?t=538539 |
03-17-2013, 05:03 PM | #92 | |
04-23-2014, 01:57 AM | #93 |
Do you still have this truck for parts?
04-23-2014, 05:40 AM | #94 |
i might have a few pieces from it , but the truck has been sent to scrap. what part are you looking for?
04-23-2014, 10:03 AM | #95 |
I'm interested in the frame
04-23-2014, 10:38 AM | #96 |
I am in line for the OEM jack/tool bag if still available. LMK
Thank you, Bruce |
05-28-2014, 04:18 PM | #97 |
I'd like the radio delete please.
05-28-2014, 10:33 PM | #98 |
radio delete was sold last year.
05-29-2014, 08:59 PM | #99 |
I'm in north Ga. Is the cab any good don't need perfect just build able thanks travis 770 310-0530
