Old 01-27-2014, 11:39 AM   #76
xpickup
xpickup's Avatar
Re: '52 Rot-box Turned Tire Roaster.
Wybrow, nice job. Love the back half. So smooth looking.
Shannon
xpickup is offline   Reply With Quote
Old 01-28-2014, 04:29 PM   #77
skip99
skip99's Avatar
Love it, great job on fab work..what are you using for the bushings on the ends of the links at the crossmember? Is the 4 link itself stiff enough to keep the rear from swinging side to side? Or will there be some sort of panhard .? Bar for side yo side deflection?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 01-28-2014, 08:31 PM   #78
99 to Life
99 to Life's Avatar
might I chime in, I think this set up is def beefy enough. Check out what some companies are selling, this is by far strong enough. Pan hard is only needed on parallel 4 link or 2 links, this is a triangulated 4 link so a pan hard isn't necessary.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-30-2014, 02:07 PM   #79
yawdie1
yawdie1's Avatar
Still awesome!! I still want that back half for my truck! good work
1950 chevy PU work in progress.
yawdie1 is offline   Reply With Quote
Old 01-30-2014, 10:21 PM   #80
Wybrow
What 99 to Life said. I run almost an identical 4-link on my S10 (much more basic, but built off the same principal) and I can literally only fit a credit card between my tire and the bed side (and it's rolled flat) and I have painted tire lettering, of which the paint never gets rubbed off, and I corner hard frequently.
We ran out of room on the '52 and could only pull off 28 degrees for each bar. I figure that will still be lots, this definitely isn't going to be a corner carver by any means.
Hi, fellas. Got a lot done on the weekend but I have been entirely too busy and tired every night since to update this thread. Sorry! Anyways, I chipped away at the welding spatter on the rear end on... Monday (I think) and installed the rear end. For the first time ever, the truck laid-out Monday on tires that are about 3" smaller diameter front and rear than what I will be running.
I am ****ing stoked.
Last night I went out for a couple hours and finally got that god-awful factory crossmember knocked out for good. Then I got curious and sat down and did the math on how much original frame is left, keep in mind I added in all 5 Crossmembers that were removed. I have 21% of the original frame left. Yeah, that's it.
Ignore the bolts, I have a bunch we use for building the link bars and stuff, I'll be replacing them all with stainless button-head bolts.
Also scored a set of drop spindles for an S10 this week for $80, which in the world of drop spindles is CHEAP. They'll allow me to run a higher air pressure in the front while still riding super low, which is the best of both worlds and exactly how I like it. I didn't take a picture of them, they aren't exciting.
NOW, for the really exciting news. Over the last few weeks I had some **** luck, my winter beater (a 2004 Grand Am my mom bought new and replaced last fall with a 2013 Cruze) **** the differential out in the transmission. I decided it was time to get a fullsize truck for a daily, I am pretty sick of continually borrowing one of my friends to tow a trailer, etc and I think they are too. After browsing the used ads I found nothing but junk. I started pricing out new ones expecting to get my hopes up and not be able to afford one/be declined by the bank, etc. Well, long story short, I just ordered a 2014 GMC Sierra "Double Cab" 4x4 completely loaded with a 6.2L v8 and 3.73's to boot.
8-10 weeks will take FOREVER to show up. However, I'll have new suspension and some other goodies sitting waiting for it to show up. This is the height it will sit.
Mine is all black and a Sierra, so really, only pay attention to the height. Haha.
Next, 99 to life mentioned our bench/fab area and I decided to share. We built the bench when we moved in. It measures 18'x3' deep. Honestly, not sure how tall. It is built entirely out of 2x2x1/4 wall tubing, with 1/4 gussets and a 3/8" sheetmetal top. It is heavy as **** and no matter how hard you're reafing on something in the vice it does not budge. I love it.
All the attachments on the bench are actually drilled and tapped into the bench top, we are planning to build a few different sets of control arm jigs for the bench and also a sheet-metal brake.
We built these two rooms also when we moved in, the one on the right side houses the compressor (which is wired, but still not plumbed 6 months later :rofl) and my laptop for music to the stereo upstairs. The room on the left is the "engine closet". It's a safe spot for our engines and stands to sit clear of dust and grinding debris.
There are three different welders in the shop, a Miller 180SD TIG machine, a ThermalArc 220V MIG and a Lincoln Electric 120V MIG, we can pretty much make anything stick together. There's also a King vertical and horizontal combo bandsaw under the bench, it gets used a lot.
I think that's it, you guys got a little mini-tour, sorry about all the pictures. More to come this weekend.
Wybrow is offline   Reply With Quote
Old 01-31-2014, 01:29 PM   #81
Kabwe
Certified Car Nut
Kabwe's Avatar
Great build, wonder craftsmanship. I really enjoyed going through your build thread.
Kabwe is offline   Reply With Quote
Old 02-02-2014, 07:04 AM   #82
Wybrow
Thanks, man!
We kinda ran out of material so tonight I got anxious and decided to half-ass throw the body on. It was beyond motivated, even though I haven't lost any motivation, this helped a lot. Probably going to leave it look like this for the week and tear it back down next weekend and finish the back-half.
The bed is sitting on the axle and a single jack-stand holds up the front, the front panel is bent all to rat **** so I have no idea how close the bed is to being where it's supposed to be, but it looks kinda right. There's a swap meet local to me this coming weekend, and I've found a set of southern running boards for sale that I'm picking up on the way next weekend.
Overwhelmed with how far this truck has come in the three short months we've been working on it.
Old 02-02-2014, 12:32 PM   #83
oldman3
oldman3's Avatar
Looks sweet...Jim
oldman3 is offline   Reply With Quote
Old 02-02-2014, 09:02 PM   #84
ghettoluxury
ghettoluxury's Avatar
Looks killer! You guys are doing some very nice work.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-24-2014, 10:40 PM   #85
Wybrow
So, hey! I haven't updated in a while due to some laptop issues but we've been working just as hard.
The body is back off the truck, and we've pretty well got the back-half finished up suspension wise. The 4-link was done previous to the body pictures. The next step was to set out and get the upper bag brackets placed and welded in for good. We didn't really have a plan until we started and just kinda went with it...
We used a piece of 2x4 bolted to the upper and lower bag plate to simulate the air bag at "zero psi". RE7's squish to 2.9" at zero psi, but I fully intend to drive this thing as low as physically possible, so we added an extra inch to allow a higher air pressure at the same ride height to firm up the suspension. Same sorta idea I had going with the drop spindles in the front.
The first night, we got this far, these bars run parallel with the upper link bars, and from the back of the crossmember they all look solid mounted.
We had planned to run a bar up over the top of the link bars and tie it all in to the bag mounts. We measured it up the Friday night and then built it Saturday night. As soon as it was tacked in, we all didn't like it. Couldn't all agree on tube placement and decided to scrap it.
So, we went home, I believe at 10:30am Sunday morning after a long night of staring and thinking.
As always, one of us came up with a plan even before we all got home. This is what Dave came up with, I love it. The outside bars (even though you can't really tell in the pictures) are parallel with the lower link bars and the frame rails.
I honestly couldn't be happier with the outcome. I haven't uploaded the newest set of pictures yet, but we've had bags in it and everything is fully welded. I've got the frame torn down now and have spent lots of time blending in everything for good.
Until the next update!
Old 02-24-2014, 11:41 PM   #86
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Amazing fab work man, Looks killer.
--Josh
Old 02-24-2014, 11:49 PM   #87
99 to Life
99 to Life's Avatar
Looks cool, great job.
Old 02-25-2014, 12:25 AM   #88
oldman3
oldman3's Avatar
Very nice work...Jim
Old 10-31-2014, 09:13 AM   #89
mr incredible
mr incredible's Avatar
anything new update?
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 10-31-2014, 11:53 AM   #90
99 to Life
99 to Life's Avatar
I been wondering the same thing
Old 11-09-2014, 04:41 PM   #91
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Ok ?
Whats up........
johnnyclack is offline   Reply With Quote
Old 06-15-2015, 11:07 PM   #92
Wybrow
Boy oh boy, I haven't updated this in a long, long time. Thrilled to say the truck was in it's very first invite-only indoor car show... well over a year ago. It has been the best weekend I've had with the truck to date. Unfortunately, after that show it has more or less not been touched since.
Here's a handful of pictures from MegaSpeed and one how the truck currently sits. The body is going to get blasted this week, then I am going hard on metal working the cab. Consider this my unofficial round two.
Old 06-21-2015, 08:17 AM   #93
ghettoluxury
I'm glad to see you are getting back at it. This is an awesome build and you guys are cranking out some nice work.
Old 06-21-2015, 09:40 AM   #94
oldman3
oldman3's Avatar
Glad to see you back...Jim
Old 06-21-2015, 11:20 AM   #95
99 to Life
99 to Life's Avatar
Iv wondered about this build. Glad to see it back. Good luck with the metal work. I always enjoy seeing that.
Old 06-21-2015, 12:40 PM   #96
Trixxterr
Looks good. Can't wait to see the finished product.
Trixxterr is offline   Reply With Quote
Old 08-11-2015, 10:09 PM   #97
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hey Wybrow,
I'm usually on the 60-66 forum, but I noticed you're nearby so I came over to check out your build.
Nice work! I really like seeing clean fab work. I'll follow along to see how things finish up.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
