Old 02-25-2013, 06:10 PM   #76
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: PS bracket issue on '71
Are you going to drill and tap the crank?
Keith
Convert to disc brakes.
Old 02-25-2013, 06:39 PM   #77
Malamute
Malamute's Avatar
No, I don't plan to. My biggest concern is room without pulling the radiator and grill. A friend of mine says he did one before and put it in the oven at 150 and then hit the center with a little heat when tapping it on.
I just want to be very careful with heat as I don't want to damage the rubber in between the inner and outer portions.
Malamute is offline   Reply With Quote
Old 03-02-2013, 05:58 PM   #78
Malamute
Malamute's Avatar
Well, not enough room. Got it half way on and that was that. I ended up pulling the radiator to get more room.
Has anyone ever installed one of these HB's that isn't tapped for a center bolt? I think I'm going to need a socket that is about 2" in diameter which is what I'll hit instead of hitting the balancer directly.
I had it heated to 170 for 30 min and put some oil on the crankshaft and still no go. I've never done this before so I don't want to force it and create a bigger problem.
Any advice from the peanut gallery?
Old 03-02-2013, 07:41 PM   #79
Andy4639
Old member
Andy4639's Avatar
Talking Re: PS bracket issue on '71
I always used a block of wood but the V-8 all have been drilled and tapped so I could pull them up with a impact.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-02-2013, 08:05 PM   #80
Malamute
Malamute's Avatar
We wouldn't be having this dialogue if there was a damn crank bolt!
Old 03-03-2013, 03:39 PM   #81
Malamute
Malamute's Avatar
Change of plans. I feel like I'm going to damage something trying to get it on. My friend is bringing his taps over and we're going to drill and tap it. Would do it today but it's my wife's birthday so it looks like I'll finally have it next weekend.
Old 03-03-2013, 03:59 PM   #82
lolife99
lolife99's Avatar
Good deal.
Use a balancer installation tool and you will be fine.
Fully engaged threads in the crank,... work much better than trying to pull it on with a bolt.
(Too much of a chance of stripping your newly tapped threads, with just a bolt)
Keith
Old 03-03-2013, 04:08 PM   #83
Malamute
Malamute's Avatar
Good deal.
Thanks. I have the removal and installation tools so I should be good to go. Just need to find a crank bolt since it didn't come with one. Hopefully my local store has one. I know it's a 7/16" - 20.
Old 03-04-2013, 12:37 PM   #84
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Let us know how it works out.
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 03-17-2013, 08:41 PM   #85
Malamute
Malamute's Avatar
She's alive! Drilling and tapping the crank was the best way to go, it slid on there like nothing. I'm going to enjoy it for a while before I tackle the PS install and possibly a booster for the brakes.
Thanks for the input everyone, it really was helpful.
Old 03-17-2013, 09:24 PM   #86
lolife99
lolife99's Avatar
Congrats!
So is your pulley alignment better now?
Keith
Old 03-17-2013, 09:34 PM   #87
Malamute
Malamute's Avatar
Congrats!
Yes, right back where it should be. If anything the alt pulley is off by 1/4" when compared to the crank and fan but it should be just fine. I let it idle for 10 minutes and nothing. I will be careful and stay close to home for the first few drives.
