05-18-2013, 12:57 PM | #76 |
Re: 1970 project/ DD "instant death"
Maybe if you had at least used new steel?
Old rusty diamond plate and 55 gallon drum scraps just seem a little unsafe for something as important for saftey. Plus it looks like the sides where you cut all the support away are kinda thin. If they fail it's not your life that worries me. It's the family returning from the mall with grandma that you happen to crash into causing "instant death" This just looks a little sketchy. But otherwise, great work! One more thing.....Please consider a short bed conversion. Your friends and neighbours will thank you.
05-18-2013, 01:43 PM | #77 |
The dimond plate looks worse in the pics, it's actually not that old
It's scraps from the s10 I bagged not long ago It's 1/4" steel so it's plenty If it was any thicker I would be just putting more work into it The shortbed conversion is out of the question To me there's nothing like a bagged longbed, they just look so much better layedout And thank you Posted via Mobile Device
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
05-18-2013, 05:28 PM | #78 |
Got them cleane up and painted
Will drill the hole for the bag and drain holes when I bolt them in Posted via Mobile Device
05-18-2013, 06:19 PM | #79 | |
Good fab work man. |
05-18-2013, 06:34 PM | #80 |
Thats cool.
That spot where your cup is open closer to the bushing is where I was talking about T metal is thin/narrow in that area. Would hate to see it bend or even worse fail alltogether. Have you considered a frame Z? I just compleated one and it really is not hard to do. Has many advantages over what you are doing here. You are going to find that your lower arms are going to be dragging scraping all the time. With a Z you avoid this plus you raise your trans, exhaust and you can even center the wheel if you want. Plus your not cutting suspention parts which should awalys be avoided. Just a little advice from someone whos been there.
05-18-2013, 06:49 PM | #81 |
im doing a bodydrop still
evryone forgets that its a daily driver. to top it off i live in appartments all my work is either done on the side like these lca's and ho i did my notch i try not to park it for more than a day so it makes it even more of a challenge ive bagged two of these trucks and both layed rocker. i would love to z it but my time and space dont meet the requirerments all my side work is based out of my truck and i do more of mobile fabrication granted im still a kid in most eyes but i have much more knowledge then im given credit for. as for the lca's they will be plenty strong, i know i didnt completly box in the back part of the control arm but you learn alot about stregnth when working on trophy trucks and rock crawlers theres more than enough like i always say "bolts are for people that dont trust their own fabrication skills" not trying to be rude, its just how i say stuff
05-18-2013, 06:50 PM | #82 |
AMEN!
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
05-20-2013, 05:48 PM | #83 | |
Pic of the rim with no hub cap and the inside of the hubcap and you can kinda see the lip You can see mid way on the rim that there is three nubs The hubcap stretches over it Posted via Mobile Device
05-20-2013, 05:50 PM | #84 |
Also got some updates....
Got the lca's all bolted in Posted via Mobile Device
05-20-2013, 10:18 PM | #85 |
Thanks for the pics, they clear it up for me in my head. Keep up the good work.
05-21-2013, 05:27 PM | #86 |
took some pics of the lca's bolted in and aired out
and some other issues im going to clear in the next couple weeks carrier bearing crossmember is hitting so thats next to go exhaust is scraping on just about everything lol need to get some more 3/8 dot line so i can bolt in my pie cut ucs's to get an inch or two lower because the balljoints are maxed out when lowered all the way
05-25-2013, 02:07 AM | #87 |
What do you think, patina?
And since I bolted in the lca's I've yet to take a pic of it aired out in the front and rear Posted via Mobile Device
05-25-2013, 07:39 PM | #88 |
Looks good!!!!
06-08-2013, 06:48 PM | #89 |
great work so far man!!! keep it up
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
06-10-2013, 09:31 PM | #90 |
VA72C10
Missed this build on here man...I'll follow along here now since I'm on here more
Looking for a 67-72 swb or blazer project in or around VA. |
06-11-2013, 12:51 AM | #91 |
Been super busy lately
Doing a lot of side stuff Cupping a set of lca's for a fellow forum member Fixing the front end of a family members avalanche that tboned a car And trying to get my 84 k-5 in running order 961,000 original miles! Going to be working on tonneau cover pritty soon Will be something different that I haven't seen or heard of before Posted via Mobile Device
06-20-2013, 11:44 AM | #92 |
anyone have a extra 6 lug steelie??
i want to have an extra as a spare and show piece to mount in the bed already got an extra hub cap and tire now i just need the wheel
06-20-2013, 04:29 PM | #93 |
not my year truck but im enjoying this thread. great fab work. I only wish i knew a fraction of what you can do. Im determined to learn to weld. That being said those HF cheap welders like the 70a arc welder or the 90a flux wire, would those be ok to learn on? and with one of those would i be able to do anything sturdy enough to my truck where i dont kill a family of four on their way back from the mall as one of my welds breaks? just sayin'
06-20-2013, 07:02 PM | #94 | |
as for the welder and why i use it its also to prove that it can be done. please practice practice practice before you touch the truck. safety is a huge thing for me and i wouldnt put someone in danger of bad welds but it would be an excellent welder to learn with once you have it down i would invest in a nicer one im a full certified welder so i can make this piece of crap work just fine
06-21-2013, 12:26 AM | #95 |
I'm pretty sure my spare is a stock steelie ,I'll have to look tomorrow to be sure. You wouldn't happen to have another wheel such as a rally to swap for it would you? I will let you know if its got the nubs for caps tomorrow ,I know it is definitely a 15. Dan.
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go |
06-21-2013, 01:38 AM | #96 |
If a trade is good for you I will find one
I just want the steelie lol Ill check around I'm sure there's someone I know that has one for you Posted via Mobile Device
06-22-2013, 01:42 PM | #97 |
Yes my spare is a stock steelie with the nubs for caps . I just went under the truck to look. Dan.
06-25-2013, 01:53 AM | #98 | |
06-25-2013, 01:59 AM | #99 |
Of course when you ride low and the way your not suppose to things tend to break. My bar for my bridge in between the notches broke before the welds, do to a design flaw and using thin tubing.
Finally decided to bust out the 1 1/2" round chromoly Put a little twist to it but I like it Let me know what you guys think I did this in about an hour and I'm not so sure I'm done yet and might have some other things up my sleeves The bars do not touch but because its a higher strength steel it won't require being attached to each other Posted via Mobile Device
06-25-2013, 09:19 PM | #100 |
I love your build.. so much diy fab, its great. Wish you had a pick where the truck is slammed but even front and rear. Seems like the rear is always lower.. great work man.. really.
Eric (Evaded)
If I see a Zombie.. Im runnin it over with my Truck. |
