Old 03-07-2013, 10:20 PM   #76
meatwagon83
meatwagon83's Avatar
Re: for the dually guys....20" rims
now lets see the 058s!!
meatwagon83 is offline   Reply With Quote
Old 03-08-2013, 08:48 AM   #77
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Awesome! So the rear "interlock" is nothing more than a "hubcentric ring" to keep the inner and outer aligned, nice!
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 03-08-2013, 12:12 PM   #78
SCOTI
SCOTI's Avatar
Still bummed about the lack of tire choices for lowered 2wd guys.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-09-2013, 10:01 PM   #79
BHBurban
BHBurban's Avatar
In for lowered pics!
"94 Suburban '89 Dually '00 Tahoe 88 shortbox
BHBurban is offline   Reply With Quote
Old 03-10-2013, 02:19 AM   #80
Skunksmash
Skunksmash's Avatar
Originally Posted by JCampbell View Post
Just talked to Trevor over at T.W.A.T.
... What?! lol
Skunksmash is offline   Reply With Quote
Old 03-11-2013, 07:47 AM   #81
GCncsuHD
GCncsuHD's Avatar
Originally Posted by Skunksmash View Post
... What?! lol
Tennesee Wheel And Tire, horrible acronym planning
ΜΟΛΩΝ ΛΑΒΕ
Old 03-11-2013, 03:44 PM   #82
maxwheels
both rear wheel are 21" lip to lip, gap is 4.5" FYI
maxwheels is offline   Reply With Quote
Old 03-11-2013, 04:23 PM   #83
GCncsuHD
GCncsuHD's Avatar
Great info, you can kinda see the difference in offset, looks like the one on the left (floor) is the inner and the one on the right is the outer? Can you get a measurement from the inner mounting flange (where it will contact the hub) to both the very inner edge of the " inner rim" and to the very outer of the "outer rim"? That way we could compare how far in and out it will stick comparatively.
I would go as far to say with that room between the duals, it could easily accept 275-295", maybe even 305 rubber without rubbing between the duals.
ΜΟΛΩΝ ΛΑΒΕ
Old 03-11-2013, 05:07 PM   #84
maxwheels
I measured from the back of the inner to the lip of the outer, where the inner would sit flush to the hub out to the outer lip about 11.25"
Old 03-11-2013, 07:13 PM   #85
SCOTI
SCOTI's Avatar
Originally Posted by LOW1TON View Post
I heard these were coming out. So I am glad to see them. I have 22s on my black truck and love them but on my red truck I only have 17s and want bigger! These will fit right in perfect. I can still keep a decent size side wall for the crappy roads here in Tulsa. Only thing that will kill it for me is if you have to run a different size inside rear wheel. I think they all need to match. But that's just my opinion.
Since you've had your set-up done for a while on the square body, what do you consider your limit as far as weight capacity w/the 22's? Obviously they're not up to par for the full capacity a dually is capable of (they might squeak by, but everyone know's 22" tires are not optimal in a HD app).
I'm just curious where people draw the line for safety concerns. I'm on the fence.... I sure would like some 20's on mine (22's have too short of a sidewall for my personal taste & I would want to get the 4 equal width/size rears which is also a must for me). Since my main cargo will prob be just the open car trailer I have loaded w/a swb truck, I feel comfortable but it makes me wonder how others view the scenario.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2013, 06:36 PM   #86
JCampbell
Bump, since these have now started hitting the streets in limited numbers.
Anybody got a set yet?
JCampbell is offline   Reply With Quote
Old 06-15-2013, 10:13 PM   #87
JCampbell
Bump.
Old 06-16-2013, 02:25 AM   #88
meatwagon83
bump, im still broke!
"DON'T TOUCH THE TRIM!!"-Early Kyler
Old 06-23-2013, 03:34 PM   #89
LOW1TON
Ok here is my info on these wheels. I just got the very first set of 058 wheels are they are bad ass! Polish job is a little dull and center caps are typical eagle wheel cheap looking. I bought these for my 88-98 dually. There is no way these will tuck on a lowered truck. Over all combined rear dual width is 21-3/16". This is too wide to fit under a factory set up. From the inside mounting surface to the outer edge lip on all wheels front and rear is 9-13/16" so I guess what I am saying is the back spacing is 9-13/16" on all wheels. The inside wheels do not have a different offset although rumor had it they were. The space between the wheels in the rear is 4-1/4" wide. Don't buy these unless you have wider fenders, narrowed rear end, or you don't mind your wheels sticking out. I have wider fenders on my truck so these will work great for me. I will post picture when I get tires and get them mounted on the truck. Hope this helps all of you make a decision. I also don't believe these will fit on a square body and tuck without wider fenders or narrowed rear end. Sorry for long post. Let me know if you have questions.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 06-23-2013, 03:48 PM   #90
SCOTI
SCOTI's Avatar
What tires do you plan to run?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-23-2013, 04:14 PM   #91
LOW1TON
Probably the nitto 420s, fronts will be 245/45/20, rears will be either the 255/50/20 or the 265/50/20 but have not made a final choice yet.
Old 06-23-2013, 04:15 PM   #92
SCOTI
SCOTI's Avatar
Cool... About what I had in mind from researching. Looking forward to seeing some pics. There's also a 235-55-20 by Yokohama....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-23-2013, 07:04 PM   #93
JCampbell
What are the odds of you getting bored and throwing them on your square for a look-see?
Old 06-23-2013, 07:10 PM   #94
meatwagon83
how about a lifted square?
Old 06-23-2013, 07:38 PM   #95
LOW1TON
Jcampbell, my square has a narrowed rear end so I won't be much help or i would do it gladly. Lifted truck would be fine as long as you are cool with the rear wheels sticking out past the fenders.
Old 06-23-2013, 08:47 PM   #96
JCampbell
Hmm. For some reason, I thought you were on Townastys.
Old 06-23-2013, 10:22 PM   #97
LOW1TON
I am on "townastys" but still for extra clearance we narrowed my rear axel. Townastys will get you under the fender but won't allow you to tuck with air bags.
Old 12-03-2014, 02:52 PM   #98
lolife99
67-72 parts collector,…
lolife99's Avatar
Bringing this old thread to the top.
Anyone running the AE 20" dually wheels now?
Keith
Convert to disc brakes.
Old 12-04-2014, 02:06 AM   #99
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Pictures of a Dodge Truck we did for a customer .... ...Polished Eagle 056's in 20"
ksbrktracer is offline   Reply With Quote
Old 12-05-2014, 06:32 PM   #100
SCOTI
SCOTI's Avatar
This is all I've seen them on.... lifted trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
