#76 |
Re: All California Members
but how does it work since i just recently found out that my block is from a 96+ truck do I have to find smog parts from the same year of the block or can i put like a 1977 smog parts?
#77 |
it's been said but if you have a 96 block you need to meet the smog requirements of that engine and year. so yes you need 96+ smog equipment
#78 |
is there another way how can i find out the exactly year it came from?
#79 |
#80 |
![]() Join Date: Oct 2013
Google is your friend. for decoding engine numbers try: http://www.crankshaftcoalition.com/w..._chevy_engines. also for smog info: www.dmv.ca.gov/vr/smog.htm
search California Vehicle Emissions Testing and get a copy of the California Vehicle Code. a professional registration service should be able to help steer you in the right direction. search for one in your area or try Donna Leek for a possible reference to someone in your area: pro.reg.service@gmail.com - I do know of a '76 that has a '92 350 in it that has all of the original smog equipment on it that passes the Smog tests. |
#81 | |
Here is the casting number chart I usually use. http://www.nastyz28.com/sbchevy/sblock.html |
#82 |
Unless the VIN is stamped on the engine, there is almost no way to tell EXACTLY what year the engine came from. Some may of sat a year or two before actually being fully assembled and installed in a vehicle. What stampings are on your block? If youd like, you can PM me and I'll help you out,
#83 |
#84 |
At the body shop.
Once every 2 years.
" That didnt make it any newer " " Dont antique the equipment " |
#85 |
my best advice is to find a guy. ask everyone you know. keep asking , see an old truck in a praking lot go up and ask the guy, ask ask and ask somewhere someone wants your money!
2001 Tahoe 1978 K30 |
