01-28-2014, 09:00 AM | #76 |
Re: Vinegar for rust removal
Cool stuff
01-28-2014, 02:54 PM | #77 |
I have also cleaned scale out of radiators with the stuff!
01-31-2014, 03:12 PM | #78 |
I used never dull on the aluminum side pieces on my 66. They looked great. Then I wiped them with a wet rag, and they went instantly dull again.
02-01-2014, 02:25 AM | #79 |
60-66 Nut
Did you strip the clear anodizing off of them first?
02-01-2014, 12:13 PM | #80 |
02-02-2014, 12:37 AM | #81 |
60-66 Nut
You need to remove the clear anodizing from aluminum before you can polish it. Oven cleaner works good for that.
02-02-2014, 10:45 AM | #82 |
03-28-2014, 09:14 AM | #83 |
Put this on the build thread...but thought it might be more use here to show the results. Been working on getting the fleetside assembled now that I have a clean title back and have been soaking some more parts. I have gone to a 75% vinegar and 25% clr solution and its sped up the process by about 30%. Still getting the same great results......a pic of the tailgate chains which were left in a 5gal bucket of water by the PO for an undisclosed time frame....they looked rough before 3 days of soaking.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-28-2014 at 09:22 AM. |
03-28-2014, 12:04 PM | #84 |
I may have to give this a try for all the hardware & little brackets I'm pulling off as I repair the front rust. Does it hurt any to leave stuff soaking too long? I don't want to leave the bolts in a bucket for a few weeks and come back to find them dissolved.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD Last edited by Improbcat; 03-28-2014 at 12:04 PM. Reason: I no spull gud |
03-28-2014, 01:34 PM | #85 |
Ive left steel bolts in for up to two weeks with no issues. I do rinse with a baking soda & water mix....just a 1/4 box or so in a 5gal bucket. I've had great success with the vinegar. The 25% CLR mix is something new I've been doing and it seems to help cut the soak time down some. After a few days soaking, I take a wire brush to them, resoak for a few hours or another day, do my baking soda and water rinse and air dry. It will give the metal a nice prepped surface for self etching primer (which I use on all bare metal). Posts some pics of before and after too if you don't mind.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-05-2014, 05:54 PM | #86 |
I put my headlight buckets and after a week it was clean bare metal. I sprayed with rustolyum and it came out awesome. The 292 6cyl water jackets are crusty rusty so I put a few gallons of vinegar and letting it set for 3 months now so we will see what happens
