06-19-2013, 02:44 PM | #76 |
Re: New member from DFW, first truck build not starting where I thought!
Depending what coilovers, it could be worth a grand. I think I paid close to $1600 for my Tein SS coils back in the day, they went from my first hatchback to the second. Then wound up buying them back from a friend I sold them to when I needed the money, and threw them on my crx, then they found their way onto the turbo Si. and had skunk2 pro's on the 94 coupe.
Also what wheels are on there would probably make it worth it. I say scoop her up! Hondas are so easy to work on, and b series swaps are easy as pieeee! keep me posted on it man
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! |
06-19-2013, 07:10 PM | #77 |
I just finished lowering the front of my truck this weekend and replaced all the suspension components. I found some drop spindles on Ebay for $200 shipping included and cut one spring for a total of 4 inches, have about $400 in the whole deal. I will drop the back after I get welding done on one side of the frame, but thought I would show you how low this setup would get you on the front on the cheap.
[IMG][/IMG] |
06-19-2013, 07:18 PM | #78 |
Diggin The SquareLife
im thinking it has cheap/ebay coilovers on it and some off brand wheels nothing fancy lol and yea I got a lot of friends that have Hondas/acuras so I could get the parts help but bad thing is really dnt knw how to drive a stick :/ lol but when I told my friend that I didn't knw how to she let me drive her boosted hatch!!! an man it was a blast!!!!!! she thought I was bsin when I drove it cause I was doing so good! haha
06-19-2013, 11:02 PM | #79 |
very cool project ! sucks it got off to a rough start but its going to look dropped.
06-20-2013, 09:44 AM | #80 | ||
06-20-2013, 09:47 AM | #81 |
Thank you sir!!
06-20-2013, 05:12 PM | #82 |
They were 2.5 inch spindles
06-21-2013, 07:59 AM | #83 | |
06-21-2013, 10:23 AM | #84 |
I work at LKQ of North Texas, which actually houses all the Houston and Central Texas sales reps as well. We work hand in hand with ATK remanufacturing, so I got put on with one of the guys over there and he hooked me up.
But since I was originally told that the engine was a 350, I bought the kit for a 350, so I barely used any of the gaskets and just gave them all to my brother with the rest of the parts (block, heads, gaskets etc.) And he's going to build that motor for an S10 he's got
06-24-2013, 11:35 AM | #85 |
Well thought I was gonna take a little break from working on the truck and go to the lake with my girl this weekend... Well, I guess she didn't want me to go to the lake with another woman!
On a positive note, I took a looky at the tag in my glovebox and it matches my vin on my dash. Which matches the vin on my title. but it's got a silverado emblem on the silver trim piece that runs above the glove box with the two vents.. did that ever happen on the GMC's? Got a silverado dash or someone else put that on probably?
06-24-2013, 11:41 AM | #86 | |
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
06-24-2013, 11:51 AM | #87 |
Also I see on my glove box tag it says heavy duty fr. springs, heavy duty rr. springs...
If I put the standard duty leafs/ front springs would that make it sit a little lower? I've always thought it sat a littttttle high for a 1/2 ton. Secondly, per DJM suspension, their spindles require you to know if it's 1" or 1.25" rotors. When I had my wheel off changing the tire, my (WORNNNNN OUTTTTT) rotors kinda looked like they would be 1"... but with all this heavy duty stuff, is it possible they're just worn further than they should be?
06-24-2013, 11:52 AM | #88 |
And where could I find all the option codes with a little more specific details on what they include?
I might try and take my truck back to factory (just to match the codes) besides the drop.
06-24-2013, 01:08 PM | #89 | |
PM Keith Seymore I believe is how you spell his last name. He can provide you with some links and he's also a very very helpful gentlemen and can maybe even help you find out what specific truck you have.
06-24-2013, 01:23 PM | #90 |
seems like this whole section of c10s is getting the texan love! another houston part of tx lol and your project WILL change, dreams are temp when you get a square body! lol
ill be sticking around |
06-24-2013, 01:42 PM | #91 | |
So I did some looking up on my RPO's from the glove box and this is what I found... Just to see if I could get a little more detailed information, but it was mostly what was on the tag, some were a little more informative. I put down everything from the GM Site. ** are ones that didn't pull anything on the site, so I copied straight from the tag * are ones that were on the site, but I added the tag note. UA1 Battery, Heavy Duty UF2 Lamp, Cargo UM6 Radio, AM/FM Sterio, Seek/Scan, Auto Reverse Cassette **XFN P235/75/15 ALS S/B R (PER TAG)** NL2 Fuel Tank, Auxiliary N33 Steering Column, Tilt Type N41 Steering, Power, Variable Ratio N67 Wheel, Rally Type, Variation2 J50 Brake System Power K34 Cruise Control, Automatic, Electronic LE9 Engine, Gas, 8 Cylinder, 5.0L, 4BBL Hi Compression MX1 Merchandised, Trans, Auto Provisions *3 speed auto PER TAG* F59 Stabilizer Shaft Front F60 Front Spring, Heavy Duty GU2 Rear Axle, 2.73 Ratio G50 Rear Spring, Heavy Duty, Variation1 CD4 Windshield Wiper System, Pulse ZQ2 Sales Package, Driver Convenience C60 HVAC System, Air Conditioner Front Manual Controls ZY1 Color Combination, Solid D45 Mirror O/S, SST *EXT Below-Eye-Line- PER TAG* **23D LDDI Blue Custom Clo (PER TAG)** 29U Primary Color, Exterior, Dark Blue (91) *29 Midnight Blue PER TAG* YE9 Convenience Package, Comfort & Decor Level #3 **YFN P235/75/15 ALS S/B (PER TAG)** **YH4 Gold Medal Special (PER TAG)** **ZFN P235/75/15 ALS S/B (PER TAG)** E63 Body Equipment, Fleetside, PUBX A01 Window, Tinted, All Shaded, W/S **B3W Preliminary Price (PER TAG)** B32 Covering, Front Floor Mats Aux
06-24-2013, 04:07 PM | #92 |
Well fellas... Another quick update for you. My girls dad owns a tire shop a mile or so from where we work, So I strolled up there to pick up 2 tires for the one that blew, and to replace the other one that is about to go... On my lunch break. That was at 1:00 today, it's now 3:00 and I just got back.
the one that I thought was going to blow next didn't, instead the one that I got from a buddy last night after the first one blew was next on the list.
06-24-2013, 05:12 PM | #93 |
I would take the wheel off and measure the rotor, you will be able to tell right away.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
06-24-2013, 05:16 PM | #94 |
I didn't have a measuring tape handy :p but I'm going to when I put my other wheels on. Just ordered a set of tires through work for 40 bucks with 75% tread :p
06-25-2013, 10:50 PM | #95 |
Have you decided on the drop you are going to put on the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
06-26-2013, 10:30 AM | #96 | |
Front: 3" spindle, 2" spring (cut 1 round) Rear: 5" flip, 2" shackles, 1" block And probably run the calmax shocks on all 4 corners. Which leads me to what I did last night, threw a tinyyyyy AS* set of 215/60's on my other set of 15x8 rallies. When I was putting the backs on I discovered it already has 2" shackles, with the small square of bed support cut. also has a mounting bracket for the license plate behind the bumper... So I'm guessing the guy before me had it pretty low, and took all the lowering components off... But I'll be getting another set of tires (biggggger) before I go further with a drop.
86 Short Bed Build I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment! Last edited by cyclefreak207; 06-26-2013 at 10:30 AM. Reason: Left out information. |
06-26-2013, 10:46 AM | #97 | |
06-26-2013, 10:59 AM | #98 |
I don't think so, it looks like mine has a little more space in it? Sits up higher, and the bed support is notched.
06-26-2013, 11:12 AM | #99 |
Ahh I see the difference now that they are side by side. Nice use of PDF Writer
06-26-2013, 11:18 AM | #100 |
mmm, I use paint! lol, that's all I have to use for doing cut sheets and stuff at work to mark quarter/pillar cuts.
