Old 01-14-2014, 11:07 PM   #76
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
xpickup is offline   Reply With Quote
Old 01-15-2014, 12:16 AM   #77
oldman3
oldman3's Avatar
Re: 47 Step van
Hey Shannon, what gauges are you running in the van...Jim
oldman3 is offline   Reply With Quote
Old 01-15-2014, 10:08 AM   #78
99 to Life
99 to Life's Avatar
Re: 47 Step van
the metal magician is at it again!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-18-2014, 05:01 PM   #79
xpickup
xpickup's Avatar
Re: 47 Step van
Oldman3, the main gauges are dolphin brand and the air ride are air lift brand.
99 to life, thank you.
Tomorrow I will get the steering back together now that everything is painted. I also want to mount the pro portioning valve and finish up the brake lines. I will have pictures tomorrow.
Shannon
Old 01-19-2014, 09:25 PM   #80
xpickup
xpickup's Avatar
Re: 47 Step van
I made the rear master cylinder mount because there was some flex in it. Then I mounted the pro portioning valve. After that I made my brake lines to where I did not finish when I did the frame. I had bought a blue point flare kit and it works great if anybody is looking for a good one. I then put the steering all back together. I only thing I had to put in is the steering column. I was able to put the wheel well back in too.
Shannon
Old 01-19-2014, 09:30 PM   #81
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-19-2014, 09:31 PM   #82
drivewaycustoms
drivewaycustoms's Avatar
Re: 47 Step van
This is a very cool build with lots of impressive fabrication too! What ever happened to the 6 cylinder?
87 Crewcab Dually
66 Cadillac Sedan deVille
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
drivewaycustoms is offline   Reply With Quote
Old 01-19-2014, 09:34 PM   #83
xpickup
xpickup's Avatar
Re: 47 Step van
Drivewaycustoms, thank you, I do not know if it came with the motor when Ken bought it.
Shannon
Old 01-19-2014, 09:36 PM   #84
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-19-2014, 09:50 PM   #85
xpickup
xpickup's Avatar
Re: 47 Step van
More pictures
Shannon
Old 01-19-2014, 09:52 PM   #86
xpickup
xpickup's Avatar
Re: 47 Step van
Last ones.
Shannon
Old 01-20-2014, 12:34 AM   #87
oldman3
oldman3's Avatar
Re: 47 Step van
Shannon, looks great...Jim
Old 01-22-2014, 11:37 AM   #88
wickid demon
wickid demon's Avatar
Re: 47 Step van
Shannon what size step die do use on your floor pans and gauge of metal? Your work looks fantastic. Another question do you have any issues with putting a bead in a transmission tunnel then running it through the slip roll to give a curve. Thanks for the tips you give and the work you do.
Ryan
Ryan
My Wickid 54 http://67-72chevytrucks.com/vboard/s...d.php?t=518657
wickid demon is offline   Reply With Quote
Old 01-22-2014, 03:03 PM   #89
xpickup
xpickup's Avatar
Re: 47 Step van
wickid demon, I made both 1/8 and 3/16 step dies for my bead roller. On my steel floored projects I use .o60, or 16 gauge. This truck is aluminum and is 14 gauge or .080 thick. Big thing in doing it is making to tight of a radius, because it wants to drag on the edge of the die and shears the corner. I use the lid from the smaller coffee cans for the template for my corners. On the tranny tunnels, when you put it in the slip rolls it does flatten out the indented part but the line from the bead roller is still there. No problem on the tips, always glad to help everyone.
Shannon
Old 01-22-2014, 06:36 PM   #90
_Ogre
_Ogre's Avatar
Re: 47 Step van
Originally Posted by xpickup View Post
Last ones.
as if we'd let you get away with that
shop air compressor timer
Old 01-23-2014, 09:53 PM   #91
48 GMC BURB
48 GMC BURB's Avatar
Re: 47 Step van
Driveway, It is here in Annapolis waiting for you to come an adopt it !!! Seriously if you can use it I have the trans also ...
Shannon , AKA Metal Master ...sweet work as usual !!
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 01-24-2014, 11:02 PM   #92
xpickup
xpickup's Avatar
Re: 47 Step van
_Ogre, haha, it was nice when you could post 5 pictures at once. Now with the resized photobucket one sometimes you can not even do two.
48 GMC BURB, thank you, that is right you did have the engine and tranny.
Well nothing done on the truck outside in the driveway because it was like high of 15 degrees today. I am so over this cold snowy weather, and spring can not come soon enough. So I was working on some stuff inside my heated garage. The truck was missing the side cowl. So I made an air scoop for it. It will have a sliding closer in the inside of the cab so that the fresh air will be able to come it. I still have to cut out the hole on the back side but other than that the outside is done except for a little sanding.
Shannon
Old 01-24-2014, 11:04 PM   #93
xpickup
xpickup's Avatar
Re: 47 Step van
Pictures
Shannon
Old 01-24-2014, 11:06 PM   #94
xpickup
xpickup's Avatar
Re: 47 Step van
More pictures
Shannon
Old 01-24-2014, 11:08 PM   #95
xpickup
xpickup's Avatar
Re: 47 Step van
Last ones
Shannon
Old 01-24-2014, 11:24 PM   #96
wickid demon
Re: 47 Step van
Shannon that scoop turned out awesome. Your attention to details are second to none.
Ryan
Old 01-25-2014, 12:29 AM   #97
oldman3
oldman3's Avatar
Re: 47 Step van
Shannon, they will know you didn't pick that up at the local hot rod store, super nice job...Jim
Old 01-25-2014, 09:15 AM   #98
xpickup
xpickup's Avatar
Re: 47 Step van
Wickid demon, thank you.
Oldman3, thank you. I still have to mount it. I used some duct tape on the back to hold it there. Had to see how it looked.
Shannon
Old 01-25-2014, 10:28 AM   #99
Bubba54
Re: 47 Step van
Shannon, Build is looking great. My first time seeing the offset steering, looks solid.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 01-25-2014, 04:03 PM   #100
99 to Life
99 to Life's Avatar
Re: 47 Step van
awesome, so sick. did you perforate that or can you buy it like sheets like that?
