Old 04-10-2014, 04:29 PM   #76
JROC's Chevy
Re: 2010 Camaro Wheels on Lowered C10
Schoolboy, NICE truck! Did you have any issues with scubbing? I am about to put a set of these wheels on my 1979 Silverado. What tires sizes did you use on front and back? I am looking for a tire with around 4" of side wall. How much where the 2" adapters? Thanks for your time.
JROC's Chevy is offline   Reply With Quote
Old 04-10-2014, 04:52 PM   #77
JROC's Chevy
Do you think 1.5" adapters will work?
Old 04-10-2014, 05:00 PM   #78
Houston Ben
Houston Ben's Avatar
I like and will do the same when my tires wear out!
Houston Ben is offline   Reply With Quote
Old 04-10-2014, 05:23 PM   #79
school boy
school boy's Avatar
I had no scrubbing when turning, but did rub the fender lip in the front if wheel turned and hit a bump. These wheels/tires ran smoother than my wore out 235/70/15 tires. Google "5x5 to 5x4.75 adapters" and mine ran $200 shipped and were made to fit 73-98 2wd chevy/gmc hub diameter. As for tires, 245/45/20 and 275/40/20, theres about a 4 inch side wall.
1.5 adapters would work but in my opinion, not enough on the looks side.
school boy is offline   Reply With Quote
Old 04-10-2014, 05:29 PM   #80
JROC's Chevy
Gotcha. So if I went with a bit smaller tire on the front say 3in sidewall I could eliminate some scrubbing and give myself a little more clearance?
Old 04-10-2014, 05:56 PM   #81
school boy
school boy's Avatar
when I say my truck is low for static drop truck its low. its about 5.5-6 in front and 7-8 in back. I rub even with the over wheels/tires. So as long as youre not extremely low, I would run those sizes.
Old 04-10-2014, 06:02 PM   #82
JROC's Chevy
Ok, gotcha. Mine is about 2-3 in front and 4-5 in rear. Thanks for your help. I will post some pics on here when I get it all done.
Old 04-30-2014, 10:13 PM   #83
AGearHead4Life
AGearHead4Life's Avatar
School boy, did your adapters appear to be hub centric? Trying to decide if I should even worry about it and just run these. They've got a set of four on ebay for $109 shipped here:
http://www.ebay.com/itm/4-Wheel-Adap...5f01c0&vxp=mtr
The set that of 2" adapters that Im using on my '92 Camaro with C6 wheels have held up well but dont remember if they are hub centric. Guess I can go pull a wheel.
AGearHead4Life is offline   Reply With Quote
Old 05-01-2014, 03:11 PM   #84
school boy
school boy's Avatar
Mine were not hubcentric but the inside of the adapter was snug on the hub. If you really think about it, a lot of wheels with the two bolt patterns have an opening much bigger than the hub diameter and rely on the lugs to be center. As long as the wheel uses acorn lug nuts, the wheel should be centric. With that being said, im a over achiever and use hubcentric wheels and adapters when I can.
Old 05-01-2014, 09:38 PM   #85
AGearHead4Life
Good points. Thanks man!
Old 05-01-2014, 11:34 PM   #86
Tom
driving is in my blood
Tom's Avatar
The truck in the pic with the 15"s on the first page doesn't look quite that low. My old 79 was 5/6" and the front looks lower. It was running a 255/60/15 and the edges were past the fender lips.
Old 05-02-2014, 10:10 AM   #87
school boy
school boy's Avatar
It does look a little higher, may be the angle. Im using 2.5 drop spindles, 2.5 springs that were cut about half a coil, flip kit and 2 inch shackles. heres a little better pic.
Old 05-14-2014, 10:01 PM   #88
SILV
Schoolboy, did the normal 1/2x20 lug nuts work with those wheels. I'm assuming any acorn lug nut works but I'd like to know for sure.
SILV is offline   Reply With Quote
Old 05-15-2014, 06:06 PM   #89
TheBlueBomber
TheBlueBomber's Avatar
I love them!!
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 05-23-2014, 03:45 PM   #90
school boy
school boy's Avatar
Normal acorn 1/2-20's worked. sorry for the late response btw.
Old 05-28-2014, 05:29 PM   #91
JROC's Chevy
Got my camaro rims bolted up! I think I need to drop it down some more. I have a 2" drop hanger, 2" shackle and lower shocks on the rear and the fender lip sits about 3 1/2" higher than top off tires. I have also installed new leaf springs. How much more do you guys think a axle flip will drop it? What do you guys think about removing the helper spring and how much would that drop it? I would like the fender lip to sit even to 1" lower than tires. http://imgur.com/odMx0fG
http://imgur.com/soh4c6s
Old 05-28-2014, 06:13 PM   #92
AGearHead4Life
I've ordered 1.5" adapters, but was recently informed that they won't work for the front. We will see I guess. I may be ordering another set.
I got the 1.5" because i wanted to make sure that they cleared the fenders when I go lower.
Old 05-28-2014, 06:21 PM   #93
wjjeeper
wjjeeper's Avatar
I think the Camaro wheels look great on there
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 05-28-2014, 06:28 PM   #94
AGearHead4Life
I believe that a flip kit will drop it 5" more.
Old 05-28-2014, 06:38 PM   #95
TIM86
TIM86's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
TIM86 is offline   Reply With Quote
Old 08-15-2014, 03:19 PM   #96
JROC's Chevy
Guys its been a while but here is my truck with the camaro rims. Let me know what ya think. http://imgur.com/rlh0jnj - http://imgur.com/tdCewCl - http://imgur.com/lBTqg8Q
Old 08-15-2014, 06:52 PM   #97
Pop's C-10
Pop's C-10's Avatar
Tha assist for Jroc
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 08-16-2014, 05:51 PM   #98
gmachinz
I think what looks odd about them (I do like the wheels...not knocking them at all here...) is that these lowered squares IMO look aggressive with a more negative offset. That wheel style looks good on the truck but would be a lot better if the hubs were tucked in more.
gmachinz is offline   Reply With Quote
Old 08-18-2014, 05:22 PM   #99
JROC's Chevy
Thanks, Pop's! How are you getting the pics to show up? Gmachinz I hear ya, to each his own, I think they match the body line very well. It would be nice if this style rim was made with a truck offset so we could compare.
Old 08-19-2014, 06:59 PM   #100
slammed90
slammed90's Avatar
Saw this one n thought it was a sharp looking truck.
"NO BAGS JUST PLAIN LOW"
slammed90 is offline   Reply With Quote
