#76 |
Vintage 4x4s
Re: 72 1/2 2wd getting parted now
Randy,
On second thought, I will take the outer grille. Also will take the core support unless the one in the K20 is still mostly intact under the battery tray. Thanks, Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#77 |
![]() Join Date: Mar 2007
Sorry for the delay Randy. I am going to pass for now. I think I will wait for one that needs less work.thanks for your time
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#78 |
Just like to part out trucks!!
OK Jud, I'll look at K20 support today. Grill is yours and so is support if K20 is bad
Bowtie72, no problem Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#79 |
Heater control and ashtray are sold
#80 |
![]() Join Date: Apr 2011
Randy if you still have it I'm interested in the parchment auto column. I also need a linkage and a crossmember. Basically everything to do an auto swap on my truck. Thanks -
Jim |
#81 |
Jim, $65 shipped for column, I could throw linkage in same box for another $25. AT crossmember $45 shipped, AT brake pedal setups are $32. Thanks Randy
#82 |
I will take the column, the linkage and the crossmember. Please PM me payment instructions, IIRC you no longer take Paypal?
#83 |
They are yours info sent, Thanks Jim, Randy
#84 |
Rolling frame, steering wheel, shroud, alot of other parts still for sale. Ask and I can let you know if I have the part. Thanks Randy
#85 |
![]() Join Date: Oct 2012
Randy, I will pass on the center caps but I did get the payment for the engine stands mailed out. Thanks!
Russ
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
#86 |
#87 |
Russ, no problem, stands are yours
p_rubottom, I have that bracket. I also have some regs out there, what year are you needing them for? Thanks Randy
#88 |
Pics for Bill, both will need cleaned up
#89 | |
I believe the cab is a 70-71. Also forgot to ask earlier, i need the tailight wiring harness for a fleetside, do you have any? All this would be shipped to 67026 zip. Thanks |
#90 |
Hey Randy,do you still have the heater control panel in panel 60,also need a clutch rod delete plate,if the heater levers are not broke I will take them.Thanks Randy
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#91 |
p_rubottom, I'll look on regs, the one bracket bolts to firewall, and round bracket goes around column and other bracket, I'll have to look on round bracket, I cut them off most the time. Sorry no taillight harnesses right now
Randy, this one is sold, I think I have another good heater control out there, I'll look Thurs after work. I have alot of clutch delete plates Thanks Randy
#92 |
p_rubottom, I only have 72 window regs out there. And on the brackets, I only found the one bracket, I didn't find a round clamp but I have one more place to look
Randy, here is pics of heater control, the face isn't as nice as the one in this truck but no broken levers $47 shipped for it and clutch delete plate Thanks Randy
#93 |
I'll take both for $47.00.Thanks Randy.
#94 |
Thank You Randy, I'll let you know when money order gets here. Thanks Randy
#95 |
Vintage 4x4s
Hi Randy, did you look at the core support on the K20?
#96 |
Hey Jud I just looked at it it's rusted out the battery tray
#97 |
Hey Randy,has the MO for the gas pedal & cable arrive?Thanks Randy
#98 |
Randy, it came this morning, mailing out Mon. I'll let you know when the money for heater control and delete gets here. Thanks so much, Randy
#99 |
Vintage 4x4s
ok randy, add the support to my pile. thanks, jud
cash when i get there ok otherwise i can send a check now. Posted via Mobile Device
#100 | |
