#76 |
Re: TX '64 Under Way
I've never worked on a 64 pickup, but of the other GM vehicles I've worked on from the 50's to the 70's, the door glass is attached to the regulator so it will need to either be removed or held in place somehow. I'd recommend taking the window out if you're going to have it apart for more than a few hours. You wouldn't want the window to fall inside your door and shatter.
As for the vent window, if you leave the door glass in, the vent window won't need to come out. If you take the door glass out, sometimes you can get it out with just loosening the vent glass, sometimes you have to take it out. It's only because the door glass uses the vent glass for the front run channel that you might need to take the vent glass out.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#77 |
I'm just glad to be here!
Look at Sharps40 thread starting on post #156. He does a good job of photos and description on how to get it all out....
http://67-72chevytrucks.com/vboard/s...=571916&page=7
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#78 |
Is that a falcon fuel tank? and where did you find it??
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#79 |
As Aggie hinted: if you pull the entire assembly, window and wing window, you will see how easy it all is.
In fact, I would venture to say it is easier to reassemble that way, instead of trying to work around stuff you didnt want to loosen up or take out. At the end of the day, it is silly easy to do and you may think of some things you want to do/add to the door while you have all that stuff out. (tinting the glass or sound deadner inside the door.)
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#80 |
Thanks for the quick replies guys. I did some more reading last night and it seems you guys are on point. I've also got a few rolls of sound deadner being delivered today, so I'll coat the inside of the door and door panel while I have it apart. Appreciate the help!
The gas tank I'm using is a Mustang tank, 65-68 I believe. We got this one locally here in Dallas at a Mustang shop. You can find them online for about $150 with a sending unit. Hard to beat the price, especially since they fit so perfectly in between the rails. Since I switched my gauges over to Auto Meter, I ordered a fuel gauge to match the sending unit for ease. Here's a link to an online retailer: http://www.cjponyparts.com/fuel-tank...5-1968/p/FTK5/
'58 Apache |
#81 |
for the gas tank, where did you mount the filler neck? Is it in the bed floor?
#82 | |
If I go the stationary route, I'll bring the filler neck up to the bed floor.
'58 Apache |
#83 |
Got the driver's door done last night: changed the exterior handles, door lock, door handle relay, window regulator, applied sound deadner to the door panel and as much of the door as I could, put in new interior handles (window and door opener) and added the arm rest. Hoping to get the passenger side done this weekend.
Thanks for the guidance. Your tips helped a lot as I worked through it. I still have a bigger gap than I'm comfortable with between the exterior door skin and the vent window rubber seal. In our bathroom at the house, I looked at the shower door rubber seal that goes between the frame and the door glass. It's a small enough seal that I think could be used to fill the gap on my truck window, so I may swing by the hardware store and grab some to see if I can make it work.
'58 Apache |
#84 |
Hello, love your truck actually just spent over an hour searching for this thread so I could stare at it some more haha. Do you know what size tubing they used for your step notch? Im going to do my 65's the same way since I feel that is the strongest way to notch these trucks but im not sure what would be the best size to use. Thanks in advance
#85 |
Hey bruh, any issues installing Ididit retrofit, column shift?
1965 Short Fleet http://67-72chevytrucks.com/vboard/s...d.php?t=637478 1983 Short Fleet (Under construction for my 13 year old son) 2008 GMC Denali 2012 Harley Roadglide Follow me on Instagram: Ru_django ![]() |
