Old 01-07-2014, 07:10 PM   #76
checkmate211e
checkmate211e's Avatar
Re: My build thread- 67 C10 SWB
Originally Posted by 67cheby View Post
WOW, impressive amount of sheet metal work in that cab !
Thank you sir, you have an impressive piece of sheetmetal of your own! Nice truck!
My 67 Chevy C10 SWB build: http://67-72chevytrucks.com/vboard/s...30#post6406130
Hydroboost conversion: http://67-72chevytrucks.com/vboard/s...22#post6405622
checkmate211e is offline   Reply With Quote
Old 01-07-2014, 07:19 PM   #77
67cheby
67cheby
67cheby's Avatar
thanks man !
67cheby is offline   Reply With Quote
Old 01-07-2014, 10:13 PM   #78
checkmate211e
Now that the bed metal is here from LMC, I can work on that until the mufflers arrive. Like a idiot, I am piecing it together. I smart person would have just bought the complete steel bed already assembled. But I am probably saving a couple hundred bucks by welding it together myself.
Old 01-08-2014, 10:03 PM   #79
checkmate211e
The Spintechs are here and exactly what I needed! (provided they aren't too loud) (1) 45 gets me right to the Xpipe and the other gets me right where I need the exhaust tips to be. These mufflers look like very good pieces, very well built! Still fabricating the muffler brackets.
Old 01-08-2014, 11:23 PM   #80
getsomegreen
This is a nice build!
getsomegreen is offline   Reply With Quote
Old 01-09-2014, 11:39 AM   #81
NastyNate32
NastyNate32's Avatar
Did you learn to mig weld starting on body panels? I just started mig welding myself and I have to weld on my rockers, fill old tank fill hole, and shave side markers. Any tips?
NastyNate32 is offline   Reply With Quote
Old 01-09-2014, 12:21 PM   #82
mcbassin
Still Learning
mcbassin's Avatar
You did a great job saving that cab! For a second, I thought dang that was fast! Then I saw the date stamp 2011. Time lapse....? tetanus shot . Nice build.
mcbassin is offline   Reply With Quote
Old 01-09-2014, 05:57 PM   #83
checkmate211e
My first adventure into mig welding was the 1 piece floorpan. My tips would be to use .023 wire (with gas, don't flux core), when possible use panel clamps and copper backing plates. Don't let the sheetmetal get too hot while welding, it cause warpage and burn through, I like to jump around tack welding (3 tacks) and then use a air nozzle to cool the metal off before doing more tacks. Study up on the uses of 3 different types of welds (there may be more, but this is what I can think of at the moment for sheetmetal): butt, lap, and plug welds. Use vise-grips, sheetmetal screws, and magnets to hold your piece in place when possible. I like Eastwood, TP Tools, and smartshoppersinc.com for bodyworking tools.
I really like the copper backing when working with sheetmetal because you can turn the heat up a little more to get better penetration an not worry as much about burn through.
http://www.eastwood.com/butt-weld-cl...ckers-kit.html
Old 01-09-2014, 06:03 PM   #84
checkmate211e
Thank you. Lol, I started this truck in June 2011. This has been over 3 years in the making, and still a long ways to go. Then I decided to share what I have learned in the process after getting inquiries into the complete floor pan process.
Old 01-09-2014, 06:24 PM   #85
checkmate211e
I also like this copper backer because its soft, just drill a hole in it (or 2) and screw it to your repair area with small sheetmetal screws. As far as the rockers, I would use Zinc rich weld through primer on the inside wherever you are concerned there will be bare metal left.
http://www.eastwood.com/soft-copper-triangle.html
Old 01-12-2014, 08:47 PM   #86
checkmate211e
4 more pipes left to take care off and probably need to add at least 4 more hangers.
Old 01-12-2014, 09:43 PM   #87
Z10
Z10's Avatar
Looks great Checkmate! I'm about to install a Magnaflow system on my 72. What cats are you using?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-12-2014, 09:56 PM   #88
checkmate211e
Thanks,
Thanks! No cats, just flex pipes to absorb the vibrations from the motor. Decided to use flex pipes to avoid putting the torque stress on the exhaust pipe joints.
Old 01-13-2014, 09:18 AM   #89
Bennett68C10
Bennett68C10's Avatar
Nice job on the exhaust
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-08-2014, 10:29 AM   #90
duallyjams
duallyjams's Avatar
um it's May already no update since January.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-08-2014, 06:22 PM   #91
checkmate211e
I know man! Sorry, a lot of changes went down at work in January. So a lot more responsibilities got thrown into my lap, unfortunately, more pay was not. Overtime is now at my discretion, so that was my "raise". Also was "handed" a company phone, so even when I'm not at work, I am. Seems like the likelihood of raises went out the door when the current idiot usurped the Oval Office.
Old 05-08-2014, 07:41 PM   #92
duallyjams
duallyjams's Avatar
Huh my work schedule changed for the worse also, I feel like I'm always there and never have any time off unless I use vacation.
James
IG duallyjams
Old 05-08-2014, 08:35 PM   #93
checkmate211e
I feel ya. I'm terrified to use vacation time because I'm the only true parts/tire guy. Inventory is hard enough to keep straight when I'm there, let alone being gone for a few days. I will be out doing forklift tires tomorrow, so I cringe at the thought of what the end of my day will be like.
Old 05-16-2014, 06:32 PM   #94
checkmate211e
FINALLY!!!!! AN UPDATE! Got around to tacking the exhaust and then got someone to TIG weld. Still a little more to go, but finally some progress.
Old 05-26-2014, 11:38 AM   #95
checkmate211e
Managed to get some work done on the dash this weekend.
Old 05-28-2014, 08:57 PM   #96
checkmate211e
Decided I need to get this bed together so its not taking up so much room in the garage.
Old 05-28-2014, 09:00 PM   #97
67chevy1
67chevy1's Avatar
That dash is looking great. What size exhaust did you put in it.
67chevy1 is offline   Reply With Quote
Old 05-28-2014, 09:09 PM   #98
checkmate211e
Thanks Matt. Kinda procrastinating on the dash, can be a bit stressful at times. The dash is my make/break on the build. If it looks like crap, I will look like an idiot. The exhaust is 2 1/2". The largest motor I ever plan on putting in the truck is a 383, so I should be good for a while. Most of it is 304 stainless, but the X pipe is 409. The mufflers are aluminized Spintechs. Once the bed is done, I can plan the position of the tips (forward of the rear tires).
Old 05-28-2014, 09:38 PM   #99
67chevy1
67chevy1's Avatar
The dash is defenately a monumental task, but it is looking as good as the rest of your build.
Old 05-29-2014, 12:14 AM   #100
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress. Looking good.
