Old 03-17-2014, 10:39 AM   #76
Claytona08
Claytona08's Avatar
Re: 87 SWB ..Pearl..
What is that little tool for?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 03-17-2014, 07:10 PM   #77
Sodell
Sodell's Avatar
It is concave on one end and splays the pivot rivets for the vent windows. Those two rivets are for the pivot point. Put the rivet in, place it upside down on a hard surface and them hammer the other end with the tool.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 03-19-2014, 01:05 PM   #78
Claytona08
Claytona08's Avatar
Ahhh I gotcha!
Old 03-23-2014, 09:32 PM   #79
Sodell
Sodell's Avatar
Got the pivot rivets in.
[IMG][/IMG]
tool worked well.
[IMG][/IMG]
Scott
Old 04-13-2014, 11:53 AM   #80
Sodell
Sodell's Avatar
FINALLY go the front of the dentless bed painted and put on. The bed was outside and I had to wait for a nice day to get it done.
[IMG][/IMG]
Scott
Old 04-14-2014, 11:41 AM   #81
Claytona08
Claytona08's Avatar
Looking good Scott.
Old 04-14-2014, 11:50 AM   #82
Sodell
Sodell's Avatar
Looking good Scott.
Thanks, it seems never ending...looking forward to some good weather...
Scott
Old 04-16-2014, 08:37 PM   #83
Sodell
Sodell's Avatar
I reluctantly ordered a dash pad from ebay..
http://www.ebay.com/itm/270984456512...84.m1497.l2649
I got the pad in three days. So far pretty happy with it. I have seen a lot of recommendations for Dashesdirect.com. Their urethane pads are $380, so I was happy to find this in the box!...It looks pretty thick and feels more substantial than another I have recently seen.
I will post some pictures when I unwrap it this weekend. I might be able to get it installed.
[IMG][/IMG]
Scott
Old 04-16-2014, 09:51 PM   #84
surly66
surly66's Avatar
I like your build, Scott. Can't wait to see the finished product...do you mind if I ask where you go the vent window pivot rivets in the correct size?
Thanks.
Tony
surly66 is offline   Reply With Quote
Old 04-17-2014, 01:41 AM   #85
Sodell
Sodell's Avatar
I got them as a set on Ebay...If I was going to do it again, I would leave these rivets on and take the ones off that attach to the inside track. Then you could just use plain rivets with a rivet gun to reattach.
Scott
Old 04-17-2014, 08:26 PM   #86
y5mgisi
Second Chance Program
y5mgisi's Avatar
Sweet score!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-17-2014, 08:48 PM   #87
surly66
surly66's Avatar
Thanks for the info...I think I'll give that method a go.
Tony
Old 04-17-2014, 09:47 PM   #88
Sodell
Sodell's Avatar
Tony
I think that would be the easiest. I would also recommend warming up the rubber seals when replacing.
Scott
Old 04-18-2014, 05:07 PM   #89
Sodell
Sodell's Avatar
Cleaned, polished and got new vinyl for center pieces of the grill.
[IMG][/IMG]
Scott
Old 04-18-2014, 09:15 PM   #90
Sodell
Sodell's Avatar
This is a before photo...
[IMG][/IMG]
Scott
Old 04-20-2014, 05:53 PM   #91
Sodell
Sodell's Avatar
Polished all the stainless steel, painted the grill and put it back together.
[IMG][/IMG]
[IMG][/IMG]
All of the plastic clips were broken for the side stainless, and I have not been able to find any new ones. I had to use some small bolts and nuts for the ones completely broken. I used some bent bobby pins to hold the ones that just had the clips broken.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Scott
Old 04-22-2014, 10:17 PM   #92
Sodell
Sodell's Avatar
I had to fix the insert before I could install the dash pad. I got a small threaded rod from Fastenal, and some nuts. Drilled holes where the plastic thread was and glued the threaded rod into the hole with two part epoxy. It worked great. The insert is in good shape other than the back fasteners being broke.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Scott
Old 04-23-2014, 10:15 AM   #93
Claytona08
Claytona08's Avatar
Wow, everything is looking great! The grille came out very nice!
Old 04-23-2014, 06:53 PM   #94
Sodell
Sodell's Avatar
Thanks, I am hoping to get new paint on the doors, and then I can put the cab completely back together and start driving it a little more.
Scott
Old 04-26-2014, 07:48 PM   #95
Sodell
Sodell's Avatar
Got the dash back together and installed. It's not perfect, because the fit is a little off, but I think it looks much better than a cap.
[IMG][/IMG]
I ordered some new pedals today, and I need to get new carpet. That and the Taz floor mats need to go...lol
Scott
Old 04-26-2014, 07:55 PM   #96
Sodell
Sodell's Avatar
While I was working on the interior I decided to go ahead and tackle the headliner. The fabric was sagging in a bunch of places, and it was so faded it looked blue.
[IMG][/IMG]
Used some fabric paint to freshen up the color. The fabric was in otherwise good shape. I have not used this type of paint before, but I am happy with the results.
[IMG][/IMG]
I was concerned for a while because it looked like it had streaks on the fabric, but once it dried it was fine.
[IMG][/IMG]
Scott
Old 04-26-2014, 08:00 PM   #97
Sodell
Sodell's Avatar
I used some 3M upholstery adhesive and reattached the fabric to the headliner. I am getting close to completing the interior.
[IMG][/IMG]
Scott
Old 04-29-2014, 08:35 AM   #98
Claytona08
Claytona08's Avatar
Looks great! Progress is coming along!
Old 04-30-2014, 09:58 PM   #99
Sodell
Sodell's Avatar
Thanks, I am very close to being able to drive it....
Scott
Old 05-03-2014, 12:18 AM   #100
Sodell
Sodell's Avatar
I puled the truck out today to do some wet sanding and I found a little bit of trans fluid on the floor. I can't stand to have a leaking vehicle so after an investigation I found that the speedo gear was the culprit. This turned into a project and I ended up replacing the trans mount, and the filter.
It was dirty, must have been leaking for a while.
Cleaned every thing up
[IMG][/IMG]
The inner and outer seal are almost impossible to find. I had to go to a transmission shop and beg for some.
[IMG][/IMG]
Scott
