Old 02-09-2015, 09:55 AM   #76
T.W.Dustin
T.W.Dustin's Avatar
Re: 1964 short step 292 "AZ Valley Cruiser"
Originally Posted by Mjminino View Post
Are you going to Por15 or powder coat your frame? I ended up por15ing
I plan to clean it all up, etch prime it and then paint it satin/semi-gloss black using implement paint from John Deere or NAPA. That's all that is needed out here. Additionally, this is a budget build intended to be a regular driver. Everything is happening either in my garage or in my side yard I have set up for doing this kind of work. I am planning on painting the truck at home as well.
Please Watch for Motorcycles
T.W.Dustin is offline   Reply With Quote
Old 02-10-2015, 06:57 AM   #77
Mjminino
Do you have any information on the aforementioned paint? I used por15 and it took half a quart (and was only 55$), 8 hrs, a pack of cigarettes and 12 beers to finish mine
Mjminino is offline   Reply With Quote
Old 02-10-2015, 12:45 PM   #78
TJ's Chevy
TJ's Chevy's Avatar
Yer gonna be spoiled in that thing! lol haha!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-10-2015, 12:47 PM   #79
T.W.Dustin
T.W.Dustin's Avatar
I used POR 15 on a 1969 Corvette restoration years back. I remember it taking 2 weeks to get it off my hands. I had that frame powder coated and used POR 15 in other critical steel substructure elements (bird cage).
Old 02-22-2015, 11:20 PM   #80
T.W.Dustin
T.W.Dustin's Avatar
I have been thinking more on the transmission and have decided I may just bolt a 700-R4 behind the 292, I am worried that the 292 might just have too much low end torque for the S10 T5. This will also simplify things. I don't want to go down the T5 WC Frankenstein path.
Old 02-22-2015, 11:46 PM   #81
TJ's Chevy
TJ's Chevy's Avatar
Could always throw in a camaro t5 or a richmond 5 as well. Real men use 3 pedals. HAHA! Just kidding now!
Old 02-23-2015, 11:48 AM   #82
T.W.Dustin
T.W.Dustin's Avatar
Hey TJ, the Camaro T5 is the "World Class" or WC version and it will bolt right up (s10 requires an adapter for the input shaft which I do already have).
However, in order to get the shifter where I want it (more forward), I would have to swap in a tail shaft from the S10 onto the Camaro T5 or it would not fit with my stock bench seat which I plan to use. these are affectionately known as the T5 Frankenstein transmission in a number of threads on this forum detailing the swap.
I am not totally convinced I am going to use an automatic but I am leaning that way. We will see. I don't plan to drive the truck hard. I can't seem to find either transmission very cheap which I was hoping for as this is a budget build. I just have to keep looking. I have everything I need to do the T5 except the transmission itself and the clutch disk.
Tom
Old 02-23-2015, 12:00 PM   #83
TJ's Chevy
TJ's Chevy's Avatar
Have you thought of an nv3500 or 4500 5 speed? They are truck trannys, but will give you the od.
Old 02-23-2015, 12:16 PM   #84
T.W.Dustin
T.W.Dustin's Avatar
I had not considered it to date, but perhaps I should. I am sure some other guys have done it. If it can bolt right up to my 292, or even better with my bellhousing and such without adapters and all it may be the right choice. What year trucks do these come out of? I really do prefer a 5 speed. I will do some searching since the search tool is back up and working
Old 02-23-2015, 02:07 PM   #85
T.W.Dustin
T.W.Dustin's Avatar
After further review, the NV3500/4500 have integrated bellhousings and require changing to a hydraulic clutch. Have to think about that a bit. Anybody done this and happy with the results?
Old 03-04-2015, 12:35 AM   #86
T.W.Dustin
T.W.Dustin's Avatar
Well after thinking it all through, and considering that I already have the adapter plate from Hamilton Intakes, I am looking for an 85-91 S10 T5 with a mechanical speedo. They are not as prevalent as I expected. Called a few junk yards and have been searching Craigslist and there isn't anything available yet. This should be easy but hasn't been.
Old 03-07-2015, 11:39 AM   #87
TJ's Chevy
TJ's Chevy's Avatar
They are out there. Just make sure its the V6 version and not the 4 cylinder version.
Old 03-07-2015, 06:03 PM   #88
T.W.Dustin
T.W.Dustin's Avatar
I have located a '91 5 speed from a 2WD 4.3L V6 S10. It is in SW CO where I have friends - I just need to grab it next time I am in the 4 corners area. $150 seemed very fair for a good working unit.
Old 03-10-2015, 08:21 PM   #89
T.W.Dustin
T.W.Dustin's Avatar
After thinking more I decided to go the POR15 route and picked up a quart. If I need more I know where to get it locally now. If this thing ever ends up in a wetter climate it will be a good thing. Using the semi-gloss black. Doing the suspension and crossmember too.
Old 03-11-2015, 12:19 AM   #90
Mjminino
Yeah i just got a bunch of parts that i need to 15, tie rod ends, pitman and idler arm, captian fabs ps bracket and his impala ss caliper brackets and a cardone ps box.
Old 03-26-2015, 02:40 PM   #91
T.W.Dustin
T.W.Dustin's Avatar
Still working on the cab in the garage.
It's coming along nicely! I decided to the replace the "crushed" passenger side rocker entirely. Here is what I found underneath after a quick brush with the wire wheel. I guess I will POR15 all the inside stuff to avoid future rust. Pretty clean for 51 years!
Old 03-26-2015, 03:07 PM   #92
TJ's Chevy
TJ's Chevy's Avatar
When I received my email notification and read "Look what I found under the rocker panal" I was hoping to see a pile of gold.
Old 03-26-2015, 03:18 PM   #93
T.W.Dustin
T.W.Dustin's Avatar
Hey TJ, if it was all rusty it would be a pot o'gold to fix it so it is "gold" to me
Old 09-05-2015, 11:06 PM   #94
T.W.Dustin
T.W.Dustin's Avatar
Well after a long hot summer I finally had a "under 100 degree" day to get something done. My son came for the weekend and we got a few hours on the truck today. The Suburban front suspension swap went exactly as advertised. All the mating areas were POR 15'd in advance. I have the Captain Fab brackets for the PS and still need to attach the sway bar, etc.. I will also be converting to 6 lug rotors that I have already sourced from Summit.
Old 09-14-2015, 03:10 PM   #95
T.W.Dustin
T.W.Dustin's Avatar
I installed the PS box using the Captain Fab bracket. Well made bracket and no surprises during installation.
Old 09-14-2015, 03:34 PM   #96
TJ's Chevy
TJ's Chevy's Avatar
Looks good.
Old 09-17-2015, 10:02 AM   #97
Stickman
Stickman's Avatar
Just stumbled across your build. Yes it has been a long hot summer but it's starting to cool off a bit. Looks like your moving along and it looks great.
Stickman is offline   Reply With Quote
Old 09-17-2015, 12:25 PM   #98
T.W.Dustin
T.W.Dustin's Avatar
Howdy neighbor!
