Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 04-12-2018, 11:20 PM   #76
Captainfab
60-66 Nut
Re: 6 Lug Rear Disc with 15" Wheels and an E-Brake
I'll have to take a look and see if I can ship the trailing arm mounts in the same box as the rear disc brackets. I will let you know.
Old 04-13-2018, 11:37 AM   #77
TheBrewery
TheBrewery's Avatar
No worries if not, last night a local guy told me he has a set. I can paypal you the $$, is the price the same with the substituted parts?
Mike
1960 C10 Short Step 235 w/ 3 on the tree
1999 Mazda Miata <- Track Car
2016 Chevrolet Colorado z71
2016 Chevrolet Traverse - Wifes Car
2014 Honda CBR500R <- Also A Dust Collector
2009 Suzuki GSXR600 <- Stolen
TheBrewery is offline   Reply With Quote
Old 04-13-2018, 10:54 PM   #78
Captainfab
60-66 Nut
The trailing arm mounts will fit in the medium box along with the rear disc brackets. I will send you a PM with ordering and payment info.
The base plates with a different hole pattern does not change the cost of the rear disc brackets.
Old 06-15-2018, 11:02 PM   #79
TR32
TR32's Avatar
Has anyone found a set of brake lines and used them for this setup?
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg...........
TR32 is offline   Reply With Quote
Old 06-16-2018, 01:26 AM   #80
Captainfab
60-66 Nut
So neither of the suggested hoses on the parts list are working for you?
Old 09-09-2018, 08:39 PM   #81
Blazerowner
Blazerowner's Avatar
I’m interested. How does the stopping power compare to the drums?
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 09-09-2018, 11:54 PM   #82
Captainfab
60-66 Nut
Hopefully someone that has bought these and installed them will chime in......
Old 06-17-2019, 11:33 PM   #83
Chuck78
You don't make a kit to fit the Dana 44 GMC truck rear ends, do you? Does this fit them???
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 06-18-2019, 11:22 PM   #84
Captainfab
60-66 Nut
No I do not make a rear disc conversion for the 6 lug Dana 44. No, this bracket set is designed for the '64-'82 GM truck 12 bolt or '79-'87 GM truck 10 bolt. You are the second to ask about this in about a month, but before that I have not had a request for. If I were to develop a rear disc bracket set for the Dana 44, I would use the '79-'85 e-brake caliper. But now you have posted elsewhere discouraging people in regards to the '79-'85 e-brake calipers. I have not seen that they are hard to find, nor have I heard of anyone having a hard time finding them.
Old 11-18-2019, 06:01 PM   #85
Treybizttu
Are these brackets still in production?
Thank you...
Treybizttu is offline   Reply With Quote
Old 11-18-2019, 11:38 PM   #86
Captainfab
60-66 Nut
I fabricate all of my products everyday. This is one way I attempt to make a living. As long as the thread isn't closed, the parts are available.
Thank you...
Old 01-02-2020, 08:13 PM   #87
70GM
Any word yet on how to hook up the ebrake with this setup? Just curious if someone has determined a way to use the stock ebrake cables.
70GM is offline   Reply With Quote
Old 01-02-2020, 10:26 PM   #88
Captainfab
60-66 Nut
I don't think the stock e-brake cables for your drum brakes can be utilized. You will have to go with a custom set of cables.
Old 01-19-2020, 09:11 AM   #89
CUSTOM/10
CUSTOM/10's Avatar
I have a stock 6lug 72 12 bolt 4x4 and would like to get a set of brackets for my application with gloss black powder coat. Can you pm me with a total cost and payment info. (PayPal )
Thanks Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-19-2020, 10:59 PM   #90
Captainfab
60-66 Nut
PM sent
Old 07-06-2020, 02:22 AM   #91
54Caddy
GM Addicted
54Caddy's Avatar
I see you reference a GM metric caliper and showing photos of front calipers test fitted. What GM metric calipers are those if their not D52 calipers. Are they D154?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-06-2020, 09:46 PM   #92
Captainfab
60-66 Nut
Yes the '78+ Metric calipers are the D154 calipers.
Old 12-09-2021, 08:39 PM   #93
jzorn94
I'd like to order a set of brackets.
jzorn94 is offline   Reply With Quote
Old 12-09-2021, 09:11 PM   #94
Captainfab
60-66 Nut
PM sent.
Old 03-17-2022, 07:16 PM   #95
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 11-09-2023, 02:10 PM   #96
burnie6bt
burnie6bt's Avatar
Here are some assembled pics. These 3 pics are with a typical '78+ metric front caliper.
Captainfab, I purchased a rear disc kit a few year ago for my 1972 c10 using the AWD Astro Van front rotor and the D52 caliper.
I am looking at converting to a 6x5.5 rear axle. Would it be as simple as swaping my axles and using the later chevy truck rotors as mention in this kit? Or do I need to change the spacing, calipers, and rotors?
burnie6bt is offline   Reply With Quote
Old 11-09-2023, 04:42 PM   #97
Captainfab
60-66 Nut
Sorry but no it is not that simple. There is no such thing as a 6 lug rotor that has the exact same dimensions as the Astro/Safari rotor. Everything must be changed including the brackets. The only bracket that is the same are the base plates.
