Old 05-10-2015, 10:44 AM   #76
Henney
Re: Simple '49 Truck
Rear wheel offset is looking tight on the outside. More to come.
Henney is offline   Reply With Quote
Old 05-11-2015, 11:13 AM   #77
Henney
So the rear is tight. Looking at a couple options to fix it. Worst case a couple rear wheels will be for sale.
Old 05-11-2015, 08:51 PM   #78
Advanced Design
Advanced Design's Avatar
Too bad about the wheels. The truck looks very nice!
Advanced Design is offline   Reply With Quote
Old 05-12-2015, 03:44 PM   #79
scotts72heavyhalf
scotts72heavyhalf's Avatar
Looks like Bruce is doing his usual killer work! I just picked up a 51 this weekend I`ll have to get togather with you so I can drool on your truck!
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 05-12-2015, 05:13 PM   #80
Henney
Thanks fellas. Rear wheel solution = grind off the centers and move them forward an inch.
Old 05-26-2015, 10:13 AM   #81
Henney
Making good progress, the truck is now back at my place for wiring and to get the engine running. Sheet metal is more or less all on. There is a hood fitment issue I’m working through now but it’s way closer than it was last week. I have about an 1/8th gap on the driver’s side hood-to-fender line but more like 3/8th on the passenger side. I think it’s play in the hood support assemblies and worst case I’ll have to kick the radiator support over.
I was able to get the floor covered last night with Raptor Liner and once it’s had a day or two to setup nicely I’ll be starting the wiring. Also got the front speakers located in the kick panels.
Does anyone know where to get a window regulator spring? The big one pictured not the little one that goes behind the crank.
Old 05-26-2015, 06:50 PM   #82
lower50's
lower50's's Avatar
Wow sweet truck. That went really fast, when do you sleep lol. What color red is that?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-27-2015, 04:13 PM   #83
Henney
I gotta say that a very large portion of all that work is Bruce, not me. i just made sure all parts were thought out and available when needed. now that it's back home. sleep is limited.
Not sure the actual color of red. it looks more like a rust in real life than what shows up in those photos.
Old 05-27-2015, 06:22 PM   #84
Sim6
Sim6's Avatar
Looks great
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 05-27-2015, 07:28 PM   #85
FarmerSid
FarmerSid's Avatar
Why do you think you need a new spring? Raptor liner looks awesome! I'm going to do the same. Would you mind getting some box to cab measurements for me if you have a chance? Have any new plans for the rear wheels seeing that they were too wide?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-27-2015, 08:14 PM   #86
Dan in Pasadena
Dan in Pasadena's Avatar
Henney,
Everything looks great. Was the Raptor bed liner applied by roller or by spray gun? I assume one of those schutz type guns(?). Does one of those take a huge amount more volume of air than a conventional automotive spray gun or HPLV gun?
Last, did you strip to bare metal (apologies if it's been mentioned and I missed it) and primer it or put it over bare or un-prepped old paint?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-27-2015, 08:47 PM   #87
99 to Life
99 to Life's Avatar
Not to hijack here, truck is looking mighty nice. I just seen eastwood offers a sound deadner/ rust inhibitor coating that requires no primers and can withstand extreme heat. its like 200 for the gallon but I think it's worth a try considering bedliner brands are near 100 gallon, then the sound deadner adds about that, plus the time putting them on.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-28-2015, 12:37 PM   #88
Henney
Sid,
I need a new spring because the window regulator I have doesn’t have one. The driver’s side has one and the passengers is missing. I think i found one for a '38 chevy car that will work. I’ll try to remember to get dimensions tonight.
The wheels are steel so we’re going to cut out the center move it forward an inch and weld it back in. It’s the cheapest, quickest fix so figured we’d start there. If it doesn’t work hopefully I can sell them and will have to order new ones.
Dan,
I sprayed in the liner with the gun that comes with the kit. Bought it off Amazon for cheap. I just have a little pancake compressor at the house and it ran the entire time but kept up. I had the gun set at around 50psi. The cab was sand blasted and primed before getting painted so I had a clean surface to start with.
99,
Are you talking about lizard skin? If so I considered using it but just couldn’t get myself to pull the trigger. They have both a thermal and acoustic mix and using both of them is spendy.
Old 05-28-2015, 04:35 PM   #89
lower50's
lower50's's Avatar
1951 MG TD
Old 05-29-2015, 11:20 AM   #90
99 to Life
99 to Life's Avatar
No, diff product. I'm familiar with lizard skin. very popular stuff.
here is the link
http://www.eastwood.com/promotions/r-d-corner.html
Old 06-04-2015, 09:19 AM   #91
zteca
Junior Member
Nice work! Quick question, Did you have to modify the firewall to clear the 6.0?
zteca is offline   Reply With Quote
Old 06-05-2015, 10:00 AM   #92
Henney
We put in a tunnel to clear the tranny and a small notch for the driver side fuel rail. Probably could have gotten by without the notch.
Old 06-08-2015, 01:52 PM   #93
Henney
Got a bunch of work done over the weekend but not a whole lot of pictures to show for it. Big thank you to Chizzler for helping me figure out the hood/fender alignment. I struggled for days trying to get that but it looks great now.
Grill is in, exhaust is complete, engine fired over the weekend and went smooth. My wife wasn’t super impressed by the Thrushers but I was. Dove into bleeding the breaks and made decent headway. Found and fixed all the leaks. Got the first pass at bleeding done but the pedal never did harden up. I’ll be working on getting the body wiring complete this week.
If I could figure out how to upload video I'd post the engine starting.
Old 06-09-2015, 01:58 AM   #94
lower50's
lower50's's Avatar
Make sure the master has no air, Had that on my Jeep found a little bubble.
Congrats on the engine, it's exciting to hear them with exhaust for the first time.
1951 MG TD
Old 06-09-2015, 09:31 AM   #95
99 to Life
99 to Life's Avatar
congrats on the progress. Every time my MC wasn't bled, it wouldn't even let fluid out to the calipers. I'd take the MC off bench bleed it and instantly have fluid to the lines. Mine usually hardened up pretty quick. Can't wait to hear the engine.
Most guys usually just upload the video to youtube (have to create and account) then just post the link here. Use to be able to embed the whole video here, but seams like that doesn't work anymore.
Old 06-09-2015, 11:19 AM   #96
Advanced Design
Good progress! First engine start is always exciting. Hope you can share the video.
Old 06-25-2015, 10:16 AM   #97
Henney
Wasn't ever able to figure out the video which sucks because now I have a new one of the first time driving. Pretty excited to say she left the garage for the first time under her own power. It went well, probably didn’t get above 20 and I know it didn’t leave 2nd but everything felt good. I did screw up and not have enough tranny fluid so it got interesting for a second. 7 qts later and we were moving.
Brakes worked out well which have been a pain over the last couple weeks. Bleeding them wasn’t fun, there’s a small leak from the proportioning valve, and the pedal throw might have to get modified. Under emergency braking the brake arm will crash into the headers before bottoming out the master cylinder.
My heater core also blew last night. It was the original core and had been working but I guess she decided it wasn’t meant to be. I’ll be getting a new re-pop’d one because the heater, in my opinion, is one of the cooler features of the truck.
All of the electrical is complete and I’ve moved onto the stereo. Will be running an alpine deck and amp with a JL 12” sub and component speakers. Should sound pretty good. I also ordered up RAMmat yesterday which after some pretty good research seemed to fit my goal and budget nicely.
I also got a 12V electric wiper motor installed. Went with the Newport unit which just like everyone says bolts directly into place and was super simple. I had it in, wired, and running in under an hour.
This week’s moving to getting the windshield and rear glass in. finish out the door windows and deadbolt locks. And then finish up the stereo. I also gotta get my rear wheels back from Bruce.
Old 06-25-2015, 10:47 AM   #98
99 to Life
99 to Life's Avatar
congrats, fastest painted truck build iv seen! yeah the OG heaters are def cool, but are very troublesome. There are always something on a build that will fight or haunt you. I guess some more than others. You'll get em all ironed out.
Old 06-25-2015, 03:28 PM   #99
Henney
Thanks 99. If you go back to my original schedule you all were making fun of me for I'm off a month. When all said and done I'll be off about 7 weeks.
Old 06-25-2015, 04:01 PM   #100
99 to Life
99 to Life's Avatar
Well Henney, you ever hear of something called RUST!!!!! that will put a beating on some timeframes. If you want I can send you pics of my deadbolt design, if you haven't gotten one yet. Just shoot me a dm if you need.
