12-13-2016, 08:05 PM | #76 |
Re: 1964 C10 build
Update !!! not sure why so many pictures are not available, Maybe someone can chime in on this.
http://67-72chevytrucks.com/vboard/s...d.php?t=649661 |
12-13-2016, 08:09 PM | #77 |
Re: 1964 C10 build
Ok, here are some pics of the SLOW!!!! progress made. Sorry, been traveling with me job. Gotta pay for the truck some how.
AC mocked up !!
12-13-2016, 08:11 PM | #78 |
Re: 1964 C10 build
12-13-2016, 08:13 PM | #79 |
Re: 1964 C10 build
12-13-2016, 08:15 PM | #80 |
Re: 1964 C10 build
12-13-2016, 08:22 PM | #81 |
Re: 1964 C10 build
Started woking on the bed. Got all the wood mounted, gas tank filler installed, then took it all back apart to stain. Wood is Yellow Pine bought at Home depot, cut and drilled at home.
Sat the bed on it just to get a peek. I like the stance in the back. Stained the wood. Gotta get back home this weekend and put the Satin finish on it.
12-29-2016, 10:48 PM | #82 |
Re: 1964 C10 build
12-29-2016, 10:50 PM | #83 |
Re: 1964 C10 build
12-29-2016, 10:52 PM | #84 |
Re: 1964 C10 build
12-29-2016, 10:53 PM | #85 |
Re: 1964 C10 build
12-29-2016, 10:59 PM | #86 |
Re: 1964 C10 build
Looking good
You can find me on Instagram @neveno_cten |
12-30-2016, 12:23 PM | #87 |
Re: 1964 C10 build
Following. This thing is turning out pretty sweet!
12-30-2016, 02:01 PM | #88 |
Re: 1964 C10 build
Beautiful truck! Love the orange.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
12-30-2016, 02:32 PM | #89 |
Re: 1964 C10 build
12-30-2016, 02:33 PM | #90 |
Re: 1964 C10 build
Its taken me 2 1/2 years, I feel that I'm still so far away, but I know I'm not.
12-30-2016, 02:35 PM | #91 |
Re: 1964 C10 build
I have always liked that color as well. I was very happy to find one that wasnt destroyed.
12-30-2016, 02:51 PM | #92 | |
Re: 1964 C10 build
My plans have also changed in the interim & I'm upgrading the power-plant to shred some rubber. It never ends. x2 on the patina color it has....
12-31-2016, 12:53 AM | #93 | |
Re: 1964 C10 build
Heres what I did with my exhaust. I don't like the bends, but its not a Hi-Po engine or anything.
04-13-2017, 08:35 PM | #94 |
Re: 1964 C10 build
Started fixing all the bare spots and trying to keep that Patina look.
[URL=http://s1269.photobucket.com/user/sickfast1964/media/64%20chevy%20truck/IMG_0010_zpswpg6oyv7.jpg.html][IMG]http://i1269.photobucket.com/albums/jj583/sickfast1964/64%20chevy%20truck/IMG_0010_zpswpg6oyv7.jpg[/I
04-13-2017, 08:37 PM | #95 |
Re: 1964 C10 build
04-13-2017, 10:40 PM | #96 |
Re: 1964 C10 build
Great to see you back
04-14-2017, 08:57 AM | #97 |
Re: 1964 C10 build
I tried to put my glass in before I went out of town for the week, but the seal was too big, and did not fit correctly. So I called the glass company back and they will be out Monday morning to get r done. Why cant aftermarket **** fit right??
04-14-2017, 09:00 AM | #98 |
Re: 1964 C10 build
http://s1269.photobucket.com/user/si...plo9y.jpg.html
Also found out I assembled this incorrectly... can you see what I did wrong??
04-15-2017, 01:53 PM | #99 | |
Re: 1964 C10 build
Also, your upper ball joint bolts are installed wrong. The bolt head goes on the underside and the nut goes on top. The reason why is when you fully grease the balljoints, the boots will swell and tend to rub on the sharp threads of the bolt sticking out of the nut if you install them the way you have. That's also why the bolts have lo-profile heads rather than normal tall heads. Most manufacturers of ball joints put a little instruction sheet in the box (which no one reads) that explains this. |
04-15-2017, 03:15 PM | #100 |
Custom Truck Lover!
Re: 1964 C10 build
looks great! nice work.
Squarebody guy |
