01-21-2015, 07:10 PM | #76 | ||
Re: timing
yoshi's 49 project |
01-21-2015, 10:01 PM | #77 |
Re: timing
I realized the receipt says 8" but often times those numbers are generalized. 7.75" would qualify as an 8" balancer.
I can remember the days when I stayed awake too late, too many nights working on my truck. I used to take long road tests at work during the day so I could nap. |
01-21-2015, 10:11 PM | #78 |
Re: timing
02-01-2015, 02:03 PM | #79 |
Re: timing
#17
02-01-2015, 10:29 AM chevy49 Junior Member Join Date: Jan 2015 Posts: 10 I Had another look at the truck today in between the snow showers. I fitted piston stop & turned the engine with a socket & ratchet. The engine came to a stop right at the end of the timing tab I would say 15deg BTDC. I then turned it the other way & it stopped 2 2/8" away from 0deg BTDC. Would that mean I have the wrong timing tab?
02-01-2015, 03:17 PM | #80 |
Re: timing
It should stop at the same place if you turn it one full turn each way. If you have that much variance your stop is off, probably too deep if you cannot turn the engine thru TDC. One you find the TDC you can make a mark on your balancer relative to 0 on the tab installed and proceed from there to check timing.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-01-2015, 03:35 PM | #81 | |
Re: timing
02-01-2015, 04:00 PM | #82 | |
Re: timing
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
02-01-2015, 05:55 PM | #83 |
Re: timing
1project, you are right, I was assuming he had it set for absolute TDC. It will stop short on either side the same distance from TDC so center in between is actual in relationship to balancer.
02-02-2015, 03:54 PM | #84 |
Re: timing
I've remarked the balancer using the piston stop as you can see in the pic. I've also taken a pic of the distributer with a piece of alloy to show which way its pointing
02-02-2015, 05:25 PM | #85 |
Re: timing
Looks good to me.
02-02-2015, 06:35 PM | #86 |
Re: timing
That's definitely in the ballpark.
The more accurate you are with TDC on #1, and timing your distributor, the easier ignition is to manage.
02-02-2015, 06:38 PM | #87 |
Re: timing
I just hope my 8" balancer isn't on the move
02-02-2015, 07:04 PM | #88 |
Re: timing
If you suspect your balancer is separating (outer ring coming loose) then replace it before it does. Sometime before it breaks free and grenades itself inside your engine bay (another reason I like balancer covers with timing marks printed on them) you will notice excessive and increasing vibration coming from the engine - this is your balancer deconstructing itself.
Otherwise, I don't know what you mean by "on the move"
02-02-2015, 07:22 PM | #89 |
Re: timing
That's what I've been told is a possible reason for the TDC mark being where it is. Is it possible that a 305 8" balancer could've been fitted by mistake?
02-10-2015, 05:34 PM | #90 |
Re: timing
Finally got some time on my truck, I couldn't start it so I decided to bite the bullet & fit the HEI distributer that I have sat in its box. It was too late last night to turn the key after fitting it. I made sure everything was ready then tonight I tried again, she started the instant I turned the key but only for a few seconds. A few tries again & it was running. The new mark that I'd made was too far after TDC but the original was at about 6 deg BTDC so I turned the dizzy to get 12deg. I then took it out for a short run. All seemed well at first then I noticed the smoke coming from the rear of the cab which turned out to be an oil leak from around the timing cover area & getting burnt on the headers. It also suddenly started making a noise inside the carb. Which seemed to stop just as I arrived home. Will have to check back on that one. After cleaning up & packing everything away I noticed the dial on the rear of the timing gun was on 33 so what I've done was wrong. I went to start the engine again but it seemed as if the battery was flat but when I checked I've got 12.6v. So I assume it's struggling to turn over due to timing.
02-16-2015, 03:33 PM | #91 |
Re: timing
3100 v8 vacuum test:*http://youtu.be/jeezGuFLCF4
as you can see on tickover its jumping around, when i increase the rpms it settles down
02-16-2015, 04:49 PM | #92 |
Re: timing
vacuum gauge jumping around at idle means the timing is to far advanced, back it off a bit
02-16-2015, 05:02 PM | #93 |
Re: timing
At the moment I have the dial on my timing light set at 32, & I adjusted the timing till the mark on the balancer went to 0 deg. Should I set the dial to 30 then reset to 0 deg again?
02-16-2015, 05:16 PM | #94 |
Re: timing
no, while the engine is runniung just back the timing down till the vacuum gauge stops jumping. that should put your timing at maximum at idle. now for full advance timing turn the timing dial till the balancer zeros while revving at 3000 rpm. that will tell you what your total timing is. should be about 32 to 34. if not, your distributor will need some recurve work.
02-16-2015, 05:18 PM | #95 |
Re: timing
Oh wait, your vacuum gauge is jumping around at 3100 rpm?
02-16-2015, 05:20 PM | #96 |
Re: timing
I mistook that gauge jumping around at idle.
02-16-2015, 05:21 PM | #97 |
Re: timing
It's jumping around at tickover less than 1000 rpm
02-16-2015, 05:25 PM | #98 | |
Re: timing
02-16-2015, 05:27 PM | #99 |
Re: timing
Seems like No.6
02-16-2015, 05:27 PM | #100 |
Re: timing
Ok, jumping around at idle also means to much timing
