Old 12-30-2015, 05:14 PM   #76
Scott2
Re: 1949 AD truck 'Chevy-49'
Originally Posted by Chevy-49 View Post
@ Rob,
Thanks for your tip about the cab ventilation, I drove the truck several years ago and did not drive with the vents open, hmmm... maybe electric windows will help.
@ Scott2
Thanks, that's the way I did get also all the information I need(ed).
This week bought a new welder, tried a lot of (test) welds to get the settings right, first welds to the cab:
Left cab corner is also in, need to trim the door gap later.
Fuel filler patch is in.
Great pics, love the progress and nice work! I just cut open the right side cab corner last night and started looking at the gas filler hole as well! Can you expand on your comment about the cab corner and door gap and maybe post a pic? I'd like to know what I'm heading into.
Now that you've done the corner is there anything you'd do different next time?
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 12-30-2015, 05:35 PM   #77
reaper71
reaper71's Avatar
You have done alot of metal repair already,looking good..
I know the feeling, I had all the same rotted spots as you did on my truck.
I ended up making most of my pieces rather than buying new patch panels (lack of cash ) new patches make the time cut in half.
Nice progress so far will be watching..
Mark...
reaper71 is offline   Reply With Quote
Old 12-30-2015, 06:24 PM   #78
Chevy-49
Chevy-49's Avatar
The right rear cab panel was not as bad as the left side, the patch panel are not perfect, see pictures.
I will put on the doors first and trim the patch panels to fit the doors.
Same problems with the cowl panels. I did not weld the with the left and right outer cowl panels in yet. (see post 47)
Close up:
My build thread: 1949 AD truck 'Chevy-49'
Chevy-49 is offline   Reply With Quote
Old 01-12-2016, 11:49 AM   #79
Bomp
Bomp's Avatar
I had a similar problem with my replacement panels. Nothing like a pie cut to make things fit.
Sub'd
Bomp is offline   Reply With Quote
Old 01-12-2016, 12:15 PM   #80
Chevy-49
Chevy-49's Avatar
Sub'd
Thanks, I have read your build also, can't wait to get the cab on the frame, putt the doors in and see how many cuts I have to make.....
Have to finish the firewall and top cowl vent first....
Old 01-15-2016, 09:52 PM   #81
Tikal48
Tikal48's Avatar
Your truck is looking great! You've been making some good progress.
I closed the cowl vents on mine also. I think it makes a cleaner look.
Tikal48 is offline   Reply With Quote
Old 01-24-2016, 11:28 AM   #82
Chevy-49
Chevy-49's Avatar
Thanks Tikal48, I also like the cleaner look and had some problems with water coming into the cab.
Cowl vent patch welded in :
Old 01-24-2016, 11:49 AM   #83
aknovaman
What brand MIG did you buy? Cebora 140 amp ?
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 01-28-2016, 11:19 AM   #84
Chevy-49
Chevy-49's Avatar
Hello Aknovaman, sorry I'm sure that I answered your question, think I hit the wrong button,.....
It's A Cebora EVO 160 M (28-160A)
http://www.cebora.it/art_495_dati_tecnici_uk.html
Richard
Old 02-14-2016, 05:57 AM   #85
Chevy-49
Chevy-49's Avatar
Today finished firewall, welded seams flush
Had some small holes om left and right lower corner of front windows.
Need to make a patch for the left mirror bracket.
Stripped (handles and trim) the right door, tommorow I will get the door in and see what I have to fix.
Old 02-14-2016, 04:25 PM   #86
Chevy-49
Chevy-49's Avatar
Right door is in.
Gaps need a little adjustment, i like the first set up.
Door needs a little work also, will patch the speaker hole and bottom of the inner door.
Old 03-08-2016, 12:16 PM   #87
Steve-W
Steve-W's Avatar
Door looks nice and tight, great first attempt
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 03-13-2016, 02:52 PM   #88
Chevy-49
Chevy-49's Avatar
Had a short break (vacation), this weekend started to make a patch for the left top cowl and welded it in.
Have to drill some new holes tonight en test fit the mirror bracket.
Fixed the door gap on the bottom rear corner of the door. I'm Happy how it turned out.
Old 03-13-2016, 02:55 PM   #89
dug224
dug224's Avatar
Keep the pictures coming. Nice build. dug
dug224 is offline   Reply With Quote
Old 03-17-2016, 03:00 PM   #90
Chevy-49
Chevy-49's Avatar
Had to do something else, because the left door is a real struggle to set right.
Drilled some holes for de mirror brackets.
Also, bought another door, need the inside skin to fix the 'speaker' holes.
Old 03-17-2016, 08:18 PM   #91
NorCalGal
NorCalGal's Avatar
Lots of useful information, I'm subscribed
Jan's 53
NorCalGal is offline   Reply With Quote
Old 03-29-2016, 02:59 PM   #92
Chevy-49
Chevy-49's Avatar
The left door is in as good as its gets, did modify the new hinges.
Drilled new holes in the lower hinge and shorten the upper hinge.
As I remember the door did always hit the rear cab panel, as shown on the picture.
So time to cut the rear cab panel, drill out the spot welds, remove rust between the panels.
Old 04-23-2016, 12:12 PM   #93
Chevy-49
Chevy-49's Avatar
Today did some welding at the left rear cab corner, fixed the door gap.
Need the fix the bottom rear cab corner, nice job to do tomorrow.
Bought also a set Dynamat, I will start to put it inside off the doors.
Old 05-02-2016, 12:43 PM   #94
Chevy-49
Chevy-49's Avatar
Today made a patch panel for the speaker holes in the door, I will also fix the bottom of the door.
Bought a patch panel for the bottom, need to trim the patch and the door.
Old 05-02-2016, 02:57 PM   #95
Chevy-49
Chevy-49's Avatar
Any tips how to remove bottom of the inside door?
Is the lip spot welded, or just bend ?
Grind the lip off and make / weld a new one in.
My outer skin seems OK and will not be replaced.
Old 05-02-2016, 03:51 PM   #96
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
I am looking at this repair myself, any tips would be much appreciated!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 05-02-2016, 10:40 PM   #97
Tikal48
Tikal48's Avatar
Chevy 49,
The truck is looking good. The bottom lip on the door is just bent. I replaced the inner and outer skins on one of my doors, so I just ground the bottom lip off. I have to get back to my other door, but I'm off on other tangents at the moment.
Good luck and keep up the good work!
Old 05-02-2016, 11:07 PM   #98
Flysocal
Really nice patch work especially with the inner door. Lots of work getting the perfect matching bends in the sheet metal good job. Following your build.
Flysocal is offline   Reply With Quote
Old 05-03-2016, 12:37 PM   #99
Chevy-49
Chevy-49's Avatar
The lip is not welded, just bend as Tikal48 mentioned (thanks Tikal48) but in my case the lip too much rusted to use again.
I did ground the edge off and will try to weld the seams together.
I did also buy a damping material (Dynamat) would it be a good idea to put inside of the doors right now?
Bottom is open for easy access....
What do you think? ....
Left door bottom patch is ready to weld in.
Right door speaker hole patch is also ready to weld in.
Right door bottom patch is almost ready, thinking about pressing a recces in.
