Old 07-16-2016, 02:55 PM   #76
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1949 Chevy 3100 Build Thread
Looking good...love those split bumper cars...
Old 07-16-2016, 05:07 PM   #77
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool build!
ChuckDriver is offline   Reply With Quote
Old 07-27-2016, 10:38 PM   #78
Flysocal
Thanks for the comments. I didn't start this build thread to stroke myself. I really like positive criticism. I'm learning as I go so please don't hesitate to comment or provide suggestions.
Continuing with the Cab theme. Been working on doors. The plan is to run Altman bear claws. With a 80-90s vintage keyed lock on each door. Would also like to figure out a way to lock the doors from the inside the same way as stock. Still thinking this stuff through. In the meantime I ordered glass from Classic Truck Glass. They have a frameless kit for 47-51 I ordered it in smoke.
Flysocal is offline   Reply With Quote
Old 07-27-2016, 10:44 PM   #79
Flysocal
Repaired a bung on the hood. Installed it to check fit. Gaps are a bit big but the hood/spring/hinges function as they should. I didn't spend much time making adjustments so I'm confident I can get it tighter with a little massaging.
Old 07-31-2016, 12:52 AM   #80
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
trucks coming together nicely. I remember seeing someones post on here about modifying the Altman latch to lock from the inside. I will see if I saved the page or not.
GreasyLikeaBurger is offline   Reply With Quote
Old 07-31-2016, 03:45 PM   #81
Flysocal
That would be helpful thank you
Old 08-01-2016, 04:04 PM   #82
kustombrad
kustombrad's Avatar
Very nice!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 08-02-2016, 08:17 PM   #83
Flysocal
Started on Altman door latches. Mocked it up but couldn't get too far since I'm waiting on handles.
Old 08-02-2016, 08:21 PM   #84
Flysocal
Spent way too much time trying to make newer style keyed door locks work. After a couple of attempts I decided to graft repop to new using JB weld. I hope it's strong enough!
Old 08-09-2016, 06:36 PM   #85
Flysocal
Right side door latch went together easily. Driver side giving me problems. After hours of adjusting I realized it wasn't me it was the door latch. The pawl wasn't machined properly it was binding on the post causing door to not open and close smoothly. Trique confirmed they had a bad batch of pawls and I needed to grind it down. What a royal pain! This kit is going to work out but its far from a bolt on kit. Repop door handles need some grinding to fit not sure about original handles. Got the exterior locks working nicely. These are a 90s vintage GM lock with keys to match my ignition. Both sides are done now I need to figure out how to make locks work from the inside.
Old 08-23-2016, 11:50 PM   #86
Flysocal
User UK 51 had success making Altman door latches lock from the inside here is the thread http://67-72chevytrucks.com/vboard/s...d.php?t=520589 I tried this with no success. Having the doors lock from the outside make it more complicated and I decided it wasn't worth the hassle. Here is a pic of a truck with Impala tail lights in the roll pan that I'm using for inspiration.
Old 08-24-2016, 12:00 AM   #87
Flysocal
I'm going to run a similar setup. I purchased a 65 Impala trunk lid and grafted the tail light mounts into my roll pan. I don't have the tail lights yet but plan to get led lights from United pacific and mount them upside down. The outer lights will be turn/stop/drive. The inner lights will be backup. Picked up mockup lights off eBay and glad I did. They have some wierd angles on them!
Old 09-08-2016, 10:49 PM   #88
Flysocal
Retuned the United pacific led tail lights to summit. They were cheap Chinese junk. Ordered licensed gm tail lights also Chinese made unfortunately but fit much better. The cutout is for a hidden trailer hitch behind the flip up plate.
Old 09-08-2016, 11:18 PM   #89
Tikal48
Tikal48's Avatar
Good job on the tail lights. These look great! I've spent months trying to decide on what tail lights I wanted to use. Sadly there is not a lot of choices for aftermarket tail lights out there. I wanted something glass, but what I found did not work with where I wanted to mount them. So I bought Chinese also. . . LOL
Tikal48 is offline   Reply With Quote
Old 09-09-2016, 09:58 AM   #90
Advanced Design
Advanced Design's Avatar
Great work on the tail lights! Getting the mounts from a deck lid was a good idea.
Advanced Design is offline   Reply With Quote
Old 09-12-2016, 03:45 PM   #91
PurdueSD
PurdueSD's Avatar
Interested to see where this goes! Keep it up!
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 09-23-2016, 11:04 AM   #92
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
AWESOME!! Looks killer
--Josh
Old 09-23-2016, 11:50 AM   #93
HUSSEY
HUSSEY's Avatar
I was never a big fan of roll pans but now I think I am. Adding the classic tail lights with some chrome trim really makes it look right for this era of truck. Nice work, it's going to look great!
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 09-24-2016, 01:10 AM   #94
Flysocal
Frame is back in garage. Cab bolted to frame. Man it feels good just having the cab on frame feels like progress. Scotts ifs crossmember welded in place it fit really nice. Spent some time on the rack and pinion. Rubber bushings left me scratching my head. They seemed too long but after some research the long side is compressed by the big washer and bolt and it mushrooms. Not intuitive at all!
I've been thinking about using polyurethane bushing throughout but I think I will stick with rubber because it should offer more vibration absorption. This will be a daily driver after all.
Starting to box the frame. Engine mount area is done. Tranny mount area tacked up. I don't want to get carried away with boxing until I figure out how everything bolts to the frame. Used weldable nuts for running board brackets and plan to do the same for anything that bolts to the frame.
Next project will be engine/tyranny mounting. My 5.3 is just jonesing to get mounted but I'm waiting for corvette crank pulley and water pump so I get adequate spacing between radiator, power rack and engine accessories. with any luck I won't need tranny tunnel.
Old 09-24-2016, 01:13 AM   #95
Flysocal
Old 09-29-2016, 03:09 PM   #96
Flysocal
The engine and tranny are now between the frame rails. Mounts aren't welded just getting clearance issues sorted. It's definitely tight need a tranny tunnel but looks like everything will work out fine. Block huggers fit. There is room for the steering shaft although it's gonna be fun figuring out all the u joints because it's not a direct hit to the steering column. Crank pulley is about an inch from the steering rack. Sure feels good to have the engine between the rails
Old 09-29-2016, 03:19 PM   #97
Flysocal
Any suggestions on steering linkage appreciated. My rack is 36 spline I believe so I'm thinking of using borgeson u joint with 36 spline to 1DD thinking of going with their vibration isolator joint at the rack. Run 1DD shaft under engine mount and headers then up just aft of headers.
Old 09-29-2016, 03:47 PM   #98
solidaxel
solidaxel's Avatar
FWIW I used rubber bushings on the rack and had a bit of PS fluid leak and now the rack bushings are junk !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-29-2016, 04:31 PM   #99
joedoh
joedoh's Avatar
borgeson is great stuff!
I am not a steering expert but is there a way to mount the spine side at the rack with a straight union and length of DD then just run two ujoints, one at the end of the DD and another at the column? seems to me that eveyone uses a center support and three u joints.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-29-2016, 08:32 PM   #100
oldman3
oldman3's Avatar
joedoh, on my rack set-up I have a u-joint and the rack, then DD the a u-joint at the column, will try to get pics tomorrow. Each set-up is different, depending on headers column, etc...Jim
oldman3 is offline   Reply With Quote
