Old 03-14-2016, 03:49 PM   #76
84blaze
Re: Project: Patina (1949 Chevrolet 1434)
Originally Posted by 99 to Life View Post
I have the same kit. I only bought it because at the time I had no electric in garage. But really I don't mind the kit. I actually prefer this style of set up because if you have problems with your rear end, swap it out in a couple hours and you are back on the road. No worrying about welding link bars onto the rear, just not a fan of that.
I remember reading somewhere on this forum that someone used a different style bag then what comes with the kit to start with. Was that you or someone else on the forum? I would like to use something other than the sleeve bag it has right now.
If anyone else has an idea where I could find that info please let me know!
84blaze is offline   Reply With Quote
Old 03-14-2016, 03:55 PM   #77
Layedoutsonoma91
Layedoutsonoma91's Avatar
I would def reccomend a bolt on kit to the axle, mainly if you need to swap the rear end like you said. Ready to see this thing together!
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 03-14-2016, 05:50 PM   #78
84blaze
It's honestly killing me. I've been saving up for a welder and some other parts and pieces. Im in the Canadian Forces and will be going on exercise for a few months coming up so not expecting much to get done till mid June.
I really need a garden shed to get my lawn and garden equipment and other odds and ends out of my garage to clear up my workspace. It's getting pretty full in there hah.
Old 03-14-2016, 06:08 PM   #79
lower50's
lower50's's Avatar
I don't see anything wrong with a bolt in kit if it works for you. I think lack of space is everyone's dilemma. My truck is just over 17' long and my garage is 20'.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-30-2016, 11:16 PM   #80
84blaze
Not much to update on this rig
Got some 4x4 tube to start making cab mounts with. I cant really make any until I decide where I want my cab to sit.
New (to me) wheels
Hope to tuck this hard when it's all said and done
I bought a 2001 2500HD 2WD 6.0L for cheap and it has been taking quite a bit of my time. I've been searching down some electrical gremlins which are driving me crazy. Its a full load truck with leather and power everything. Cant decide if I should leave it this height or drop it and get Detroit Steel Wheels to drill me some 8 lug steelies for it.
Old 03-30-2016, 11:17 PM   #81
84blaze
I actually did some work on this thing today.
I pulled the 5 window cab out of the storage tent and set it on the S10 frame. I have 4x4s under the rear cab mounts and 2-2x4s under the front. With it this high off the frame it looks like the running board will sit flush with the bottom of the frame rail, which is how I want it. The front will lay out and the rear will be close with the ride tech 4 link. When its all laid out it should have a bit of rake to it which is what I want.
Cut the factory mounts off:
Running board mock up
All tucked away for tonight
Old 03-31-2016, 12:17 AM   #82
Layedoutsonoma91
Very nice progress man! Looking forward to more
6.0 ls swap/4l80e
Past build thread
Old 03-31-2016, 10:58 AM   #83
99 to Life
99 to Life's Avatar
getting there. However if it were me, I'd be bolting the whole front clip on, and getting the truck on the ground for moch up. With the running boards. See your rubber that is on the cab? that should sit on very top of your running board. Helps to have bed on too because the rear and front fender will dictate where that running board goes. So basically your RB is up too high, i know its a moch up, but don't be alarmed if that RB goes below frame. My bracket for example is close to 4" below frame if I remember right. But I mounted my body very low to frame so I didn't have to notch rear etc.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-31-2016, 12:27 PM   #84
84blaze
Thanks for the advise man. This is my first time doing this swap so it'll be a learning progress throughout.
Old 03-31-2016, 12:28 PM   #85
84blaze
Thanks dude. Its nice to finally see the cab on the frame and gives me some motivation.
Old 03-31-2016, 12:56 PM   #86
99 to Life
99 to Life's Avatar
been in your shoes, this site has helped so much. Def just bolt the front metal on and get bed in place with running boards. that way you can set up how far back or forward you want the cab and wheel alignment. Then it will dictate how high you want to mount your body off frame.
Old 03-31-2016, 11:33 PM   #87
HUSSEY
HUSSEY's Avatar
+1, that's how I did mine. I set my cab and mounted my front sheet metal to get the front wheels set in the center of the wheel well.
When all said and done, my cab mounts were exactly 2 in. forward of the oval hole in the side of the frame, which is what another member, Bartman, had noted where he put his. Also I based the height of the cab on info I got from 99 to Life's build thread. As said before, lots of great info on this board.
After the cab and front sheet metal were done, I then did the running boards and bed.
Cool project by the way, I'll be following along.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 04-01-2016, 02:28 AM   #88
lower50's
lower50's's Avatar
Now that is some good motivational progress!! Nice wheels.
1951 MG TD
Old 04-01-2016, 07:31 AM   #89
Sim6
Sim6's Avatar
Looking good blaze! Nice score on the wheels, those will look tough. I also used 4x4 tubing for my cab mounts. On the front ones I found I had to cut the angle more drastic because they were too wide for the cab and got hung up when setting the cab on.
Jeff
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 07-01-2016, 11:17 PM   #90
84blaze
I've been busy over the last week or so. I've got the frame completely stripped and ready for paint. I hope to have a complete rolling chassis by June 15th.
I ordered some new drilled and slotted rotors and pads so I can get it rolling once everything is stripped and painted. Looking at ordering some headers, engine mounts and a universal trans crossmember in the next week or so.
Old 07-01-2016, 11:24 PM   #91
84blaze
Unrelated but I picked up some older racelines for the 2500hd
I need new tires but the rims are better than what the truck had.
Old 07-01-2016, 11:28 PM   #92
84blaze
Got the front end all stripped down
Pulled the cab and put in the back of my 2500hd for the time being since I'm not driving it yet.
Started grinding with a flap disc
Used my engine hoist to get it out of the garage so i could pressure wash all the **** off of it
First layer of paint
Oh and i found a upholstered seat on Kijiji so i picked it up
Old 07-01-2016, 11:28 PM   #93
84blaze
Strippers and Coke
Old 07-02-2016, 01:02 AM   #94
joedoh
joedoh's Avatar
nice seat!
are you bolting your mounts on? why paint now?
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-02-2016, 07:18 AM   #95
dug224
dug224's Avatar
Really nice build. I especially like you High School 6.0 Blazer. Keep the photos coming. dug
dug224 is offline   Reply With Quote
Old 07-02-2016, 09:17 PM   #96
84blaze
Originally Posted by joedoh View Post
nice seat!
Just painting now so it doesn't rust. Ill grind the paint down when it comes time for the mounts. Just want to get a smooth rolling chassis for the time being.
Old 07-07-2016, 10:44 AM   #97
lower50's
lower50's's Avatar
Looks good. Ya I painted my frame several times then ground and weld then paint kept the rust away.
1951 MG TD
Old 07-16-2016, 12:16 AM   #98
84blaze
Painted frame:
Cleaning up the 4 link control arms and calipers
Painted the parts up with semi gloss
Bought all new grade 8 zinc coated hardware for the 4 link
Got the rear end out and started cleaning it up for new seals and some other internal parts
Quickly mocked up the blazer brakes and set them in the 20' wheel
Old 09-09-2016, 03:22 PM   #99
84blaze
I'm back.
Here's a quick summary of what has happened since I last posted:
Sold the 2500HD for a profit after putting some money into it
I continued stripping parts for paint
Instaled the rear suspension with new zinc plated hardware
I also rebuilt the 4x4 G80 rear end with new seals, brakes, backing plates, and cross pin.
It all started with rusty backing plates...
Then I bought a 05 GMC 2500HD and some 24.5 Semi wheels to convert into a tow pig. The truck is mint!
Old 09-10-2016, 11:41 AM   #100
99 to Life
99 to Life's Avatar
looking good, always nice to tear as far down as you are going.
