Old 09-12-2015, 07:04 PM   #76
Metaldoc
Metaldoc's Avatar
Re: 67 long box
This is my bar stool racer I built from scratch, the steering has caster and camber in it. It also has chopped door springs as lowered suspension
Metaldoc is offline   Reply With Quote
Old 09-12-2015, 07:56 PM   #77
Advanced Design
Advanced Design's Avatar
Re: 67 long box
That is cool. How fast is it?
Advanced Design is offline   Reply With Quote
Old 09-12-2015, 08:31 PM   #78
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I've had it clocked at 35mph, with a buddy driving my truck. The wheels will fold if I take it any faster. it's a 5 hp with 4 hp flywheel to give better timing and the bubba is the gas task. Cops don't like it for some reason.
Old 09-14-2015, 10:14 PM   #79
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I got the tranny cleaned, resealed and now working on the floor shifter. Not sure if my Schlitz beer tap will hit the dash.
Old 09-15-2015, 06:13 AM   #80
71Sleeper
71Sleeper's Avatar
Re: 67 long box
I am digging the beer tap. You might have to fab a cowl roof to provide clearance.
71Sleeper is offline   Reply With Quote
Old 09-15-2015, 08:39 PM   #81
Metaldoc
Metaldoc's Avatar
Re: 67 long box
had to make new shift rod arms from the tranny. seems my swap meet deal was not a complete kit. It's not that easy making a rectangle hole. it all has a new coat of paint. I started cleaning the rear end, blasting gets sand into it, so grinder and wire wheel.
Old 09-16-2015, 12:36 AM   #82
WarMonger
WarMonger's Avatar
Re: 67 long box
this build is so cool. your metal skills are amazing
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 09-16-2015, 02:01 PM   #83
Metaldoc
Metaldoc's Avatar
Re: 67 long box
tranny complete but I still have final adjustments once in
Old 09-16-2015, 02:06 PM   #84
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks man, I have ability just not a lot of money and I love working on it. It's all about the build!
Derek
Old 09-16-2015, 02:19 PM   #85
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I found my glove box door
Old 09-18-2015, 02:14 PM   #86
Metaldoc
Metaldoc's Avatar
Re: 67 long box
stared cleaning the cluster and the next thing I know it's completely stripped, blasted, painted . Fixed the circuit board, cleaned and checked all lights. Jade was the color I found the came close.
Old 09-18-2015, 04:33 PM   #87
deejaaa1
Re: 67 long box
Originally Posted by Metaldoc View Post
....Hemi Eh. It's a 331 hemi with t5 trany, out of a mustang. It has a clutch and torque converter, very strange to drive. ......
can you explain this better? sounds interesting.
I'm subbed also. love your skills.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 09-18-2015, 05:56 PM   #88
Metaldoc
Metaldoc's Avatar
Re: 67 long box
The engine came out of a 1947 Chrysler ambulance. It has a torque converter in front of a clutch assembly. the converter was filled to certain level to give a stall converter affect. then a clutch with standard tranny was behind that. The end of the engine is the torque converter. We took the output shafts from the old standard and the new t5, cut, machined and welded to fit old clutch. When you drive it, it feels just like a regular stick but you can feather the clutch out at a stop like an automatic and just gas to go. I have no idea why Chrysler did this but it does work, mind you the engine with clutch and converter weighs 1000 lbs or so
Old 09-19-2015, 01:21 PM   #89
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I would say I need new brake shoes at the least. I took the drum off and the linings fell off.
Old 09-20-2015, 09:13 PM   #90
deejaaa1
Re: 67 long box
..... torque converter in front of a clutch assembly. the converter was filled to certain level to give a stall converter affect. then a clutch with standard tranny was behind that. .......
thanks for the explanation. never heard of them. i like the 48-54 Dodge cars. gonna get me one some day. install a 4BT and 5 speed shift. maybe when i retire in 6 years.
Old 09-20-2015, 09:25 PM   #91
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Dash is reconditioned and ready
Old 09-20-2015, 10:47 PM   #92
Xeen
Xeen's Avatar
Re: 67 long box
Nice job on the gauge cluster restoration.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-24-2015, 09:52 PM   #93
Metaldoc
Metaldoc's Avatar
Re: 67 long box
paint and assemble. new seals, brakes shoes and cables.
Old 09-26-2015, 03:25 PM   #94
Metaldoc
Metaldoc's Avatar
Re: 67 long box
total overhaul done and ready to install. I think I'm passed the half way point, time to bring in the frame to start assembly.
Old 09-30-2015, 07:54 PM   #95
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Made the body dolly work for the box with a couple new brackets. Much easier to work on and move outside to prep for finish coats.
Old 09-30-2015, 08:57 PM   #96
swamp rat
swamp rat's Avatar
Re: 67 long box
Making great progress!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-30-2015, 09:11 PM   #97
Advanced Design
Re: 67 long box
The rear looks really good. Nice bed cart too. Gonna be handy.
Old 10-03-2015, 03:02 PM   #98
Metaldoc
Metaldoc's Avatar
Re: 67 long box
took the rear axles to the machine shop to get 5x5 lugs redrilled and hub turned down. new rear 71 drums to fit my 67. got the new body, rad saddle, tranny and engine rubber mounts. working on the box today, adding 1x1 angle around the edge to hold the composite boards.
Old 10-06-2015, 08:13 PM   #99
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Gas tank cleaned and painted with cold galv. spray. Then satin clear to seal surface from scratching.
Old 10-07-2015, 10:39 PM   #100
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Names of the old owners I guess, painted with new U- joints. Brought the cab back in to finish the floor to mount it. I decided to paint the interior as well. You can tell the roof was painted by someone inside the bed.
