Old 12-11-2015, 08:54 PM   #76
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 69 crew duramax build
His donor is an LBZ duramax. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-11-2015, 09:14 PM   #77
ctdarnell
Lbz donor. Cab has to come up about 3" to meet bed.
ctdarnell is offline   Reply With Quote
Old 12-11-2015, 09:46 PM   #78
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That's pretty wild how the crew cab and Longhorn bed fall right on to the crew cab long bed newer chassis.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-13-2015, 03:02 AM   #79
swamp rat
swamp rat's Avatar
That's coming together real nice!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-13-2015, 05:11 PM   #80
71blksuper4x4
SWB 4x4 Collector
Man,it's coming together quickly. How does the cab fit over the tranny as of right now? I haven't started test fitting my dmax/ally under mine yet. My frame is really similar in dimensions as your newer frame and was just curious as what it fits like. Trevor
TREVOR
Old 12-13-2015, 05:15 PM   #81
ctdarnell
Plenty of clearance for trans.
Old 12-13-2015, 08:06 PM   #82
pete29
Great looking project! im starting to build a 72 crew cab dmax. Any advice on lowering the burb roof skin? I was originally gonna leave the tall roof but i almost think itd be easier to lower it.. I was just gonna cut a couple inches out of the roof skin and drop it down but then it wont be wide enough...
pete29 is offline   Reply With Quote
Old 12-13-2015, 10:19 PM   #83
ctdarnell
You will have to slit the corners and "flatten" it out to fit.
Old 12-13-2015, 10:48 PM   #84
Sicksty8
Sicksty8's Avatar
That is one badass looking rig! Will you be using the 06 interior or keeping the 69 interior.
Sicksty8 is offline   Reply With Quote
Old 12-13-2015, 11:37 PM   #85
ctdarnell
69 interior
Old 12-15-2015, 07:05 PM   #86
AMERICAN PICK-UP
Great looking truck...
AMERICAN PICK-UP is offline   Reply With Quote
Old 12-15-2015, 09:08 PM   #87
Theboatandcarman
i think it would look best if you could somehow drop the bed lower instead of raising the cab
Theboatandcarman is offline   Reply With Quote
Old 12-15-2015, 09:21 PM   #88
ctdarnell
I have the wood floor supports resting on frame. Can't go lower without notching frame or raising bed floor. Really don't want to do either.
Old 12-17-2015, 02:11 PM   #89
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
This is awesome. Do you mind sharing some more pictures of the 4th door work? How did you all go about building the B-pillar?
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 12-17-2015, 08:57 PM   #90
ctdarnell
Body mounts installed! Frame does show a little more than factory 06. But not too horrible. Needs steps anyway. I think it will clear 35's with no lift. Think I might try to modify a set of chrome steps and attach them to power folding board motors. That way they block frame but still fold down for easy entry.
Old 12-17-2015, 09:08 PM   #91
ctdarnell
Old 12-18-2015, 06:27 PM   #92
Dieselwrencher
Looking good!
Ryan
Old 12-21-2015, 07:02 PM   #93
ctdarnell
Fender mocked up. Hood will not shut, Reservoir on master cylinder is too tall. But this is location it needs to be mounted to firewall. So now I'm on the hunt for shorter reservoir. Or a remote reservoir.
Any ideas?
Old 12-21-2015, 07:05 PM   #94
ctdarnell
Pedals are also mounted. This is why master cylinder needs to stay put. We like pedal location
Old 12-22-2015, 10:08 AM   #95
Farm Shop
Farm Shop's Avatar
The truck is looking great. Keep the pics coming.
For a shorter reservoir, some Astro vans used individual pieces that look considerably shorter.
... and others used a single reservoir similar to like a '96ish K2500 truck.
Those MC's look like an older design. This C5 MC looks similar. You might want to keep an eye on the fluid level... those Dmax trucks have some massive brakes that take a lot more fluid volume than a C5 does.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 12-22-2015, 11:27 AM   #96
pete29
Do you have any more pictures of how you welded the horizontal roof posts together above the rear doors? I was just wondering since the burb is different than the truck...
Old 12-22-2015, 10:24 PM   #97
pebblepusher68
Following, been wanting to do this to a dually Duramax
pebblepusher68 is offline   Reply With Quote
Old 12-23-2015, 02:00 PM   #98
Tynee
I miss this truck.
Tynee's Avatar
subscribed.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-23-2015, 11:16 PM   #99
notchbackgta
Originally Posted by ctdarnell View Post
Do you still have the rear section of the burb? I want to add a light on the inside of the truck and a picture down into the section where the hatch hinge bolts in would be extremely helpful so I know what is going on in that area. I want to put in an interior light, but I am not sure how to get a wire in the for power, or if it is possible
notchbackgta is offline   Reply With Quote
Old 12-23-2015, 11:41 PM   #100
ctdarnell
I do still have the rear half. I can try to get a picture tomorrow
