#76 |
laying low
![]() Join Date: Mar 2001
Re: Pace performance fitech fuel injection
You fellas know about the fuel lines being different diameters don't you? The 6 cylinder has a 5/16" single line only and a later V8 has a 3/8" feed line and a 1/4" return line from the sending unit to the fuel pump. And as far as I know each sending unit will fit in either eec tank or non eec tank. Just an FYI when planning your fuel system.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#77 | |
My truck was originally a 6-cylinder, but everything has been replaced. i did custom fuel lines tank to carb, new tank, and new sending unit. I agree, sending units all fit any of the tanks. You can use the one with a return pretty easily to add a return to the in cab tank. You can get sending units with 5/16 or 3/8, and 3/8 ones with or without returns. The sending unit that was in my truck when I got it was 3/8 and had a capped off return. When it died I replaced it with a 3/8 without the return. That was after I had replaced the tank. If I had known then what I know now I would have bought an EEC tank and made all of this easier.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#78 |
But Found Her 25yrs Later!
With the cost of other brand units, I figured I'd wait until my carb started giving me issues, but for this price I might just bite now.
Although, I may just wait and see about the new 400hp unit.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#79 |
Ok guys I just ran a test. I hooked my return line up to my shop air and put 10 psi of pressure to it and as it was filling the tank I heard it start hissing. So I crimped the hose off to hold pressure to find the hiss. Sure enough my one way vented cap will also vent high pressure out. Needless to say it takes a good amount of volume and pressure but it will vent. This is good news to me for not having to do another vent line. Another good thing is if it builds that much pressure I will surely hear it. I am going to run the command center vent to my factory tank passenger side vent that's already under the hood and run it as a vent IN only system and only out if it exceeds over 5 psi. I feel like it will be good
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
#80 | |
#81 |
So would the inline pump kit that they offer work with the factory in-cab tank in a 72 (vented, has a return port on the sending unit assembly)? Do the electric pumps have enough draw to lift the fuel through the top of the tank? I have no experience with electric fuel pumps.
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
#82 | |
#83 | |
![]() Join Date: Mar 2014
The FiTech kit uses -10AN push-on fittings ans 1/2"I.D. hose to connect the supply line to the prefilter and to the pump inlet. The pump primed instantly even with a near empty tank. It looks to be a high quality Walbro that has been rebranded with FiTech's logo. I'm sure it will provide years of trouble free operation. FiTech was in the OEM EFI buisness for along time before starting their aftermarket EFIs so I doubt they would sell you a junk pump.
Made in America by Americans Last edited by Big Kev-O; 12-29-2015 at 04:47 PM. |
#84 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#85 |
Yup, my tank has a vent off the top on the passenger side, the short one going to the filler neck on the driver side, and then the sending unit has the feed line and what I assume is a return line that is just capped on the outside with a plugged chunk of hose.
#86 | |
Hope that helps. ![]()
#87 |
Yes, I'm running a mechanical pump now. Haven't ordered an EFI yet, just getting an idea of my options. I know the Command Center is the obvious choice, but I figured I'd see how feasible the inline pump would be without the Command Center. I'm just excited that the feedback has been so good on the performance so far, and the price have dropped to reasonable levels all of a sudden!
#88 | |
I have purchased the FiTech TBI unit and Command Center to go on my 69 Camaro and will be using my mechanical pump. The FiTech parts look first rate. You can see some of our work on my build thread in my signature. ![]()
#89 |
![]() Join Date: May 2013
Having done a few efi systems , this one looks impressive , compact size , anular discharge , and a built in pressure regulator , are all big pluses
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#90 | |
#91 |
I like the idea of the command center because its really an in-tank pump, which is cooled by the fuel, and will last a lot longer. Plus having the surge tank gets rid of the issues with fuel starvation on corners when the stock tank is low (no baffles or sump).
#92 |
I put vintage air in my truck this weekend and while doing it I have been running wire and making preperations for the command center return lines. I hope jegs ships mine out tomorrow. Doubtful but hopes are high. If anyone wants I could do a little write up of the install with the command center and everything with a factory tank since I have not seen that particular write up yet.
#93 | |
#94 | |
#95 |
I will do a write up in a separate post. I will keep y'all informed here though when it gets here and I start the other thread
#96 | |
![]() Quote:
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510 |
#97 |
The impression I got from jegs is most of the FITECH stuff is being drop shipped from FITECH. Could have changed but just an FYI
#98 |
Yeah I was under this impression as well. I may call fitech
#99 |
Fitech says they will have some in the second week of January. He said jegs may have some in stock though to call them. About to call jegs
#100 |
I just spoke with Jegs customer service and they said that when my order was sent to Fitech for shipment, it came back as Backordered to be shipped on 1/13/16...oh well, guess the waiting begins....;(
