01-26-2017, 06:09 AM | #76 | |
Re: 49, bagged, 6.0, patina, the works
Thanks for the link...
Desert |
01-26-2017, 09:49 AM | #77 |
I think bumpsteer and toe correction is the big advantage. However I couldn't figure out if it was needed with reasonable sized wheels.
I found out about it literally right after my front end arrived (of course) but since I'm on a clipped AD frame and to lay running board actually doesn't max out the suspension I'm going to hope it all sort of works itself out in the wash.... |
01-26-2017, 07:06 PM | #78 | |
01-26-2017, 07:07 PM | #79 |
It fixes bump steer and toe in/out issues throughout travel. It also eliminates the need to notch for tie rods.
01-27-2017, 08:23 AM | #80 |
OK, Good to know when I finally start my project.
Desert |
01-27-2017, 02:50 PM | #81 |
Subscribed! Any reason you went with the 3 link over the 4 link rear from Thorbros? I was considering the same but wasn't sure of the difference between the two.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
01-29-2017, 07:17 PM | #82 | |
Heres a photo. This is without the motor in the truck and an undersized tire. So you can imagine what it will look like with a larger tire and weight on the frame. Injectors re-oringed/cleaned. Intake manifold assembled and back on with a new valley pan gasket and knock sensors. S10V8.com 1 5/8 short tubes on. New water pump, steering box, idler arm, centerlink. Just waiting for my MMW tie rods. Again but showing the new Speedway GM metric tubular uppers Took some measurements and decided the 69 Mustang EFI tank from Tanks Inc. would work great. Fabbed some basic mounts and got it in today. Just need to bolt it up and trim the front lip a bit to clear the shocks when aired all the way up. I'll install the pump tomorrow but am going to wait to run the lines/corvette FPR until after boxing the frame.
'49 3100 Build | 6.0 LSX, bagged, patina, the works |
01-29-2017, 10:43 PM | #83 |
Nice progress...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-29-2017, 11:06 PM | #84 | |
01-30-2017, 04:21 AM | #85 |
A320 Pilot/USAF Retired
Cool build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-30-2017, 01:42 PM | #86 |
No real reason other than I can't remember them offering a bolt on 4-link back then. Maybe they did haha, been quite some time.
01-30-2017, 01:46 PM | #87 | |
If I don't, i'll probably graft a fuel door into the bed floor and use flexible rubber hose up to it. Thanks!
03-06-2017, 10:08 AM | #88 |
Cab at the blasters
Made some boxing plates from cardboard and had my local machine shop draw them up and cut them on the plasma table. Welding these in soon. Picking the cab up Back on the frame for a final test fit now that the parking brake is removed. Then braced before panel replacement MMW notches tie rods installed Can finally steer this thing in one piece Thats it for now. My buddy is making great progress on the cab panel replacements. Ill have some photos soon.
03-06-2017, 10:37 AM | #89 |
Looking good, Any plans for the cover on the intake?
Meaning smoothing it out etc.. Mark.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
03-06-2017, 01:09 PM | #90 |
Nope, just leaving it. Im more for the OEM styling of it.
03-07-2017, 07:39 AM | #91 |
How far down did you strip the cab before blasting? I think mine will need it but i don't know how much I'm supposed to take off. Do they primer after for you to stop flash rust?
03-14-2017, 09:57 PM | #92 |
Completely stripped the interior and dash of everything. All glass. Doors off. I only had the interior, firewall, and bottom blasted as I'm keeping the patina. And yes, it was primed after. The metal work is happening currently and will be primed again once complete.
03-14-2017, 11:05 PM | #93 |
Cool idea on blasting just the interior.
Cant wait for more progress! |
03-16-2017, 10:19 AM | #94 |
Thanks for the response, that's a huge help.
03-16-2017, 03:52 PM | #95 |
Formerly- 1972SuperCheyenne
Looks killer man, keep it up!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
03-16-2017, 04:29 PM | #96 |
I'm not a patina guy but I LIKE your truck. My Dad had two AD trucks when I was a kid. One was an early truck with true door handles that turn down. It was light green with primered fenders. The other was a later one that was the same Forrest green yours is but it was IMMACULATE....so he sold it because he was a brick mason and didn't want it to get b!tched up. This was the early 60's so the truck wasn't that old.
I'd love to have your truck when it's complete.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-19-2017, 08:25 PM | #97 | |
No problem!
Thank you! Quote:
Some more progress.
03-20-2017, 11:32 PM | #98 |
Looking good man
big_moss bagged 51 3100 build |
03-28-2017, 12:50 PM | #99 |
Nice progress man. Floors looking good
03-30-2017, 12:44 PM | #100 |
More repairs
New inner cab corners and rear section of the floor. Both sides of the floor installed/inner cowls. My buddy says the cab will be primed and ready Saturday so thats the plan for pickup. I am not having him replicate the patina on the new panels YET because the cab/wheels/inner fenders as well as other bits and pieces will all be traveling back to him for paintwork anyways. I still need to burn in the boxing plates and then I'm ready for the frame to be blasted and painted. Really from there, its all downhill assembly.
