#76 |
Re: Wtf did i get myself into 51 s10 swap
nice patch work. 104 dang. On the east its honestly felt like fall already. leafs are falling and temps are mild. it hit 44 deg at night the other day, felt like winter! Good luck with the body work. man that stuff takes foreverrrrrrrr.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#77 | |
The body work is going surprisingly smooth this cab is really clean compared to my first rot box cab. But a buddy of mine recently got laid off from the body shop he worked at, so he's doing most of it and I've been helping on my free time. I'm not in a real rush to get it back having the garage less crowded has been nice haha |
#78 |
![]() Join Date: May 2007
good to see you still chugging along!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#79 |
Looking good and having a body man friend is always a bonus.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#80 |
Updates over the past couple of months
Ended up having to find 53-54 doors because my 51 doors were a no-go on my 53 cab. Drove 2 hours to the middle of no where to get these doors but for $100 couldn't pass that up original paint no rust. Ordered new door handles, latches, strikers, locks, door pins Cut off all the body mounts on my s10 frame to re-do them since I wasn't happy with the welds I originally did. They look alot better now and the fronts are boxed in just waiting to get my cab back to double check the rear mount height and placement before I burn them in This weekend Finally Christmas shutdown for the aerospace industry gives me and my buddy some free time to work on my cab. Got the new doors hung and 90% aligned he's saying we will more then likely have to adjust them more once the cab is bolted to the frame. He's hoping to have the cab finished up and primed this week. ![]() ![]() |
#81 |
Quick update life has been hectic the last couple of months so progress has just started picking back up somewhat. Wasn't happy with some of my original fab work so cut alot of stuff off to start fresh which I'm happy I did.
But so far over the past couple of months the following can be crossed off my to do list cab body work is done (except I welded up mirror holes in the door and I'm going to shave the heater box louvers) POL chrome booster and master front brakes 100% new from hardlines to bolts little shop of horrors no toe steering installed new mevtech idler arm steering box was stripped and painted (depending on slop might replace might go power steering but really like the minimalist approach) scored a super clean original front bumper, repop tailgate, and better driverside rear fender cheap at pomona re-did cab mounts, running board mounts, and bed mounts pops donated a crusty but running 4 bolt main 400 and 700r4 trans that we pulled from the 55 ford he picked up recently just cleaned it up, new performer manifold, new balancer, new gaskets minus head gaskets, spray bombed it, and added all the chrome stuff I bought for my 350 awhile back had my headers nickle plated and sending a bunch of trim stuff, bumpers, and my 4 link out to chrome soon Welded the motor mounts in and had to push my trans crossmember back 2" for the 700r4 since originally I was going to run a th350 Cab is currently off on the roller again to paint the firewall then its ready to be finally installed for the last time. Still sticking with painting the truck satin black maybe single stage maroon, firewall and interior will be painted ford wimbledon white. Motor is 99.9% ready just need to grab some black 8mm wires and a black distributor cap because I can't stand the orange wires and red distributor I have currently Some kind of updated pics before finishing the brakes and pulling the cab off motor wasn't buttoned up ![]() ![]() my current to do list for next couple of months paint firewall and interior, get gauges (have original gauges figured new gauges would be easier and nicer), finish the rear brakes, steering shaft, remake the core support. Might add a oil cooler since my dad couldn't use it on his truck |
#82 |
Lookin good. I’m glad you’re making some progress.
my 54 s10 build |
#83 |
#84 |
Yep same here. I try to find some time here and there to work on it. I’ve got the cab sitting on the frame, it looks fantastic. The fire is starting to build in me now since the days are getting warmer. Hopefully we’ll both be done and driving them someday soon.
my 54 s10 build |
#85 |
umm, did your running board fall off? it's sitting on the ground...
looking good. |
