Old 09-15-2016, 12:01 PM   #76
JMD
JMD's Avatar
Re: '67 K10 swb big block "The Mutt"
Made some more progress last night. Nothing major but it's starting to look like a truck again! Electric fan is installed, finished up plumbing the brakes, and the passenger inner and outer fenders are hung. I'm very thankful my friends who were willing to stay late and help.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 09-21-2016, 10:08 AM   #77
JMD
JMD's Avatar
Been working on this thing quite a bit lately, getting ready to turn it over for the first time. Ran into a little issue with my throttle linkage, the cable binds pretty bad because of the severe "S" it has to make right behind the firewall...Any suggestions?
Old 09-21-2016, 10:55 PM   #78
BlueBullet
BlueBullet's Avatar
It looks like that is a two piece bracket can you take it apart and flip it over. So that your kickdown cable uses the currently unused hole and throttle cable goes back in same hole. Hope that makes sense.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 09-23-2016, 08:49 PM   #79
JMD
JMD's Avatar
I did try that, however flipping it also moves the bracket towards the firewall about 2" and it's still not quite lined up with the pedal. The shorter distance creates an even more severe kink in the cable...I think I'm going to end up fabricating a bracket off the pedal and drilling a new hole in the firewall.
Since I'm getting rid of the bulkhead plug and the mechanical speedometer I needed to find a quick and easy way to fill those two square holes in the firewall. Some square tube caps fit the bill perfectly!
Old 09-25-2016, 12:15 PM   #80
NewType72
NewType72's Avatar
Wow does that polar pedal ever look nice and clean in there. Great stuff subd for sure
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-25-2016, 05:53 PM   #81
JMD
JMD's Avatar
It's a very nice product! The only gripe I have with it is that it was advertised as a bolt on assembly that wouldn't need firewall modifications...Not entirely true but oh well.
Old 09-26-2016, 01:41 AM   #82
JMD
JMD's Avatar
Exclamation Re: '67 K10 swb big block "The Mutt"
Went through the heater controls today and ended up replacing the heater core and a few seals. I'm happy with the way the way the temp control faceplate turned out considering what I started with.
Old 09-26-2016, 11:43 AM   #83
NewType72
NewType72's Avatar
Trust me we fought that with a porterbuilt front dropmember product we got. I'd much rather fight a gasp pedal at this rate lmao
- Dylan
(209)-985-7721
Old 10-15-2016, 10:53 PM   #84
JMD
JMD's Avatar
No huge progress but I did spend a solid 6 hours trying to install an oil pressure sending unit. I had to remove the oil galley plug on the front of the engine and of course I stripped the allen head out. I was thinking I would have to pull the engine and drill that sucker out but luckily an easy out did the trick! I was pretty nervous for a bit though.
Also installed power steering lines and the drag link. Apparently there's no good way to hook up a 75' power steering pump to a '67 gear box so I'm stuck with this contraption for now...it'll work but it sure is ugly.
Old 10-24-2016, 09:09 PM   #85
JMD
JMD's Avatar
Was going to spend the weekend finishing up the wiring but got sidetracked...For the life of me I couldn't figure out why I had a constant 12 volts to both sides of my brake light switch. After a lot of head scratching and foul language I found that my new steering column was shipped with the hazard switch in the "on" position which was causing all of my issues
In order to turn the hazards off I had to install the button, which led to installing the turn signal lever, steering wheel, and shift linkage...And then it was time to shut the shop down for the weekend. Oh well, guess the wiring will have to wait until next weekend.
Old 11-26-2016, 02:32 PM   #86
JMD
JMD's Avatar
Lots happening with this build, finally got it running! Unfortunately the PO didn't know the difference between an internally and externally balanced engine, and I didn't bother to check Boy does that make a difference! So I got the pleasure of dropping the transmission and installing a balanced flywheel and damper.
Also had 2.5" dual exhaust run to a pair of Flowmaster 50 series mufflers. I'll get the tailpipes installed once I know where the bumper and hitch will fall.
Old 11-26-2016, 02:38 PM   #87
JMD
JMD's Avatar
Now that it moves under its own power (for the first time in 4 years!) I was able to get it on a trailer and over to the body shop. Here we are test fitting the new hood.
Old 11-26-2016, 02:53 PM   #88
JMD
JMD's Avatar
Unfortunately the aftermarket hood and fenders are, well...garbage. The drivers side lines up ok after a good amount of grinding, welding, and "persuading", but we were unable to get rid of the 1" gap between the front corner of the hood and the drivers side fender. There is also a sizable depression in the hood where it meets the cowl. About 1/4" low. I am in disbelief. I'm currently waiting to hear back from my supplier to see what can be done but I'm not gonna hold my breathe.
Old 11-28-2016, 01:56 AM   #89
JMD
JMD's Avatar
Started assembling the bed. Again, pretty disappointed by the fitment of this aftermarket stuff. Lesson learned I guess.
Old 01-20-2017, 01:04 AM   #90
JMD
JMD's Avatar
Doors are done! Feels good to be over that hurdle.
Old 02-02-2017, 12:50 AM   #91
JMD
JMD's Avatar
Moving along on the front clip. Finally found a hood and a pair of '68 fenders that were in ok shape. Took a bit to get them straight, but they fit much better than that repop crap. It amazes me how much work goes into painting a truck.
Once again I wish I would have spent a little more time and money finding OEM parts. Putting the internals of the doors together was a nightmare. It would have been WAY cheaper to buy a pair if beat up OEM doors, cut the rust out of them, and patch them up than it was to make this aftermarket junk fit nice.
Old 02-02-2017, 12:54 AM   #92
JMD
JMD's Avatar
Here's a prime example of the poor quality contol practices of the aftermarket industries. This picture is looking down at the top of the core support where the upper radiator clamp mounts. See anything wrong with the location of the holes?
Old 02-03-2017, 03:15 PM   #93
DeepOceanStepside
DeepOceanStepside's Avatar
Just ran into the same issue on my aftermarket core support...i dont know why the heck they do that.
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 02-04-2017, 10:28 PM   #94
JMD
JMD's Avatar
Who knows. The first aftermarket core support I had on the truck was really for a 69-72, but it fit perfect. Then I switched to a correct one from the same company but the holes are all out of whack. The only difference I can think of is that I bought the first one about 4 years ago... Maybe quality control was a lot better back then.
I had some undercoating sprayed in the doors and on the floor pan, both inside and out. It's supposed to provide some sound deadening. Also did the final fitment of the front clip minus the hood. Hopefully we'll get to the hood tomorrow and then it's on to paint!
Old 02-18-2017, 10:38 PM   #95
JMD
JMD's Avatar
It was a beautiful day to work on the truck today!
Old 03-10-2017, 12:50 AM   #96
JMD
JMD's Avatar
Finally home!
Old 03-10-2017, 06:38 AM   #97
GR8-68
GR8-68's Avatar
Wow !!! This is looking great
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-07-2017, 08:12 AM   #98
JMD
JMD's Avatar
And the fun continues...
Old 07-11-2017, 11:48 AM   #99
JMD
JMD's Avatar
Almost done with wiring. Everything was pretty straight forward except for a weird problem I'm having with the LED tail lights from LMC. For some reason the rear blinkers won't flash if I have the headlights/running lights on. However if I plug in a normal incandescent bulb or even the LED park lights (which have the same plug as the tail lights) everything works as it should. If I plug the tail light into one of the front blinker sockets, I have get same problem. The only thing I can think of is that something is wired wrong inside the LED unit itself. I spoke with an LMC rep and they're sending me two new tail lights. Hopefully that solves the issue.
Old 07-11-2017, 04:50 PM   #100
StanleyRosiello
StanleyRosiello's Avatar
Badass rig man. With everybody going super low with these truck (to each his own... and I still love these trucks low or high) its refreshing to see a guy with his truck riding high. Can't wait to see it finished.
StanleyRosiello is offline   Reply With Quote
