#76 |
Thats exactly what they did....
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
#77 |
I am glad for you that things seem to be turning around, damn thats a lot of power! I still will stick by my earlier comments about not buying a crate and going to a local engine builder but am very happy your saga is nearing and end, the fun should start soon!
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. ![]() |
#78 |
Mike, that is unbelievable man! I can't wait to see and hear that thing. When you have it rolling around again, let us know how it feels getting on the freeway, that should put you in your seat and get a lot of onlookers in the process. Oh man!
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
#79 | |
Interesting to note the pump gas 572 is 620/650. I guess I really need to get cracking on the posi now. ![]()
#80 |
Hey Miket that is some good #'s!!! PHR did a dyno test as is on a 572 that came out at 701HP-forgot the torque. Said they got in touch with GM and was told that they rate them low so they with always be as rated. Put a Eaton Posi unit (comes complete) under mine. Just removed my ring gear from old unit and installed on new unit. Added new bearings ,used same side shims and reinstalled. Works fine-leaves 2 nice black streaks now. LOL. First time you rap on it lets us know how far the wooowww meter climbed. Good luck.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#81 |
I am really excited.....gotta get the posi done so I can looks towards a small NOS kit!
#82 |
Broke
miket, have you got that beast out on the road yet?
72CheyenneSuper1ton4x4BigBlock |
#83 |
Broke
How much extra does it cost to have them dyno your crate engine?
Also if you had a choice which would be better, having them dyno it, or take the engine to an engine shop and having them go through the whole thing to make sure everything is to spec?
#84 |
I believe Sallee charges $450 for the dyno which they video tape. Based on my experience with Sallee, if you buy your motor from them, have them dyno it before shipping. That way they are responsible for it before things get worse.
#85 |
Broke
Thanks miket.
#86 |
After being out of town for a few weeks, I finally got home yesterday and was able to read the dyno numbers from the pull...pretty interesting....
From 2900 rpm through 6100 rpm the motor made no less than 560 lb ft of torque...pretty flat...but with good gains starting at 4400 and running through 5200 with a peak of 633... however horsepower really builds from 4000rpm (433 hp) through 6100 rpm with a peak at 663.6.hp. Unfortunately it looks as though two mods will be required after this....stall converter and probably hydroboost....as it seems I have no vac. I will get my truck back on Monday....will update then.
#87 |
A n t i c i p a t i o n . . . . .
#88 |
Picked up my truck tonight. Wow...man....it really scoots. I couldn't really do much cause it was raining....and no posi...but 1/4 throttle roll ons at 50 get you to 100 pretty quick.
This sounds funny but the motor sounds much better...smoother...it doesn't sound like it's fighting itself...even though it has a much bigger cam. I do know that a stall converter and posi are in order... All in all I am really happy and feel very satisfied with Sallee Chevrolet....I even got to watch my Dyno on videotape!
#89 |
Pronounced "Pew-al-up"
Congrats Mike! I'll bet its nice to let it roar down the road, after all you went through. We will have to take a look at the next meeting.
![]() Dan
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
#90 |
how about some specs on the motor? what cam are you running? lift and duration? any flow numbers on the heads? sounds like a awsome motor. i wish i could afford one.
Anthony |
#91 | |
Crane Solid roller Cam (615/630 296-304 dur) Crane Solid Roller lifters New Pushrods UpgradedValve Springs, retainers/keepers Crane Gold Race Roller Rockers Valve covers (shown) Victor intake (ported) 850 Speed Demon Mech Sec carb new coil and module Square deck block Port Job on the heads port job on the intake mill heads for 10-1 compression The ZZ comes with Edelbrock RPM/Performer Oval port heads.
#92 |
pics
a quick pic...
#93 |
Post Whore
![]() Join Date: Feb 2000
She's a beauty!!!!!!!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#94 |
Gotta get rid of the bad filter....
#95 |
Now why did you do that?!! We all will have the same dream over and over again.
#96 |
Nothing clever
little bit of info I found on the scoggin dickey web site:
Explantion of why 502 crate engines consume oil and the proper fix. All 502's built since the inception during the mid-80's have used a unique ring combination of 2.0mm/1.5mm/4.0mm. The factory installed 4.0mm oil ring is a low tension ring. It is used to reduce frictional horsepower losses. Oil consumption is a natural characteristic of this type oil ring. When it is time for a 'freshen-up' on your 502, we recommend and sale the Speed-Pro high performance file-fit ring set which includes a standard tension oil ring for improved ring sealing and oil control. With the use of this ring set, your oil consumption will return to a normal level of about 1 quart per 1,000 miles. Dont know if you guys already knew that but supposedly if you get the replacement ring set they sell, it will fix the problem. Sorry but this is the only kinds of help I can offer (SHHHHH I know nothing, but dont tell the wife!)
Got "the Midas Touch!" |
#97 |
Doesn't help much does it? Mine uses 2 qts. per 1000, so that is alot of expense to go to for only $1.50 savings per 1000 miles. I would have to drive 100,000 miles to save $150.00. Surely GM can come up with a better ring then that.
#98 | |
#99 |
Man, now I'm scared! Picked up a ZZ4 for a friend of mine, cause I could get it cheaper than he could. It's in my garage awaiting him to bring out his pickup to install it. I hope all is OK!!!!!
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#100 |
Formerly yellow72custom
Mike that is SWEET!
![]() You are defenitly gonna need some posi....my 3.07 geared truck has a hard enough time hooking up with a little 350....i can only imagine how the built 502 would run!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
