Old 02-21-2017, 11:46 PM   #76
c10guru
Re: Project Pumpkin
Stumbled across a facebook post that i could not pass up. 01 Tahoe short wheelbase. Saves me from cutting the Denali frame and the wheel base of a SWB 67 C10 and a SWB 01 tahoe is only off by 1/2 inch! So i brought her home!
c10guru is offline   Reply With Quote
Old 04-09-2017, 10:27 AM   #77
webberjames95
Re: Project Pumpkin
damnnnnn. you got like 6 cars in this pick up build lol
webberjames95 is offline   Reply With Quote
Old 05-24-2017, 12:07 AM   #78
c10guru
Re: Project Pumpkin
Have to have a lot of parts when building!
Old 05-24-2017, 01:29 AM   #79
noteron
noteron's Avatar
Re: Project Pumpkin
Awesome job so far. But why did you ditch the idea of having AWD?
noteron is offline   Reply With Quote
Old 05-24-2017, 12:03 PM   #80
NewType72
NewType72's Avatar
Re: Project Pumpkin
Definitely a lot of other pieces to make one but hey that's how it has to happen sometimes. Johnny cash "one piece at a a time" comes to mind.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-25-2017, 03:22 PM   #81
made2drag
made2drag's Avatar
Re: Project Pumpkin
im in.... im loving the fact that you want to build a 67-72 so bad and not just buying a daily swb already driving.
the Tahoe seems to be the way to go. Modern everything... cab/bed mounts and bumper mounts and it should be an awesome driver with old school style
made2drag is offline   Reply With Quote
Old 07-09-2017, 01:00 PM   #82
c10guru
Re: Project Pumpkin
Time for an update! Been a busy boy, far too busy to update haha. Anyways here we go!
Old 07-09-2017, 01:06 PM   #83
c10guru
Re: Project Pumpkin
Finally have a blank canvas! Time to give it a good scrub and rollers!
Old 07-09-2017, 01:08 PM   #84
c10guru
Re: Project Pumpkin
Figured I'd do a final rendering lol
Old 07-09-2017, 01:10 PM   #85
c10guru
Re: Project Pumpkin
Cleaned up decently. Enough bare metal to build body mounts.
Old 07-09-2017, 01:12 PM   #86
c10guru
Re: Project Pumpkin
Cut the spare tire mount off, it's a race truck. No need for spares! Why do i feel like that's gonna bite me in the ass later?
Old 07-09-2017, 01:30 PM   #87
c10guru
Re: Project Pumpkin
Like to ditch the factory tank and run a fuel cell between the rear frame rails. Depending on how low I drop the body i might just run a tonneau cover and use the box for a battery, fuel, air tank, etc.
Old 07-09-2017, 01:39 PM   #88
c10guru
Re: Project Pumpkin
Now because i want AWD and a low truck its time to ditch those torsion bars and rear coils.
Old 07-09-2017, 01:43 PM   #89
c10guru
Re: Project Pumpkin
The plan is to ditch the torsion bars in the front and run air shocks. Monroe MA805 kits are super cheap but ill have to modify the lower mount. Yellow is stock replacement and white are the Monroe air shock.
Old 07-09-2017, 01:46 PM   #90
c10guru
Re: Project Pumpkin
The measurements are similar but I don't have much room to play with and do not over extend the suspension so I'll definitely need level sensors.
Old 07-09-2017, 01:55 PM   #91
c10guru
Re: Project Pumpkin
Here's the room i've got to play with up front.
Old 07-09-2017, 01:57 PM   #92
c10guru
Re: Project Pumpkin
The rear is a different story, got lots!
Old 07-09-2017, 01:59 PM   #93
c10guru
Re: Project Pumpkin
Got some more research to do on suspension components. Should have the engine and trans in soon. Then I can drop the cab on and front clip.
Old 07-10-2017, 02:07 PM   #94
made2drag
made2drag's Avatar
Re: Project Pumpkin
I cant wait to see this together. great idea!
Old 03-25-2018, 10:53 PM   #95
c10guru
Re: Project Pumpkin
Well time for cab to meet frame!
Old 03-25-2018, 10:58 PM   #96
c10guru
Re: Project Pumpkin
I had a general idea where to make the hole in the frame for the front body mounts from drewskiren and his truck Young Frankenstein but ultimately it would be where ever the centerline of the front axle would sit in the front fenders.
Old 03-25-2018, 11:02 PM   #97
c10guru
Re: Project Pumpkin
With the fenders bolted up i got the front tires lined up to where i wanted them then I squared the cab to the frame.
Old 03-25-2018, 11:10 PM   #98
c10guru
Re: Project Pumpkin
I want the cab to sit as flush with the frame as possible because the tahoe chassis is so much taller than the original and the less suspension work I have to drop the better. I found basic body bushings from energy suspension manufactured for a Jeep CJ5. I used large washers and locked the body to the frame.
Old 03-25-2018, 11:12 PM   #99
c10guru
Re: Project Pumpkin
Now for the rear mounts they are more narrow than the fronts and don't sit on top of the frame. Scratched my head a bit then took the Tahoe front body mounts and welded them to the inner frame rail and bingo.
Old 03-25-2018, 11:23 PM   #100
c10guru
Re: Project Pumpkin
Now because the Tahoe frame is about 2" taller than the 67 I'm either going to have to cut the front of the frame off or notch the core support which I don't want to interfere with the rad. But winter is about to set in and thats the end of that. She now gets put away for the season.
