02-09-2019, 12:07 PM | #76 |
Re: Anyone have this original in-bed spare tire carrier mounted?
Installed one on mine today. I know the wing nut isn’t factory correct, but it looks period correct to me
02-09-2019, 12:25 PM | #77 |
Hey Tigger, what size tire is that, I'm trying to determine the largest tire that will fit on a short bed mounted in the same location. Thanks. BTW, I like your wingnut setup better than the factory double nut.
02-09-2019, 02:35 PM | #78 |
here is an old pic I had saved, don'tknow anymore about it. Also I have a set up that has a disc as well but it is at the cabin and under 100ft of snow
02-09-2019, 02:40 PM | #79 |
Ok-found pics of an NOS one
02-09-2019, 05:10 PM | #80 |
225/75/15. I like the wing nut too- l live in a area that is pretty safe as far as spare tire thieves go
02-09-2019, 11:35 PM | #81 |
70+ ( Old Skool Club )
Reading through thread I thought I'd post a spid pic for I truck I have with E81 wood floor and it shows the RPO Code P13 for the spare tire carrier which is mounted on drivers side between wheel well housing and cab.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-23-2019, 06:20 PM | #82 |
I'd like to find those pieces. I managed to find an NOS bracket, but no hardware.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-10-2020, 11:02 AM | #83 |
Carpe manana
Here's an example of the 9/16" carriage bolt for the 71-72 3/4-1t applications.
Does anyone know if the carriers were painted then installed or painted ahead of install? Mostly I'm curious if the Phillip head bolts were painted or not.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-10-2020, 11:19 AM | #84 |
Mr. Cheyenne
I am excited about the parts I got from LockDoc, though it seems like I did not get "Phillip head bolts" but I guess that is not going to be a big deal.
As luck has it (or bad depending on your view) I had to get a replacement tailgate and during its paint I am having my bracket painted, along with the hardware. But not the carriage bolt/lock.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
11-10-2020, 03:34 PM | #85 |
The Older Generation
You didn't get "Philips head bolts" because I didn't have any. Very few of them I have seen actually have the philips head screws at the top. Here is the picture of the one I sold Rich (first two pictures) and one I still have on a short bed side. If you notice, both of them have hex head bolts in them. They are also mounted the opposite way on each bed side and one is mounted on the passengers side ahead of the wheel well and one is mounted on the passengers side behind the wheel well. Obviously there is every configuration under the sun because a lot of them were added by the owners. Last picture is a picture of the screw mentioned in a couple of posts that looks the same as the original philips head screw for the tire bracket. It has a flatter head but I'm sure no one would notice that unless you are going for a 100 point restoration. LockDoc
11-10-2020, 04:01 PM | #86 |
Mr. Cheyenne
Leon, I meant no offense. I am not at all upset, you could not have sent me any hardware ;-)
11-10-2020, 04:54 PM | #87 | |
I always had the impression the top of the brackets were installed with the #3 phillips, but picture #3 & #4 in post 85 look right to me too, on the assumption they're GR 5 bolts. Similar bolts were used for the front bed panel (e.g., "RBM"), for example. Doc makes a good point, many were installed post factory. Looks clean 72 Tigger.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-10-2020 at 05:11 PM. |
11-10-2020, 05:49 PM | #88 |
The 68 50 th has the original Phillips head screws but I’m missing the round washer and they put a wing nut on it I’ll have to start looking for both. Looks like it’s been modified to add a lock . Going to remove the added metal when I start on it . It’s original as it’s on the spid.
11-10-2020, 07:15 PM | #89 |
Carpe manana
Looking at the very first picture in this thread it would appear that example was painted off the vehicle given the breadth of coverage (if that's original paint). I've got a spare here that I'll check - would be curious what others note.
11-10-2020, 07:25 PM | #90 | |
The bolts on the Blue one are grade 5. Fastenal has the 5/16 inch "Round Head" Philips machine screws in stainless or Zinc plated. I bet any well stocked hardware store would have them too. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-10-2020 at 08:43 PM. |
11-10-2020, 08:06 PM | #91 |
I'm going to look tomorrow at the original fender phillipd head bolts from my stepside. They look very similar
11-11-2020, 01:00 PM | #92 |
Does anyone know what length the upper and lower mounting bolts for the bracket should be? I notice LockDoc mentioned 5/16" in an earlier post so I assume that's the diameter.
Also, if anyone prefers the look of the lower profile Phillips head screw for the top of the bracket, I found something that might be of interest. By doing a little Googling and comparing images found against the ones in this thread, the most similar profile is something called a "Phillips Truss Head" machine screw. They look like this. The truss head screws have a wide, lower profile head. I do realize that the truss head screws don’t have the flat area where the Phillips “cross” is on the factory screws but the overall look is pretty close. Last edited by cericd; 11-11-2020 at 01:56 PM. Reason: Clarity |
11-11-2020, 01:12 PM | #93 | |
If a philips then the top screws are 5/16-18 x 3/4. The bottom are carriage bolts you'd find along the perimeter floor. That said, I saw someplace the "kit" included a spacer of some sort used where a hole is drilled through the bed floor. The bolt for that hole may have some variance I suppose, but it's still a carriage bolt. Changed my guess on how they're painted, now agree with deadhead - seems they would be painted off the truck, a little tough to spray the back well enough while mounted. Best to paint parts disassembled anyway, no matter what the factory did.........more or less
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-11-2020 at 01:18 PM. |
11-11-2020, 11:30 PM | #94 | |
I can't really tell by the pictures on here if the head has a flat area or not. The machine screws in this eBay ad have a flat area but they are only 1/2" long. They must be available in different lengths though. https://www.ebay.com/i/181966238511?chn=ps LockDoc
11-12-2020, 12:19 AM | #95 | |
My 71 truck used the same screws for the jack accessories spring, the heat shield and tailgate handle. I'm only guessing this truck used those screws on the top for the tire carrier. I see my OP is wrong, I recall removing the original carrier and hardware, it's more I threw it all away Installing another, got to have a P13, or whatever it is The truck will likely never see a spare though
11-12-2020, 06:59 AM | #96 |
I used 5/16” Phillips head bolts l bought at the local Ace- don’t remember if they’re stainless? I painted everything separately, then assembled it
71 C10 72 K20 72 K10 Super Kirk |
11-12-2020, 08:45 AM | #97 | |
11-12-2020, 10:36 AM | #98 | |
Good information guys. Thanks. I'm not into factory or period correct but I know there are members who are. LockDoc
11-12-2020, 10:40 AM | #99 |
Mr. Cheyenne
Personally, I like what Leon sent me the other day - carriage bolts all around.
11-12-2020, 11:02 AM | #100 | |
That will give a clean look for sure. LockDoc
