Old 08-17-2016, 08:39 AM   #76
southern parts
southern parts's Avatar
Re: Parts from a 69 cst
Sorry , no help on the engine stand or harness piece.
southern parts is offline   Reply With Quote
Old 08-17-2016, 09:17 AM   #77
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Is the seat still available? I can pick it up. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-19-2016, 12:25 AM   #78
caddyfront
Is the cluster still available? How much shipped to 93267
Also is the intermediate steering shaft available and how much?
caddyfront is offline   Reply With Quote
Old 08-25-2016, 12:46 PM   #79
greywurm
do you have an antennae? I only have am, but would be adding am/fm at some point and my antennae is toast. Doesnt need to be show quality, but in one piece would be nice. thanks
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline   Reply With Quote
Old 08-25-2016, 08:13 PM   #80
Don Brace
Active Member
Do you have a distributor hold down clamp?
Don Brace
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 08-26-2016, 11:19 AM   #81
gmc 2500 4x4
5 blade clutch fan $50. is it 18''?
gmc 2500 4x4 is offline   Reply With Quote
Old 08-26-2016, 12:09 PM   #82
southern parts
Caddyfront - the cluster is good for parts . the gauges are faded and it has an extra hole in the bezel from the manual throttle. $65 plus shipping for it and the intermediate shaft
Greywurm - sorry no help
Don brace- $10 shipped if I have an extra. I will check tomorrow.
gmc 2500 4X4- I will check the fan size tomorrow.
Old 08-26-2016, 12:10 PM   #83
COOP3726
Do you still have the steering column? If so, how much for the complete unit? Also power steering gear box available? Thanks.
COOP3726 is offline   Reply With Quote
Old 08-26-2016, 12:19 PM   #84
In The Ten Ring
Hey, do you still have the fan shroud?
If so, does it have any cracks? Are the bolt points intact?
Will it fit any radiator core support from 1969 to 1972?
If it will fit my 1972 I'd like to have it.
In The Ten Ring is offline   Reply With Quote
Old 08-26-2016, 01:41 PM   #85
southern parts
Coop3726- the column has been taken apart , cleaned and bearings greased. One of the tabs that holds the pointer is broke off and let's it move to the side a little. You can see this in one of the column pics. I all ready have a gearbox off. $125 on the column $75 on the gearbox. I'll be at the. N E Ga swap meet on the 3rd if your interested.
In the ten ring - the shroud is in good condition with no cracks. It should work in all 67-72 trucks with a small block V8.
Old 08-26-2016, 02:42 PM   #86
COOP3726
I may see you there. Thanks.
Old 08-27-2016, 12:36 PM   #87
southern parts
Dan brace I do have another distributor mount. GMC 2500 4 X 4 the fan is 18 inch diameter
Old 08-27-2016, 07:12 PM   #88
gmc 2500 4x4
i 4got i asked you, im sorry i just bought 1
Old 08-27-2016, 08:42 PM   #89
ripdog28
ripdog28's Avatar
Southern parts, do you have the passenger side floorboard vent? I need one.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 08-27-2016, 09:06 PM   #90
southern parts
do you need an a/c or non a/c vent?
Old 08-27-2016, 09:15 PM   #91
ripdog28
ripdog28's Avatar
May have said it wrong. The kick panel vent door.
69 c-10 BBC
Old 08-27-2016, 09:25 PM   #92
southern parts
I understood what you are looking for . the a/c passenger vent is different than the non a/c vent.
Old 08-27-2016, 09:39 PM   #93
ripdog28
ripdog28's Avatar
Non AC.
69 c-10 BBC
Old 08-27-2016, 09:53 PM   #94
In The Ten Ring
I'd actually like to put it onto my 6 cylinder (250 straight 6). Do you think it'd fit onto that?
Old 08-29-2016, 12:16 AM   #95
caddyfront
I'll take it
Old 08-29-2016, 07:55 PM   #96
In The Ten Ring
Originally Posted by caddyfront View Post
I'll take it
If are you speaking for the fan shroud, better if you do get it. I don't think it will work with the size radiator I have.
Old 08-29-2016, 08:21 PM   #97
ToySoldier
Is the side trim good on the bed? if so how much for the side chrome off the bed of the truck?
ToySoldier is offline   Reply With Quote
Old 08-30-2016, 12:37 AM   #98
caddyfront
Sorry I meant I'll take the cluster and intermediate shaft
Old 08-30-2016, 06:41 AM   #99
southern parts
ripdog28 - $15 plus shipping. It will be this weekend before I can get a quote on shipping.
In the ten ring- I've never seen a v8 shroud in a 6 cyl trk.
Toy Soldier - sorry, no. bed trim.
Old 09-04-2016, 05:54 PM   #100
ck5566
Do you have other Seat Belt Retractors L & R, don't need to be in working order.
ck5566 is offline   Reply With Quote
