Old 11-15-2017, 11:02 PM   #76
Black_Sheep
Black_Sheep's Avatar
Re: Brother's keeper - '58 Stepside build
Originally Posted by Dads Burb View Post
What steering column are you using? Looks like you are using the stock column support.
Also noticed that you had a smooth cowl vent cover. Is that one that you fabricated or is that the fiberglass one?
Any plans to add side plates where you extended the cab floor?
Column is an early 70's Gm, most likely a Cadillac because the turn signal switch was wired for cornering lights.
The smoothed cowl panel is steel, I purchased it from Brothers.
Step mod will remain open underneath.
Black_Sheep is offline   Reply With Quote
Old 11-17-2017, 08:35 PM   #77
Black_Sheep
Not a lot to show for this week but I did manage to get the dash wired up, oil and water temp gauges installed and a few other odd jobs wrapped up...
Old 11-22-2017, 11:23 PM   #78
Black_Sheep
This week I installed the water temp and oil pressure gauges, wired up the dash and installed a modern, high output heater. In the meantime I had the front fenders blasted and the front bed panel blasted and epoxied. Both fenders have the usual rust perforation in the bottom corners and a few minor dings, the bed panel came out perfect...
Old 11-22-2017, 11:28 PM   #79
Black_Sheep
sheetmetal
Old 11-23-2017, 01:54 PM   #80
Rude Dude
Rude Dude's Avatar
I like your gauges are they stewart warner green lines?
Rude Dude is offline   Reply With Quote
Old 11-23-2017, 04:38 PM   #81
Black_Sheep
All except the Speedo, it's a Speedhut GPS speedo with custom artwork to match the SW gauges. The tach is from Mooneyes
Old 11-26-2017, 08:09 PM   #82
Joe Pass
Joe Pass's Avatar
I need to follow....
Joe Pass is offline   Reply With Quote
Old 11-26-2017, 08:26 PM   #83
Advanced Design
Advanced Design's Avatar
Your truck is coming together very nicely Black Sheep....it is a work of art!
Advanced Design is offline   Reply With Quote
Old 11-28-2017, 11:16 PM   #84
Black_Sheep
Thanks, it's finally starting to come together. My goal is to have it ready by the MSRA Back to the 50's in June. There's 29 weeks to go, I think I can make it.
This weekend I managed to wrap up the cab wiring and run most of the other circuits for lights and the electric fan, etc... they won't get terminated until final assembly.
I hooked up the battery and tested everything, we are good to go...
Now I'm waiting on patch panels for the fenders so I can get back to doing bodywork. I think the worst is behind me...
Old 12-08-2017, 08:11 PM   #85
Black_Sheep
Due to work and family obligations I haven't got a whole lot done this week. But, in keeping with my goal to get SOMETHING done, no matter how small so this build continues to make progress. This week I managed to convert the dome light to a single contact LED bulb and used a lens from another dome light to finish it off. I also got the tail light and fuel gauge wiring routed along the frame, put the division bar "mohair" in place to finish up the otherwise restored vent window assemblies, attached the kick panel speakers and wired up the GM electric window switch which will operate the passenger side door solenoid.
Old 12-08-2017, 08:25 PM   #86
Scottish58chev
Every job is one step closer to completion, looking realy good
Scottish58chev is offline   Reply With Quote
Old 12-09-2017, 04:06 AM   #87
Nut Case
Nut Case's Avatar
What heater/ac unit and model # are you using, It looks great..
Strong work
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 12-09-2017, 08:15 AM   #88
Black_Sheep
Strong work
Keep on keepin on
NC
It's from Summit Racing
https://www.summitracing.com/parts/sum-991106
Old 12-09-2017, 01:49 PM   #89
Black_Sheep
Working on the passenger fender today...
Old 12-09-2017, 01:54 PM   #90
Black_Sheep
I have the patch fitted but it won't be welded on until I pick up some rust converter and weld through primer.
Old 12-09-2017, 07:43 PM   #91
Flames97
Flames97's Avatar
I just read through your build thread, very nice!!
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 12-28-2017, 12:34 AM   #92
Black_Sheep
Haven't updated for a while, finishing up rust repair on my fenders and trying to massage out some dents that were previously mudded over.
Old 12-28-2017, 06:04 AM   #93
Scottish58chev
Nice work
Old 12-28-2017, 09:18 AM   #94
Joe Pass
Joe Pass's Avatar
Agreed, nice work....
Old 12-28-2017, 07:23 PM   #95
Black_Sheep
Thanks guys, welding sheet metal patch panels is uncharted territory for me. It's actually going better than I hoped.
Old 12-28-2017, 07:29 PM   #96
Black_Sheep
I don't know what happened to the pictures in the beginning of the thread, here's a link to build photos if anyone's interested.
103 Photos of Mark's 1958 Apache Build
Old 12-29-2017, 12:16 AM   #97
Flames97
Flames97's Avatar
Great Work, really like this build!!
Looking at the smooth fire wall is making me rethink how I smooth mine out! I've just been filling the holes.
-Aaron
Old 12-29-2017, 10:42 AM   #98
Joe Pass
Joe Pass's Avatar
Nice to see the pictures.....
Joe
Old 12-30-2017, 11:47 AM   #99
l78vetteman
l78vetteman's Avatar
Looking Good!
Are you happy with the Permatex rust treatment?
Cheers, Rob
l78vetteman is offline   Reply With Quote
Old 12-30-2017, 03:10 PM   #100
Black_Sheep
Originally Posted by l78vetteman View Post
Looking Good!
Cheers, Rob
Time will tell if the Permatex stuff is any good, generally their products work well so we'll see.
Today I got the firewall and front floor covered with FatMat floor liner. It is supposed to reduce heat and road noise in the cab. Sound is noticeably muffled when I rap the covered area with my knuckles
