Old 02-19-2018, 12:23 PM   #76
Trackman101
Trackman101's Avatar
Re: BBC Turbo 400 to LT4 T56
Originally Posted by clay68c10 View Post
Wow!
I just read thru this, very nice work you are doing there. Very cool you are going with the Tremec. I'll be using a TKO in mine.
Is that the Capt Fab master cyl kit?
It is. It's well thought out.
Filled the circuit for the supercharger. It took almost a full gallon. That's way more than the stock set up.No leaks! The Afco heat exchanger holds a ton of coolant. I am hoping to get away with no reservoir. We'll see if I can get all the air out.
Might throw the engine coolant in also.
...What I really need to do is get to finishing the wiring.
Trackman101 is offline   Reply With Quote
Old 02-28-2018, 08:38 PM   #77
Trackman101
...Well one step backwards today. I put some juice in my radiator and come to find out it doesn't hold fluid. I must of poked a hole in it when I welded tabs to it for the shroud. And I found out when draining the rad it pours all over the frame and some cooler lines. It made for a nice mess. I'll take the time to move the petcock so I can actually drain fluid with out making a mess.
The GM fuse panel fits snugly in its' new home. I glued a tab to the steering column bracket for a switch to allow the ecm to take fuel away when I drop the clutch. It helps to decelerate the engine and makes upshifts quicker and easier. It will also control a relay for a safety when starting
Old 03-11-2018, 10:09 PM   #78
Trackman101
It's alive!
I only ran it for a few seconds as I was by myself and didn't have a spotter for potential leaks. Surprisingly enough no leaks so far. I am sure I will have plenty of glitches to work out but as for starting the first time I turned the key I was pretty happy with myself. Hope to heat cycle the engine later this week if all goes well.
The dash is all hooked up. There is a bit of a learning curve to get it configured correctly but I am starting to get the hang of it.
Waiting on a shifter stick and a couple low profile ac fittings from Summit to finish off the plumbing.
Old 03-12-2018, 12:28 AM   #79
cornerstone
cornerstone's Avatar
Congratulations! Is there a video available so we can hear that BEAST?
cornerstone is offline   Reply With Quote
Old 03-12-2018, 08:40 AM   #80
builtbyKane
builtbyKane's Avatar
That's awesome. Keep us posted.
builtbyKane is offline   Reply With Quote
Old 03-13-2018, 09:16 PM   #81
Trackman101
Finally got a low profile flange fitting that clears the frame for my low mount compressor. I can now start plumbing. I don't know much about ac. Does it matter where I put the high and low fittings for charging the system?
I also got conformation from GM which port was input and output on the oil cooler. (I had to remove it as there was a conflict of space with the crossmember.)
Old 03-14-2018, 03:02 PM   #82
knomadd
knomadd's Avatar
I just found your build. Looking good! I'll be following along.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-24-2018, 05:37 PM   #83
Trackman101
Finished up the plumbing for the A/C. I ordered a AC vacuum pump and gauge set. I'll attempt to charge the ac on my own when the time comes. Anybody have suggestions or approximations for the amount of oil and refrigerant I will need?
Reinstalled the interior and bolted on a stick. Not sure its the "one" but will work for now. I'll probably build one a little shorter and angled a bit toward the driver. It has bit more throw than I 'd like but I'll try it out for a bit before spending money on a short throw mount.Haven't decided on a boot to use yet.
Man the Dakota Digital is worth every penny. After a few minutes reading the instructions and downloading the app I configured the dash from my phone and have all the gauges reading correctly. When I put the truck in gear on the lift even the speedo operates.Time will tell if it is calibrated correctly.
I have brought the engine up to temperature a couple times. So far so good.The first fan comes on once it reaches its set point so I'm confident I have them wired correctly. I've burped a bunch of air out of the supercharger system.
Now to bleed the air out of the steering, clutch and brakes. I may actually hate bleeding brakes more than wiring!
Old 04-15-2018, 10:50 PM   #84
Trackman101
While I am waiting for stupid winter to end I added a flex fuel sensor so I can can run E85. Once I get the tuning done I should see another 30-40hp. Engine bay is officially done. ...other than charging ac but as you can see I am in no rush to get that done. Hopefully in the next 2 weeks things will smarten up and I can begin tuning and getting the bugs out.
...wish I would have closed the hood
Old 04-16-2018, 12:10 AM   #85
cornerstone
Lots of hard work, perseverance, and a little spendy of the dinero... and this is what you get. BEAUTIFUL
Old 05-22-2018, 06:44 PM   #86
Trackman101
I have a bunch of miles on the truck now. I have been using a remote tuner to tweak the stock tune for the headers and custom intake.Overall pretty happy with the progress. The T56 Magnum is shifting smooth and the 3.50 gears in the back seem to move the truck well. I am having a headache with the ac system. I have a new compressor, condenser and dryer with all new hoses. System holds a vacuum. I can't seem to get the low side to accept freon. I have no idea why. If anyone has ideas let me know. It's a month wait to get into a decent shop around here.
Old 05-25-2018, 09:32 AM   #87
meenaggie
Turned out great! I still can't believe you got all that to fit with the factory A/C box on the firewall.
meenaggie is offline   Reply With Quote
Old 05-25-2018, 11:39 AM   #88
builtbyKane
It sounds like it turned out great. We would love to some warm weather pictures.
Old 05-25-2018, 09:54 PM   #89
t300
wow thats a mean ride. nice work! must be a canadian thing
t300 is offline   Reply With Quote
Old 10-15-2018, 10:43 PM   #90
68 short step
great build....
68 short step is offline   Reply With Quote
Old 10-16-2018, 09:46 AM   #91
Trackman101
Thanks for the compliments guys!
Had a decent summer with the truck. Still have a bit more rubber on the rear tires than I would like.A couple of road trips got cancelled because of the smoke and then some bad weather. Still need to refine some things including the AC and how the engine responds when touching the clutch especially on fast down shifts. Other that that no issues at all.
Nice power and better fuel mileage than anything else I own!
Old 03-25-2019, 01:19 AM   #92
Jason7121
Jason7121's Avatar
Truck turned out great. I'm getting ready to do the same swap for a friend of mine. Would you mind telling me alittle about the fuel system like what size fuel line was used 6an 8an? Did you have to put a regulator inline to maintain 60 psi? Any help would be appreciated thanks.
Jason7121 is offline   Reply With Quote
Old 03-26-2019, 10:14 AM   #93
Trackman101
I used a pump from a CTSV designed for use with the LT4. I modified my tank to fit it. Surprisingly not that expensive. It has an internal regulator so there is no need to add another. I ran 3/8 stainless lines and 6an flex. The pump and connection at the engine are similar size.
Old 03-27-2019, 03:21 PM   #94
Jason7121
Jason7121's Avatar
Thanks for all the help we got a ZR1 pump for the LT4. I'm sure I will have more questions haha.
