Old 03-06-2020, 09:35 AM   #1
hatzie
Moderator
hatzie's Avatar
Re: 1973-1991 Dual fuel tank systems theory of operation
It sounds like someone wired past the valve directly to the LH sender.
The valve and switch are working as they should.
Does the SPID (Service Parts Identification) label in the glovebox call out Option NL2?
The six position Weatherpak on the valve is lettered A-F. F should not have a wire so A is on the opposite end of the plug... easy to find.
With your Digital Volt Ohmmeter. What ohmage do you get when checking resistance between Valve plug A to ground & Valve plug C to ground. One of them should be 90Ω ish and the other should be somewhere around 29Ω ish... give or take a few Ω. The graph in my post above shows Ohms VS gauge position.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-06-2020, 10:02 PM   #2
Hart_Rod
Hart_Rod's Avatar
You may be correct about the rewiring, but this is the cleanest most unmolested old truck I have ever owned. It is a NL2 according to the window sticker. I'll ohm out the wires some time this weekend. Thanks again for all of your suggestions.
Hart_Rod is offline   Reply With Quote
Old 03-06-2020, 10:14 PM   #3
Hart_Rod
Hart_Rod's Avatar
This is the diagram I'm using to troubleshoot.
Old 03-07-2020, 09:31 AM   #4
hatzie
Moderator
hatzie's Avatar
That's the NL2 option wiring for the 87-91 TBI trucks.
There's a two position Weatherpak with the wire from the B terminal of the six position Weatherpak on the valve. This plugs into the standard wiring harness. That's where I'd start looking for Mickey Mouse wiring.
This all assumes that pouring five gallons in the LH tank will raise the needle on the gauge past 1/4 tank.
Does it do that?
Old 03-07-2020, 10:20 AM   #5
Hart_Rod
Hart_Rod's Avatar
Does it do that?
LH tank showed 3/8s of a tank and I put approx 13 gals and the gauge went to full.
Old 03-07-2020, 02:24 PM   #6
hatzie
Moderator
hatzie's Avatar
So the gauge is working.
It really sounds like the LH sender is tied directly to the gauge bypassing the sender switch in the valve.
Old 03-08-2020, 05:40 PM   #7
Hart_Rod
Hart_Rod's Avatar
Well after reading this thread about 100 times, studying multiple diagrams and thinking about everything that Hatzie has told me to look at, I finally figured it out. Somebody had two of the connectors plugged in wrong! Both of these connectors are by the LH tank and the wire colors are very similar (see diagram below). It's crazy that everything still worked (other than the RH tank reading incorrectly). I plugged the connectors in correctly and everything works perfect now. Thanks everyone for all the help, especially Hatzie!
Old 03-09-2020, 04:18 PM   #8
hatzie
Moderator
hatzie's Avatar
Thanks for posting back what you found. It helps people out that may be having the same or similar issue.
Enjoy the truck it looks like a nice machine.
Old 03-25-2020, 11:04 AM   #9
Hart_Rod
Hart_Rod's Avatar
This may have been asked, but I didn't see it anywhere. How do you know what tanks sizes came in our trucks?
SWB - both tanks 16 gallon capacity?
LWB - both tanks 20 gallon capacity?
Thanks in advance!
Old 03-25-2020, 11:48 AM   #10
hatzie
Moderator
hatzie's Avatar
LWB could be either a 16 or 20 single tank. I've owned both.
I doubt SWB has the room for a 20 gallon tank.
Not sure someone that went to the trouble of ordering NL2 and the 8' bed would order a pair of 16 gallon tanks. I doubt a dealer would order something odd like that for stock either.
Honestly you can fit the 20gallon tank with the 16 gallon straps so if you have a LWB truck just get the 20 gallon tanks and have done with it.
Something that occurred to me that needs to be said.
The NL2 dual tank harness is an add-on to the production fuel system wiring that plugs right into the existing single tank sender/pump connection on the standard harness. Probably for ease of assembly and reducing the number of electrical harnesses to select on the line. This also would allow a dealership or customer to add it if desired but I doubt that was part of the GM thought process.
Someone swapped the standard production fuel tank connector and the connector from the valve. Probably when doing service on the LH tank.
I have several colors of 3M Super 33+ Electrical tape that I wrap on harness wrap ends with plugs that can be interchanged... to avoid the mistake you discovered.
The LH fuel pump was running dead head to the valve when the RH tank was selected. That can't be safe. Not sure what mayhem you avoided by fixing this but it's all good now.
Old 03-25-2020, 01:02 PM   #11
hatzie
Moderator
hatzie's Avatar
Originally Posted by Ford Assassin View Post
I have a stand alone harness with its own fuel pump relay and power wire. Any reason I can't just plug that fuel pump power wire from the LS harness into the 'test' wire on the factory TBI relay on the firewall? Trying not to butcher the factory harness, nor make more work for myself.
Terminal D, the hot coil terminal of the fuel pump relay, was driven by the TBI ECM on Connector A Terminal 1... if the wiring diagrams are correct. I posted a snippet of the fuel pump circuit in the tech writeup.
The most elegant way to do this would be to drive the relay coil exactly like the original setup.
I'd find the original TBI ECM end of the fuel pump relay drive wire and attach it to the fuel pump drive on the LS PCM. This will offload any high current draws that might make the PCM fuel pump driver transistor unhappy.
You should be able to buzz the original ECM Connector A Terminal 1 wire to the fuel pump relay terminal D to be sure you have the correct wire.
Old 03-25-2020, 01:30 PM   #12
Ford Assassin
Ford Assassin's Avatar
Question Re: 1973-1991 Dual fuel tank systems theory of operation
I guess some of the info here is over this redneck's head. Lol
Dumb it down for me, which color wire do I need to splice into on the firewall relay harness to the LS fuel pump wire into to make it all work? The LS harness already has its own 40 amp relay with power just for the fuel pump. It's a single 12v power wire intended to wire directly to a single fuel pump.
Thanks.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 03-25-2020, 03:00 PM   #13
Hart_Rod
Hart_Rod's Avatar
Thanks.
If you don't want to use the factory relay, then something like this coming from your EFI standalone pump relay...
Old 03-25-2020, 03:09 PM   #14
Ford Assassin
Something like this...
Awesome!!
Exactly what I needed. Thx!!
Cable
Old 03-25-2020, 09:18 PM   #15
hatzie
Moderator
hatzie's Avatar
Bypassing the relay is a bad idea.
It's a more reliable setup to use the 1987-91 fuel pump relay as it was originally setup by GM.
Why?
The relay isolates the PCM from the fuel pump power circuit. This keeps fuel pump wiring problems and fuel pump problems from smoking the fuel pump driver transistor in your PCM. When you let out the magic smoke you can't put it back.
The original TBI ECM has two connectors.
A & B.
The individual terminals in each ECM connector are numbered.
The fuel pump relay connector terminals are lettered A-F. As you can see in the above wiring diagram.
Splice the LS fuel pump power wire to the TBI fuel pump power wire... according to the diagram above it's a Green with White stripe wire from the old ECM Connector A on Terminal position 1 to the relay plug terminal position D.
Old 03-25-2020, 09:34 PM   #16
Ford Assassin
Why?
A & B.
I guess I am confused. I have a separate relay for the fuel pump in my stand alone harness. Why would I want to run through another relay? Not meaning any insult, just asking for clarification.
Cable
Old 04-07-2020, 06:34 PM   #17
Ford Assassin
Almost done with my LS swap into my dually...
Will putting 12v accidentally on the wire going to the tank sender kill it? We weren't getting the fuel pump to kick on so ran a hot lead straight to the 2 wire connection, but my buddy touched the sender wire for a second instead of the pump wire. The pump works find, but the driver side tank isn't reading. Needle pegged on empty. The passenger side tank sender is working fine.
Cable
Old 05-18-2020, 04:07 PM   #18
Nick_R_23
Nick_R_23's Avatar
Speaking of LS swaps, does an 85-86 C10 with factory dual tanks have the correct wiring to install an updated 65 psi valve or is it still required to get the whole harness/switch/valve kit?
Nick_R_23 is online now   Reply With Quote
Old 05-19-2020, 12:00 AM   #19
rodstored-72
chevy truck fan
rodstored-72's Avatar
ditto for me! ...
I believe that the answer is yes, but I enjoy hatzies terrific knowledge! so hopefully he will guide us straight...
rodstored-72 is offline   Reply With Quote
Old 05-23-2020, 09:23 PM   #20
GonicGM
GonicGM's Avatar
I recently had my OEM Pollack valve completely fail to the point of requiring replacement. For decades it worked to the point of being passable. It really never had trouble switching to the left tank, switching to the right was finicky. When it did not switch completely, the gauge would over sweep clockwise and truck would starve for fuel. I would switch back and forth and to the point it finally read properly on the RH tank, the switch-over was full and complete. That process recently failed and neither tank would read properly but I could pull from the left, I just didn't know how much fuel in LH tank. Needless to say, time to change valve.
I went through and tested 9 or 10 valves I had with test on truck, wife inside, me underneath. One flat did nothing. All others you could clearly hear and feel the switching action. Most read properly on LH tank, RH tank gauge would over sweep clockwise. Only two passed the test 100%.
It seems a comprehensive test requires fuel gauge feedback. Most valves fail for RH tank selection. All but one valve felt and sounded operable on simple bench test, even the one just removed, however, such valve will not uncover ports for RH tank.
FYI
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 05-24-2020, 09:19 AM   #21
hatzie
Moderator
hatzie's Avatar
The wiring is the same. Pollack mad a change to the shuttle and body to withstand 65psi. Or they actually tested it at that level and discovered it works...
Either way I wouldn't put an old valve together with a higher than TBI pressure fuel pump.
FYI
Sounds like they are gummed up or worn out. You might be able to soak the valve section in hot PineSol and water to free them up. How long they'll live after that treatment is questionable at best.
I would probably exercise the valve to keep it happy.
Fill up both tanks. Run one down to 1/2 and switch over. Fill the low tank before the runnig tank is down to 1/2 and don't switch back til the one you're operating out of is at 1/2.
Then flip back and two that way so the valve doesn't have a chance to get gummy and stuck.
On long trips you can run down to 3/8 switch and grab a fill when both are down. That way you have 1/2 tank of fuel between them so it's not urgent. I usually have to urgently go to the Mens room or get some caffeine before I need fuel.
Old 06-14-2020, 02:23 PM   #22
rodstored-72
chevy truck fan
Hatzie,
THANK YOU AGAIN for your time and sharing of your knowledge. I am currently looking to install my new '87 tbi tanks with installed AC DELCO EP 381 fuel pumps I also have a replacement AC Delco fuel valve (U7000) and a replacement WVE pigtail connector. I am wondering if you might share what/how I should connect the pump wires? the pumps have the "factory" weather pack connectors on them?
again thank you for your knowledge and time!!
the truck is 1986 2wd swb silverado with factory duel tanks doing a 4.8LS swap.
Old 04-08-2021, 06:10 PM   #23
SunSoaked
SunSoaked's Avatar
Originally Posted by rodstored-72 View Post
Hatzie,
I have a similar question. On my 85 with factory dual tanks, am I splicing into the power wires to the senders to run the fuel pumps? Where does the "relay" come into play mentioned in earlier posts? Was that just a safety feature for the factory TBI systems from 87 up?
SunSoaked is offline   Reply With Quote
Old 09-30-2020, 03:06 PM   #24
Mixup
I have a 1987 Chevy pickup with dual tanks. The plug on the dual tank switch has been cut off and I have 4 wires hanging out of the dash. tan, tan w/white stripe black w/white stripe and gray.Does anyone know how they go onto the new switch i bought?
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 10-02-2020, 09:51 AM   #25
aggie91
I'm just glad to be here!
aggie91's Avatar
There is a diagram on Post #76. It has the info you are looking for on the switch.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
