Old 10-04-2018, 11:18 PM   #1
joedoh
joedoh's Avatar
Re: Starting a 52 Chevy 3100 Project.
looking super great man
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-05-2018, 12:15 AM   #2
28TudorAZ
28TudorAZ's Avatar
Thanks. I plan on hitting some junkyards tomorrow. I really want to keep moving on this thing. I did get the transmission tunnel today. Wow summit fast shipping.
28TudorAZ is offline   Reply With Quote
Old 10-07-2018, 06:55 PM   #3
28TudorAZ
28TudorAZ's Avatar
Built the transmission mount today.
Old 10-10-2018, 11:12 PM   #4
28TudorAZ
28TudorAZ's Avatar
Finished welding up all the cab mounts and transmission mount and painted the frame. Next is the front end rebuild and 2 "dropped spindles. Also still need to weld up some holes in the cab before I put it back on.
Old 10-11-2018, 10:05 AM   #5
8man
Man you are making time. Good work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 10-13-2018, 10:49 PM   #6
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
be careful with spacers that long, it will add additional stress to the wheel bearings.
GreasyLikeaBurger is offline   Reply With Quote
Old 10-16-2018, 01:53 AM   #7
28TudorAZ
28TudorAZ's Avatar
Are you speaking from experience?
Old 10-16-2018, 02:43 AM   #8
MiraclePieCo
MiraclePieCo's Avatar
I've heard that before too, but I've run spacers on various vehicles since the 1970s and never had a problem. They still make me concerned. Has anyone had a bearing failure they could prove was attributed to spacers?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-16-2018, 12:41 PM   #9
28TudorAZ
28TudorAZ's Avatar
Exactly. Everyone has heard. I researched it quite a bit and never found anyone who actually had the issue. Did find a video explaining why it changes the gravity a little but said it was not enough to actually cause any issues. My guess would be guys with big trucks with big heavy tires have problems with spacers and bearings. There are arguments that go both ways. I really didn't want to spend $1000 for some custom A-arms. Maybe down the road if I have issues but I suspect I will not.
Old 10-16-2018, 03:36 PM   #10
dsraven
have you done a "tire on and suspension at full compression" turning test to ensure the rubber doesn't tear a fender off when turned all the way and the suspension bottoms? with the spacers the tires do more of a sweep during a turn so they may get closer to the wheel openings than you may realize. it would suck to find that out too late.
I am sure you have done the research and found the video on scrub radius, tire size and wheel offset issues and steering included angle etc. your truck, do it like you want. as long as it is safe to drive on the same roads as the rest of us and our kids.
dsraven is online now   Reply With Quote
Old 10-16-2018, 04:55 PM   #11
28TudorAZ
28TudorAZ's Avatar
Considering I just put them on there 3 days ago and the cab and front end are still off what do you think? I guess I will see when it actually runs and drives and adjust accordingly.
Old 10-17-2018, 03:28 AM   #12
MiraclePieCo
Awesome, lol - opinions are plentiful, experience is rare!
Old 10-17-2018, 11:08 AM   #13
mikebte
Exactly. Everyone has heard. I researched it quite a bit and never found anyone who actually had the issue..
Crazy the stuff people make up. Porsche used wheel spacers from the factory on the 928 and it would run 170MPH. I think if used correctly you will have no issues. Correctly being the key word.
I remember 10 years ago I was telling people how an electric fan was better than a mechanical fan. You would think I was taking ways peoples kids, they would tell me how wrong I was and it was a phase. Now look. Most people speak hear say and not facts.
Keep up the good work, enjoying you build
mikebte is offline   Reply With Quote
Old 10-20-2018, 12:53 AM   #14
GreasyLikeaBurger
Well I actually work for Porsche as a tech, 10-15mm spacers are nothing to bump out a wheel for fitment. But when you increase that to 3+inches, you are changing the geometry of the front end.
Old 04-26-2020, 09:32 AM   #15
Desert1957
Desert1957's Avatar
Truck looks awesome. Not to hijack this thread but what are the options for longer control arms? thanks...
Desert
Desert1957 is offline   Reply With Quote
Old 04-29-2020, 01:51 AM   #16
28TudorAZ
28TudorAZ's Avatar
http://michiganmetalworks.com/store/...product_id=144
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
Old 10-18-2018, 04:15 AM   #17
Jesse Z
Their opinions are typically given with dire warnings about you killing busloads of orphans and not being on the same highway with their family, lol!
Enough digression: back to the build thread please!
Jesse Z is offline   Reply With Quote
Old 10-23-2018, 12:51 AM   #18
28TudorAZ
28TudorAZ's Avatar
So I got the cab back on over the weekend and welded up the firewall holes and bolted it up. Also today I had the day off and put the 2" lowering blocks on the back axle and welded up a bunch of holes on the inside and old fuel filler hole. I also ordered a steering column, steering shaft, steering joints, transmission cooler, a 16 inch fan and a pedal assembly today. This should keep me busy for a while. Not that I don't have anything to do but I like to skip around so I don't get frustrated or bored. Plus I can't put the front end back on till all of this is on there.
Old 10-25-2018, 07:34 PM   #19
28TudorAZ
28TudorAZ's Avatar
Finally got the dash ready for paint.
Old 10-25-2018, 07:48 PM   #20
joedoh
joedoh's Avatar
looks great!
Old 10-28-2018, 12:50 AM   #21
28TudorAZ
28TudorAZ's Avatar
Built the brackets for the radiator support, fan brackets and mounted the transmission cooler today.
Old 11-03-2018, 06:43 AM   #22
54ChevyLs
54ChevyLs's Avatar
Your doing some excellent work! Keep it up!
54ChevyLs is offline   Reply With Quote
Old 11-03-2018, 09:44 PM   #23
28TudorAZ
28TudorAZ's Avatar
Thanks. Got the steering column mount made up.
Old 11-04-2018, 08:36 AM   #24
8man
Nice looking dash, good work on the vents.
I got the same steering column installed with my buddy in the 48.
8man-aka Robert
Old 11-04-2018, 05:32 PM   #25
28TudorAZ
28TudorAZ's Avatar
Got the power booster and pedal assembly put in. If you don't use the s10 pedal setup you can cut the end of the brake rod and tap it to use with aftermarket pedal assembly.
