![]() Join Date: Mar 2007
Re: 59 Apache/C6 Corvette build
Nice job on the fenders...it looks stock
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
We added 1.5" and it looks very stock to the naked eye. I needed the room for the factory offset Corvette wheel. I was able to get a p355 tire on the 19x12.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
![]() ![]() Join Date: Oct 2014
Wow, that fender work is phenomenal!
![]() Join Date: May 2007
beautiful fab!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
Here is a pic looking back. Hard to tell it's 1.5" wider.
Getting bed floor situated. Need a 4" floor lift and decided to have a tilt up floor.
I had my old tailgate and thought the script would look good on the back of the floor lift.
Nice detail on the rear bed sill. Looking good..
Marc
where did you get your tailgate release from ????? first time i see one like that awsome
Mar-k. Very nice quality. The whole bed is from them.
The tailgate has two bear claw latches and works smooth.
Bed floor coming together.
![]() Join Date: Jan 2015
beautiful fab work sir!
Looks great! is that bed tilt setup a kit or did you fab that? I just ordered a couple "bed tonneau cover" gas struts and a couple ball mounts... not sure if its going to work until Mr Amazon drops it off
1959 Apache Fleetside Short Bed |
#13 |
It's not a kit. We are building a design we laid out on paper with Camaro trunk hinges and an electric assisted bear claw latch. The rest is 1" square tubing. The bed wood will attach with Mar-k strips and some threaded wood inserts from the underside. I didn't want to use the L strip on the bed sides. I wanted to have the wood bump up to the sides with no carriage bolts.
#14 |
Tilt bed framing done and working. I have several rubber adjusters in several places that keep all squeeks away.
#15 |
Truck is looking great! Your fab work is top notch!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#16 |
Thanks, Moving on to do the wood in the bed next.
#17 |
Wow, amazing work!!!
#18 |
meaty!
#19 |
Bed floor dialed in and done. Ready for wood. Added 60lb gas struts to lift and keep from lifting all the way up. Quick disconnects make lifting all the way up easy. I kept the gas helpers on the hinge, they keep it straight up when I remove the long struts.
#20 |
Can I just shamelessly steal this entire setup?
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
#21 |
A320 Pilot/USAF Retired
Nice job on the tilt bed floor!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#22 |
![]() Join Date: May 2010
I just read back through this entire thread and all I can say is "WOW". And that 55 Plymouth grill looks right at home in this truck.
#23 |
Update
#24 |
Looking good!
#25 |
Exhaust time
| Bookmarks |
