#76 |
![]() ![]() Join Date: Jan 2005
Re: Reproduction Tach Dash Bezel Lens Text Not Lighting Up
That's good news. I got pretty good at removing and disassembling my gauge cluster through all of this debugging, and I know exactly which tools to grab. I hope I don't have to pull it apart again for a long while.
#77 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
I know how you feel, twice is one too many. I also got a new (to me) temp gauge as might was really discolored (brown stuff on it). When I took it out completely there was an old time orange rectangle price sticker on it ($10). So at some point it was replaced with a crapy used part.
Though I just noticed I am getting bleed through on the left turn signal, I guess the little cardboard can slipped somehow (booo). So I see #3 coming to me (stupid me). I think I'll end up doing it when I get my radio in.... Edit: To be perfectly clear, I was unable to ready any text, digits, words, etc or even see a smidge of the speedo needle before swapping out the lens and tin. Once it got dark I could not tell what speed I was going.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 01-05-2021 at 12:02 AM. |
#78 | |
#79 | |
low n' slo
![]() Join Date: Mar 2009
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#80 |
Mr. Cheyenne
@pjmoreland The bleed through looks worse on the photo but I am pretty sure it was not there before this lens/tin swap. I just did a drive and perhaps I can live with it - its a real pain to take it out and break things down. I am thinking it is that seal under the cardboard cone that is causing it (its all hard).
@kev2809 For my LED bulbs, see a post a few back from me: https://67-72chevytrucks.com/vboard/...5&postcount=69 Not only is the new lens painted on the correct side, it seems milkyer? I do love the green color - this is how it should have looked the 1st time around ;-) Attaching my lens, the one in the dash is the new and the one over it is the "painted wrong" lens. Cannot really see what I mean about the color shade different but I could see it for sure.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#81 | |
low n' slo
#82 |
Mr. Cheyenne
Yep - they made good on it once it was pointed out to them (hoping to get a proper refund once I send the bad lens back). But if it was not for pjmoreland I would have been driving around at night cussing my dash lights and perhaps buying different bulbs in vain. I am so very thankful to pjmoreland for his due diligence.
GMC Pauls has also reported the tin issue and the vendor says they will re-tool but it will take some time before that will happen. Until then, I hope people find 70shortfleet!! As for the cost, so long as they last I'll be happy!
#83 | |
#84 |
Mr. Cheyenne
GMC Pauls does seem to have those little seals or the little cardboard tubes... if you find any do let me know. I suppose some kind of a (lite) ATV would work but that seems like a hack.
#85 | |
Mr. Cheyenne
Got this great suggestion via PM
#86 |
![]() Join Date: Aug 2018
I just got a new lens for my bezel and the green paint is on the back side so I’m guessing that this is one of the lenses that are painted wrong?
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
#87 |
The green paint is supposed to be on the front of the lens, so your new lens was made incorrectly.
#88 |
I finally got around to doing this mod with an old bicycle inner tube while I was installing a vacuum gauge. No more bleed-through on my turn signals
#89 | |
Nice job!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#90 |
Mr. Cheyenne
I ended up buying a sheet of rubber off Amazon, figured I could use it for other stuff. But it is more or less the same as bicycle tire rubber.
I also ended up replacing the Tach Grommet (and I saw also I could have gotten new tubes) on the Ecklers. I thought I share, as it seems I never updated my progress on the Bleed-Thru. 1953-1977 Corvette Speedometer or Tachometer Grommet Turn Signal Indicator Lens, Green, 67-72
#91 |
Mr. Cheyenne
thought I add another photo, this is with the driver side door opened. I took this photo to show how my new Blazer Courtesy lights look and happen to have the running lights on (so the dash is lit up).
#92 |
