Old 04-29-2024, 10:50 AM   #76
jasinger01
jasinger01's Avatar
Re: 1969 GMC.. right off the farm
Then started sanding the cab. Worked most of drivers side, not trying to strip all the way down to bare metal, but just want to get it to a smooth starting point.
The cab has only had 1 re spray, it was definitely maroon poly from the factory before it got re-sprayed red
jasinger01 is offline   Reply With Quote
Old 04-30-2024, 10:14 AM   #77
raggedjim
raggedjim's Avatar
Nice work, curious to see how your fauxtina paint goes.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 04-30-2024, 10:19 AM   #78
jasinger01
jasinger01's Avatar
Good luck, Rg
Thanks, I'm thinking very subtle. Just want it to look worn in, maybe get the black or primer to poke through in a couple spots.
Old 05-13-2024, 08:21 AM   #79
jasinger01
jasinger01's Avatar
bench seat back in, drilled holes and installed the sill plates. interior is getting really close! have a big box from LMC with the rest of the pieces I needed
Old 05-19-2024, 12:46 PM   #80
jasinger01
jasinger01's Avatar
Made a separate thread but posting here if anyone knows as well..
Hi, I'm wondering if I have my rear bumper brackets on correct? Truck is a 1969 GMC SWB with leaf springs. This is the only orientation that I could find that works for the brackets, and matched a picture that I found on an older thread.
Is the bumper supposed to stick this far out past the tailgate? There is a huge space there. Not sure if I have an incorrect combination of bumper/brackets?
Any feedback on if this is how it is supposed to look or if I'll need to buy a different bumper/brackets?
1969 GMC build thread: https://67-72chevytrucks.com/vboard/...d.php?t=828261
Old 06-20-2024, 12:38 PM   #81
jasinger01
jasinger01's Avatar
Determined that my bumper brackets are in fact for a coil spring truck. Needed to cut/slot them to pull the bumper in closer to the truck. More notes here: https://67-72chevytrucks.com/vboard/...d.php?t=852610
Otherwise, I've got the interior pretty much done for now. Will grab some pics this weekend.
Cab wise, I rattle canned some red oxide primer, then flat black, then rustoleum 'dark hunter green'. Layered it like this so I can do some wet sanding aging, but going to let the paint cure for a few weeks.
Have actually been driving it around town a little bit. Really happy with how the suspension, brakes, power steering all feels. Tuned up the carb a bit and seems to be running well!
Old 06-22-2024, 10:01 AM   #82
raggedjim
raggedjim's Avatar
Nice work, the dark green with cream wheels is eye-catching. Rg
