Old 03-14-2023, 08:08 AM   #76
joesscamaro
Re: 65 C10 Family Connection
That is a cool idea...I don't think I've ever seen that done before. Well done.
joesscamaro is offline   Reply With Quote
Old 03-14-2023, 08:44 PM   #77
FamilyTruckster65
Originally Posted by cwcarpenter98 View Post
I like your way of making room for the axle a lot better than the typical step notch.
On the extension needed for the rear of the frame, if you're trying to stay with a mostly stock looking frame, maybe you could get the rear section of rails from a long bed frame to get the length needed?
Ohh, that would be sneeky! good idea.
FamilyTruckster65 is offline   Reply With Quote
Old 03-14-2023, 08:46 PM   #78
FamilyTruckster65
I have thought it was, but it is not mine. I had seen it done on here before, specifically Rob at NoLimits shop truck. I just went a little more aggressive than they did.
Old 03-14-2023, 08:56 PM   #79
FamilyTruckster65
Putting things in the way so that I can see what room is left for exhaust. I want to run it past the axle and either dump behind the tires or from under the bumper.
So the trailing arms are from Tinworks and have 2 inch spacer equivalent built in. The Sway bar, panhard rod and brackets, and the shock mounts are NoLimit parts.
The axle is a Ford 9 inch from a 1970 F100 that is 1.5 inches narrower than the factory 12 bolt.
The step up is around 5 inches.
Old 03-15-2023, 08:13 PM   #80
FamilyTruckster65
Had to roll a tire over there at simulated ride height for inspiration.
Old 03-16-2023, 10:41 AM   #81
88Stanger
88Stanger's Avatar
DAMN, that is just badarse!! Love this!! Great work sir!!! I can see it already, you have inspired some new ideas! Keep up the great work, maybe one day I will get to see it done in person.
I see you are in Oregon, you going to the Swap meet in Portland?
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 03-16-2023, 07:09 PM   #82
FamilyTruckster65
Thank you 88. You are alot further ahead on your project, I have been keeping track.
I have never actually made it to the swap meet even though I have been here most of my life.
Old 03-16-2023, 07:14 PM   #83
FamilyTruckster65
Boyds tank making a test run for fitment. I will be mounting it on the top flange of the frame rail instead of the usual placement of the bottom. I have removed the rearmost cross member for some extra room. That support will be replaced with a hidden hitch.
I should have plenty of room since the bed floor will be raised.
Old 03-17-2023, 06:48 PM   #84
FamilyTruckster65
ok, jumping a bit. Really want an x pipe in here, but space with a 3" exhaust is a premium. Quite a bit of finagaling. I may run out of time with this part. The 8 speed is long and large. The two crossmemebers are very beefy and the 3" is very resistant to flexing...
Old 03-17-2023, 06:51 PM   #85
FamilyTruckster65
Argh..This is kicking my tail.
Old 03-19-2023, 12:08 AM   #86
FamilyTruckster65
Well the space to put the xpipe was too tight for the resources of the time. So I went old school true duals. I may revisit the x pipe.
Old 03-19-2023, 05:51 PM   #87
FamilyTruckster65
Trying some ideas on the routing around the fuel tank. Pretty sure I am gonna exit them under the fender between the tire and bumper.
Old 03-20-2023, 10:40 AM   #88
FamilyTruckster65
working on a floor mount shifter for the 8spd auto. This is a gated shifter from lokar.
Old 03-23-2023, 07:35 PM   #89
FamilyTruckster65
The 8L90 sure fills up the transmission tunnel.
Old 03-24-2023, 02:59 AM   #90
Braunschweiger
What a fantastic job, it looks perfect,
a really big gearbox.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 03-25-2023, 12:03 AM   #91
FamilyTruckster65
Test fitting the hydrobooster and master cylinder. I am using CaptainFabs (from the forum here) brackets. They fit really nice. I chose his kit that has the provision for a clutch master cylinder, although I have an automatic at the moment. I have been toying with the idea of using a 6 speed manual from a Nissan Z car. What has kept me from the manuals is having the shifters interfear with the bench seat.
Old 03-25-2023, 12:26 AM   #92
Arne
Arne's Avatar
With your skills, I'm sure you could fab something that would work. Something with a curved stick like my truck has.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 03-25-2023, 01:57 AM   #93
Nappers
Great project! Looking at these keeps me from selling mine. I’d regret it. Keep up the awesome work!
Nappers is offline   Reply With Quote
Old 03-25-2023, 11:18 AM   #94
FamilyTruckster65
Thanks, Arne.
Yes I can fab something, but the clock is ticking... I will likely revisit this in the future.
Old 03-25-2023, 11:20 AM   #95
FamilyTruckster65
Thank you for the encouragement. You would regret selling before you have had a chance.
Old 03-26-2023, 08:50 PM   #96
FamilyTruckster65
This days agenda. These are the 1970 F100 axles. They are 5 on 5 1/2 pattern. They need to be 5 on 5.
Old 03-26-2023, 09:18 PM   #97
Getter-Done
Getter-Done's Avatar
Great machining
Yeah one of those holes has to be Plugged
Because the stars do not Align
84 Chevy K-20
Old 03-28-2023, 08:17 PM   #98
FamilyTruckster65
Whoo! The holes match. We are using the front vented rotor from a late '90's AWD Chevy Astro van as the rear disk. The rotors are 1.25" thick and 11.6" in diameter. For now I will be using GM D52 calipers.
The OD of the axle and the OD of the register hub were turned down to match the rotor, so no mods to the rotors needed, now or in the future. Just a regular parts store item
Oops.. The picture shows the Ford pattern. I guess I forgot the take an after pic..
Old 03-29-2023, 12:40 PM   #99
Duncan K
Your fabrication work is top notch, great work so far! I am really enjoying this build
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 03-29-2023, 07:07 PM   #100
FamilyTruckster65
Thank you! Not a whole lot of fabrication from me yet, but a lot of great parts made by our talented vendors.
Still more to come!
