Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-16-2025, 12:16 PM   #76
hevy_chevy67
hevy_chevy67's Avatar
Re: 1970 Blazer Build
Originally Posted by dec010974 View Post
I will send you the template and bar. No biggy. Just give me your address. Moving forward, I cut the speedway engine mounts and made perches that raised the engine, to the frame crossmember, and correcting the drive line angle. The engine was laying center link using the original speedway mounts. I also purchased these Camaro mount to see how the fit. Lastly, where would you place angle finder, to find the rear differential pinion angle? I'm thinking one of those lines on differential case.
Is there a flat spot big enoigh on top of the diff to place a digital angle finder? Around where the rear cover bolts on.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is online now   Reply With Quote
Old 03-16-2025, 12:26 PM   #77
hevy_chevy67
Point of no return on my color! I finished up the floor work and put it in epoxy. Then sprayed some reduced raptor liner from a HVLP gun. Minimal texture and very happy with how it sprayed. I'll be doing my top this way when the time comes. Crappy lighting but it was midnight when I finished and my tripod light burnt out as I was cleaning up.
Old 03-31-2025, 02:07 PM   #78
hevy_chevy67
Cleaned up the firewall a bit - planning to get color put down on it this weekend so I can get the cab back on the frame.
Old 03-31-2025, 02:56 PM   #79
dec010974
dec010974's Avatar
@hevy_chevy67 " Planning to get color put down on it this weekend so I can get the cab back on the frame." Awesome.
dec010974 is offline   Reply With Quote
Old 04-05-2025, 11:19 PM   #80
hevy_chevy67
Firewall painted. First vehicle I've ever started painting, I'm quite happy with how it came out.
Old 04-19-2025, 12:16 PM   #81
hevy_chevy67
Done painting for a bit now. Can finally start putting this tub back together soon.
Old 04-21-2025, 04:38 PM   #82
hevy_chevy67
Should start looking like a Blazer soon
Old 04-22-2025, 10:04 AM   #83
raggedjim
raggedjim's Avatar
Very nice work. Is the paint 503 green?
Rg
raggedjim is online now   Reply With Quote
Old 04-22-2025, 10:28 AM   #84
hevy_chevy67
Rg
Yep, 503 green.
Old 04-22-2025, 10:39 AM   #85
raggedjim
raggedjim's Avatar
Originally Posted by hevy_chevy67 View Post
Yep, 503 green.
My favorite!
Is it single stage acrylic urethane? I'll be painting my 68 soon.
Old 04-22-2025, 11:39 AM   #86
hevy_chevy67
My favorite!
I went with a base/clear paint.
Old 04-26-2025, 11:04 PM   #87
hevy_chevy67
Rolled outside today to clean up the shop a bit. Starting to look like something now haha
Old 04-28-2025, 10:34 AM   #88
dec010974
dec010974's Avatar
Hello hevy_chevy67. Did you ever get your steering situated? The k5 blazer looks awesome.
Old 04-28-2025, 12:06 PM   #89
hevy_chevy67
Thank you.
No, not yet. The template you sent me is waiting at the border for me to pick up yet. I've got a few things to get shipped there before I make the trip down to get it all.
Old 05-03-2025, 02:16 PM   #90
dec010974
dec010974's Avatar
Your K5 blazer looks awesome. I hope my 2WD K5 blazer looks that nice.
Old 05-04-2025, 10:51 PM   #91
hevy_chevy67
Thanks. I hope I can keep it up and not botch it on the paint job haha
Old 05-19-2025, 03:04 PM   #92
hevy_chevy67
Started mounting some more sheetmetal and mocking things up. Getting there, some adjustments needed yet. Also need to get the rear dropped just a little more yet.
Old 06-28-2025, 10:41 PM   #93
hevy_chevy67
Found a rear diff with 4.10s, so pulled out the old one with 3.08s. Saves me having to get the gears changed.
Also got the rear lowered to where I want it o sit now. Looks much better.
Door and fender gaps almost dialed in. Spent way too much time messing with shims and getting the gaps to an acceptable level. But I'm almost there.
Hoping I can get this thing in primer before the end of July.
Old 08-04-2025, 09:08 PM   #94
hevy_chevy67
I have two original hoods, both of which have their own issues. So i decided to roll the dice on a new cowl hood. Fit isn't perfect as it doesn't sit quite flush with the fenders up front. Probably some adjustment yet but regardless I can live with it, I'm not building a show truck here.
Old 08-06-2025, 03:00 PM   #95
lks dcvn
lks dcvn's Avatar
Looks great - this is really coming together! I also like the 503 green - good choice.
lks dcvn is offline   Reply With Quote
Old 08-07-2025, 03:50 PM   #96
hevy_chevy67
Thanks, although I was hoping I'd be further along at this point!
Old 08-08-2025, 02:59 PM   #97
dec010974
dec010974's Avatar
@hevy_chevy67, do you have Whats App? I would like to share my K5 Blazer. "It's butter, 'cause it's on a roll."
Old 08-10-2025, 01:28 PM   #98
hevy_chevy67
I do not, but I have an Instagram account, although I dont use it.
Old 08-10-2025, 01:44 PM   #99
hevy_chevy67
Got the tailgate put on. Everything fitting pretty good so far.
I had told myself a few months ago I would get it in paint by fall, but that doesnt look to be happening. I finished building a temporary paint booth in another building and it isnt heated so im not going to rush things. It's not pretty, but I think it will work. It seems to move air good and creates positive pressure inside. think im going to get a cheap Amazon smoke machine and see how quickly it moves air out. Essentially all the intake air is filtered through that box, which has two fans blowing down from the top. The floor needs a thorough cleaning yet. Im into it for less then what a portable Amazon booth would be and from what I read those things dont move air well.
Old 08-12-2025, 11:53 AM   #100
raggedjim
raggedjim's Avatar
Nice, I like to see how people build their paint booths.
My neighbor paints in his driveway. He paints in the morning on a low humidity day (rare around here) Throws down an old carpet, hoses it down, parks the car on it, and goes to town! Somehow he has good luck doing it.
