Old 09-24-2023, 04:32 PM   #76
RustyPile
RustyPile's Avatar
Re: Tremec TKX 5 Speed Transmission Installation
Betcha can't wait to try out that new volt meter...
RustyPile is offline   Reply With Quote
Old 09-24-2023, 04:41 PM   #77
pjmoreland
pjmoreland's Avatar
It's all about the voltmeter. Transmission? Meh
pjmoreland is online now   Reply With Quote
Old 09-24-2023, 04:56 PM   #78
RustyPile
RustyPile's Avatar
OH, Transmission!!!! I almost forgot about that... {snicker, snicker}
Old 09-24-2023, 07:01 PM   #79
pjmoreland
pjmoreland's Avatar
Since my truck no longer has a TV cable, I replaced the bracket for the TV cable with a smaller one that is just for the throttle return spring. This is a copy of one made by Lokar, but it was about 1/4 the price on eBay. Required a little tweaking and filing to fit the Sniper.
Old 09-25-2023, 09:41 AM   #80
pjmoreland
pjmoreland's Avatar
A friend made me some spacers to raise the rear of the transmission 13/16. This amount of lift set the transmission at the same angle as the rear end pinion. It also made the clutch bellcrank more level, and now the speedometer cable is no longer munched into the transmission crossmember.
I also installed the clutch inspection covers.
Old 09-25-2023, 09:46 AM   #81
pjmoreland
pjmoreland's Avatar
I bought the wrong starter, so I swapped the original starter nosecone onto the new one. I also replaced the bushing with a new one I got at Napa. I installed the starter along with the little brace that attaches the forward end of it to the engine block. I started the engine, and the starter sounded fine.
Old 09-25-2023, 10:40 PM   #82
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Thumbs up Re: Tremec TKX 5 Speed Transmission Installation
Looks really good PJ, well done! Looking forward to the shake down run report...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-25-2023, 10:51 PM   #83
pjmoreland
pjmoreland's Avatar
Thanks! I'm anxiously waiting for the call that my driveshaft is ready!
Old 09-26-2023, 03:33 AM   #84
pjmoreland
pjmoreland's Avatar
Installed a new carpet to accommodate the high hump.
Old 09-26-2023, 10:45 AM   #85
MySons68C20
MySons68C20's Avatar
Looks factory very nice!
MySons68C20 is offline   Reply With Quote
Old 09-26-2023, 11:52 AM   #86
pjmoreland
pjmoreland's Avatar
Thanks. By the way, the carpet is from ACC and has mass backing. I am impressed with the quality, especially compared to the LMC carpet it replaced.
Old 09-26-2023, 09:22 PM   #87
pjmoreland
pjmoreland's Avatar
Picked up the driveshaft just now.
Old 09-26-2023, 09:28 PM   #88
MySons68C20
1 step closer to the edge.....
Old 09-26-2023, 09:32 PM   #89
pjmoreland
pjmoreland's Avatar
Yup! Now I gotta wait for the Hurst 16" shifter lever to arrive. I ordered it last Friday and it shipped from Nashville yesterday. Everything should be complete at that point.
Old 09-27-2023, 01:08 PM   #90
pjmoreland
pjmoreland's Avatar
While installing the new driveshaft yesterday evening, I decided to do something I've never done before, which is to use a torque wrench on the pinion u-joint u-bolts. This is because I've heard that overtightening the u-bolts can damage the u-joint bearings. I looked up the spec, and it's 20 ft-lbs. I couldn't get my torque wrench to reach the nuts though, even with a swivel adapter.
I didn't have a 9/16 crow's foot, so I drove over to O'Reilly to get one. They only sell crow's feet in a full set, so I bought the set for $26 and drove back home. I was a little nervous though because these crow's feet were kind of bulky. I popped the staples out of the packaging carefully just in case, and sure enough, the 9/16 one was too big to fit onto the u-bolt nuts. I put the crow's feet back in the packaging and reinserted the staples.
I drove over to Napa this time and bought a single Carlisle slender 9/16" crow's foot for $17. Ouch. At least I got a $5 frequent flyer discount.
Then I headed back over to O'Reilly to return the first set. I told them I had repackaged it and showed them the slender crow's foot I got at Napa. They took the set back and gave me a refund.
I headed back home and started tightening the nuts with the torque wrench. I had the crow's foot pointing off at 90° so that the length of the crow's foot wouldn't mess with the torque wrench setting. I started out at 10 ft-lbs, and then moved up to 15 ft-lbs. It just wasn't tightening down for some reason, and then the u-bolt threads stripped out. I'm guessing this is a case of low-quality u-bolts. Grade 5 unplated 3/8-24 bolts should be able to be torqued to 35 ft-lbs, and grade 8 to 49 ft-lbs. These should not have stripped out at under 15 ft-lbs.
I ordered a set of Spicer u-bolts for 1350 u-joints from O'Reilly, so I'll get to drive over for a third time here in a little bit when they arrive.
I bought the 1350 pinion yoke that these u-bolts came with from quickperformance.com. I just called them, and the guy agreed that it shouldn't have stripped out at 15 ft-lbs. He's going to run a torque test on a set there, and he's going to send me a replacement set.
Old 09-27-2023, 01:17 PM   #91
pjmoreland
pjmoreland's Avatar
Oh, and this arrived just now.
Old 09-27-2023, 08:42 PM   #92
chipmaker 1985
Thank you for the write up. I'm trying to decide whether to piece together a kit or just bite the bullet and go with Silver Sport.
I was quoted 4k for a 700r4 rebuild to handle my 400SBC. Makes no sense not to go with the TKX. At least that's the argument I'm giving to the Mrs.
chipmaker 1985 is offline   Reply With Quote
Old 09-27-2023, 08:47 PM   #93
pjmoreland
pjmoreland's Avatar
You're pretty close to the Silver Sport kit price with the cost of that 700R4.
Old 09-27-2023, 10:06 PM   #94
MySons68C20
Nope, not even close..
Old 09-27-2023, 10:09 PM   #95
pjmoreland
pjmoreland's Avatar
Close to the basic kit, anyway. It doesn't include a lot of stuff like the clutch and bellhousing.
https://www.summitracing.com/parts/ist-efkc10tkx
Old 09-28-2023, 01:04 AM   #96
pjmoreland
pjmoreland's Avatar
The driveshaft is installed with new Spicer u-bolts. I did a quick check of the other u-bolts and they stripped out at 21 ft-lbs in the vise and with a regular socket on the torque wrench. I went ahead and followed some good advice and just torqued the u-bolts down by feel in the truck. If anything, I'm a little on the loose side of the 20 ft-lb spec, but they are nice and tight.
I also filled the transmission.
The truck is down on the ground. The only thing preventing me from driving it is the shifter stick, which is supposed to be here on Friday.
In the meantime, I will be working on rebuilding an original floor-shift tilt column I was fortunate to find at a decent price recently.
Old 09-28-2023, 01:05 AM   #97
pjmoreland
pjmoreland's Avatar
Back on its wheels
Old 09-28-2023, 05:59 AM   #98
chipmaker 1985
I was quoted just under 5k for a basic kit without driveshaft, bell housing, or x-member. It did include a billet flywheel balanced for the 400, McLeod super street clutch kit, front mount shifter, all hydraulics, and hardware. It seems steep untill you start pricing quality parts individually.
I wasn't really happy about running the 700 anyway. I thought it would be a cheap solution to get my 70 drivable. It's worth the extra couple months of overtime to go ahead and build what I really want and not have to worry about breaking it.
I'm loving how this install is shaping up. It always looks better if it looks like it came from the factory IMO
Old 09-28-2023, 09:04 AM   #99
Rickysnickers
You've done a really nice job!!
Old 09-28-2023, 10:58 AM   #100
MySons68C20
The complete kit with everything and I mean everything needed from Silver Sport was $6500.00. The one addition not included was a spacer plate to set the correct hydraulic throwout bearing clearance. Not every install needs this but mine did.
Well done PJ 1st class job you've done!
