#976 | |
Re: My 1965 build thread
#977 | |
1 thing at a time is progress.
[quote=MacAttack;3292660]NASA called and they said you've got to take out a permit to have something that bright here on Earth. ![]() Thanks fellers I spent my lunch hour plus some trying to find this fitting for the back of the ac compressor. This is my coworkers truck. He didn't know where to get it, he paid someone else to do that stuff. ![]() Here is a link to nostalgicairparts.com They also have bulkheads for the firewall. ![]() When it comes to plumbing I'm a little slow. I'm looking for the fittings to make this work. I imagine it is a -6 line, but I think I need a metric to an AN fitting on the pump so I can run steel braided line. Then I will need the same style that is standard to AN for the gearbox. I did a few searchs and alot of reading and looking and never could find my answer. Again my coworkers truck for an example ![]() ![]() ![]()
Alan
Philippians 2:14-16 |
#978 |
![]() Join Date: Nov 2007
Hey Alan,
Thanks for that air conditioning link! I have been looking for some good dash vents cheap and they seem to have them. Here is another link for compressor blocks and a lot of other air conditioning stuff. http://www.docsblocks.com/default.asp The truck is looking awesome!! TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#979 |
Shloooooong bed member #2
What..............No more Smokey and the bandit
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#980 |
Hey Alan,
The english power steering gear should use these fittings to convert to #6AN Aeroquip FBM2964 5/8-18 male inverted flare to #6 AN male $6.95 Summit Aeroquip FBM2965 11/16-18 male inverted flare to #6 AN male $7.95 Summit Then the #6 right angle hose ends will fit those like Earl's EAR-809106ERL TR
#981 |
One day...
Wow Alan the dash looks awesome all painted up!
#982 | ||
It was a hard decision. That's the best movie of all time. I might put it back up in time. Quote:
![]() ![]() Thanks Scott, ![]()
Alan
#983 |
Alan,
The English use inches, that's where we picked up the bad habit. The rest of Europe uses metric. Sorry for the confusion, English=Standard. Yep the 71 box would be English, whoops I mean Standard. TR
#984 | |
![]() Still working one cabinets. It's a long story. I'll leave it at that. Got a little sanding done. The back panel is done. I know that is so exciting. Finally finished installing my front shocks. Had to pick up some new lower bolts. It only took 4 months to do that. ![]() ![]() ![]() While I was picking up bolts I picked up the long bolts for the motor mounts. I was missing one of coarse so I had to get 2 that matched. I was going from memory on what diameter bolts I needed. Well you know how the memory works. Thought the bolts were bigger than what they actually are. But did take the water pump off and paint it. Another thing off the list. ![]()
Alan
#985 |
Sunburst C10!!!
lokking good alan do you have the clamshell motormounts
Gage 1967 C10 Shortbed Stepside |
#986 |
Daring to be Different
Is that your secret. You have a list???
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#987 |
SSN 706
#988 | |
#989 |
Member of the longbed union.
you know I think I need to make a list, I always have to go to the parts store to get something about every day. would make life a lot easier on me.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#990 | |||
Yes there are (I think). They are 1969 Camaro mounts.
I have several list only because I can find the one I made before. I need a clip board or something for a central location. I have to write it down or it will be forgotten. Now the secret is out. ![]() Quote:
![]() Quote:
![]() Quote:
Alan
#991 |
Allan, It's a good thing we don't live near each other.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 05-06-2009 at 08:02 PM. |
#992 |
Sunburst C10!!!
i should make a list hmm.
no thats too much trouble nevermind. ![]()
#993 |
Sunburst C10!!!
ok ill make a list
1:make a list 2:make a list that desribes the first one 3:make a list that tells you what not to forget 1:dont forget the first list 2:dont forget the second list 3:dont forget this list
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 05-06-2009 at 08:44 PM. |
#994 |
Sunburst C10!!!
hey alan what is that stuff that you spread over panels to smooth them ive seen it on shows where they spread it over the whole panel
is it just regular body filler or is it a special filler its usually green
#995 |
Rods
![]() Join Date: Nov 2002
thats poly fill. its alot smother and dosnet get near the pin holes or sand scratches. you can use it over primer also. but its hard as a rock. you can also use poly flex
#996 |
Sunburst C10!!!
how hard is poly flex which is better of the two
where do i get it
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 05-06-2009 at 09:57 PM. |
#997 | ||||
That would be a trip.
![]() Quote:
Spent the evening sanding. Yehaw! ![]() Bottom of cab still in work. Sanding is bad enough, but laying underneath the cab makes it worse. I'm using DA's as much as possible. ![]() Here are some DA's that I use. I hardly use the one on the right. It is very aggressive and the counter weight can bust knuckles and rip off fingernails. I know all too well. I love the one on the left. It has a fine cut and won't remove fingernails. The mini DA 3" is great for door jambs and tight areas. ![]()
Alan
#998 |
Rods
lol ive used all three love them also have the HOG.. for when I realy need to get the bondo off.
as far as which to use... poly flex is more for plastic or stuff that will flex more. poly fill is great as a final but only can bea about 1/6 to 1/32 thick or it will crack....its not somthink to use to fill anything . just kinda level.. you can use the same stuff as alan his slick sand method is best for large panels. |
#999 | |
Alan
#1000 |
Commander Taco Bello
woot! 1000th reply!
still a great build man. |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
