#976 |
Member of the longbed union.
Re: 198Plus build
Thanks for nothing Alan. HAHA JK
Ronnie I sent you a PM last week about some guy wanting some of your parts on the other forum. Just wondering if you got it.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#977 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 198Plus build
I'm sure you're aware of this Alan, but for the others reading this. It would be a good ides to contact the manufacturer of the epoxy primer to see if they will approve their produst for application over a soda blasted surface. Several paint companies will not guarantee their product when applied to a soda blasted surface. PPG is one of them.
#978 | |
1 thing at a time is progress.
Re: 198Plus build
You didn't want me to lie now did you?
![]() Quote:
I need item 6 in this pic. I got a plain inner rocker patch pictured below. I'm sure you can find it cheaper, just using this pic as a referrence. ![]() This is what the wrong part looks like on the truck.
Alan
Philippians 2:14-16 |
#979 |
Re: 198Plus build
http://www.truckandcarshop.com/6072.html actual page nbr 69
pt # 60-094121 & 22 @ $57.00 ea. they do look much superior to the old setup ron |
#980 |
60-66 Nut
Re: 198Plus build
You might try one of our new vendors here on the forum, topbananaparts.com I just received an order of patch panels from them today. They are Key Parts brand and upon initial inspection they look good. Top banana has some of the patch panels for the '60-'66's on sale right now too.
#981 | ||
Re: 198Plus build
Ronnie all along didn't believe this was his cab and upon further inspection he might be right. When he had his cab in the first shop that swapped his doors might have swapped cabs as well and swapped the VIN plates. His VIN plate doesn't have the rossett rivets. The first pic is his. The second pic is my cab and the third pic is the cab I have behind the shop. What's y'alls thoughts. The last pics is the stuff that came off my roof when we had our first rain since the blasting got done.
Alan
#982 |
Re: 198Plus build
I agree that the rivets look like they are not factory, but I also cant compare mine because i have removed my plate to make a repair.
One other comment here is that if they did remove that plate they did a heck of a job as when I was taking mine off it did not come off all that easy and has some marks where the rivets spun so in thinking about that I think you would see some marks from it being removed no matter how careful you were in taking it off Just a thought |
#983 |
Re: 198Plus build
The blasting may have hidden any marks. I would say it has been removed. The question is when? I assume Ronnie does not have any photos of the VIN before he had any work done? It is unfortunate if someone did swap a cab on him.
![]() Alan, I always admire how you put everything out there for people to see. That is how my father built his business, and was how I was raised. Everybody may not always like the truth, but at least they can make a decision with all the information. |
#984 |
Re: 198Plus build
In the third pic the cab still looks painted? But the vin plate is nice and clean, but a little bent up like they did indeed remove it. The more I read about this thread/ build the more like a damn soap opera it becomes ( anything that can go wrong has/will go wrong) sorry to read the latest, hopefully you guys can get it all fixed and enjoy this truck.
Posted via Mobile Device |
#985 |
60-66 Nut
Re: 198Plus build
Yes it does appear that the VIN tag has been removed at one time. Although that doesn't necessarily mean that the cab was swapped.
Man that is some nasty looking stuff coming off your roof Alan.
#986 |
Re: 198Plus build
Well, it looks like this build has come to an end. Ronnie came over last night and picked his cab up. Due to the recent discoveries with the cab, Ronnie is pretty sure the cab got swapped. He remembers the condition of it when his dad still owned it. Ronnie said the truck didn't have much cancer due to being parked under a shed when his grandfather owned it. I feel sorry for Ronnie, if the cab did indeed get swapped.
Alan
#987 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 198Plus build
What a total bummer Id sure like to see ronnie get it together though right cab or not..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#988 |
Re: 198Plus build
that is not good. is there no way for recourse, or has he just given up. It seems as if it wasn't for bad luck Ronnie wouldn't have any luck at all
Perhaps time for Guido to give those fellows a vist ron |
#989 |
Re: 198Plus build
JMHO, I think at this point and after all the work that has gone into it I would just keep moving forward as long as the VIN is matching to your title and frame.
I agree with the others I sure would like to see him finish this one it will have some good stories behind it once it is finished. |
#990 |
Daring to be Different
Re: 198Plus build
Ronnie needs to come out here and look for another cab, or look on E-Bay. He can be on vacation and do some shopping. There's deals around. I'll keep my eye out. Next June I'm trailering my bike to Kansas on my car trailer. I'll have room for a cab if Ronnie finds one out here. He can meet me. Better than going all the way to So Cal.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#991 | |
Re: 198Plus build
Next June..............With my luck I want make it that long, I already have one foot in the grave and another one on a banana peel......Lmao
Thanks for the offer anyway ![]() Quote:
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#992 | |
Re: 198Plus build
I just want to thank you Alan for all you have done for me........
One thing I did gain from all my bad experiences with this truck is priceless..... A new friend, again thanks Alan ![]() Quote:
#993 |
Re: 198Plus build
Awh, I now pronounce you both "Friends" But then again aren't we all.
#994 | |
Re: 198Plus build
Amen Brother
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 09-29-2010 at 11:07 PM. |
#995 |
Re: 198Plus build
A few things I have going on in the shop.
69 Trans Am Clone we are doing a complete Restoration on.... ![]() ![]() ![]() ![]() 1971 Mustang Convertible ![]() My 1965 Chevy Truck ![]()
#996 |
60-66 Nut
Re: 198Plus build
It's good to see your shop is busy. And also to see that you haven't totally given up on your '65.
#997 |
Re: 198Plus build
But are you making MONEY? Most body shops want to do just Insurance Jobs. Because there isn't any money in restoring older cars. That's one of the reasons I'm keeping busy.
#998 | |
Re: 198Plus build
I'm still debating on my truck......
I'm at least paying the bills and just trying to figure this new business out.
#999 |
Re: 198Plus build
Paying the bills is good. Go after those insurance adjusters. They might send you work if they like your work. But remember your always under there thumb.
#1000 |
Re: 198Plus build
Sorta sounds like my wife
